Question about Sony Playstation 3 (PS3) Console
My 9yr old son's ps 3 when starting up doesnt go past the ps screen - no icons or anything showing. tried switching on and off with no effect, 3 months out of warranty! have seen option for PS3 restore by OvErLoDe which appears best option but appears to loose all his saved stuff - any other suggestions?
  • ian_abbott Aug 06, 2010
    thanks for your help - will try out when I get home but you're top of my sons favourite friends list now! cheers,
    President:
  • 1,139 Answers
The only other thing I could suggest is if you know someone else with a PS3, to put your drive into thier PS3 and try booting up. If it does boot then you would then be able to back your stuff up on a USB stick, put your drive back in your PS3, do a PS3 system restore and then retreive your backed up data. The only problem with this method is that your friends PS3 has to be on the same firmware as yours is, otherwise he will have the same booting problem.
I hope this helps
Posted on Aug 06, 2010
Testimonial: "help very much appreciated!"
    Novelist:
  • 105 Answers
Hi Ian, unfortunately it's a frequent problem and when you get stuck like this there's nothing you can do. I'd just go straight to the recovery menu and see if it'll work, other than that the only chance is to contact Sony technical support but most probably you'll get a refurbished PS3 and they're gonna ask you about 120 USD for the fix. Yes, it's true that if you're going through the recovery, you'll lose alla your saved stuff, but your son won't lose his trophies, because are stored online, which usually are the most "precious" thing for PS3 gamers.
To access the recovery menu, do this: Make sure the PS3 is turned off Press and hold the power button on the PS3 it will power on then power off. When it's off press and hold the power button again until you hear two consecutive beeps. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try) It will ask for the controller to be connected via the USB cable, Turn on the controller and you will have access to the menu. Be aware that you may lose all of your previously saved data (NOT trophies, they're stored online so don't worry).
Thank you for using Fixya and for rating my solution if you find it helpful. Peter_Rei
  • 1 more comment
    Peter - many thanks indeed for taking the time to respond - my son will be adding you also to his xmas card list!
  • Mauro Aug 06, 2010
    LOL ian (-:
    well, I hope it'll work, otherwise feel free to ask for more help!!
    Peter
  • gr8twhitesha Jul 30, 2011
    i did what you said and now nothing pops up help
My phone is not showing the icon past android
try to reflash the ROM with a recovery boot image, google the process for your cell or contact nearest service center.
May 15, 2014 | LG GD510 Cell Phone
My son passworded my hp lptop while he was home from Afganistan. I tried to use my computer today but I can't get past the sign in screen that asked for user name and password. I haave no idea what he...
Power on pc->immediately start tapping the F8 key on keyboard->select safe mode->press enter->login as administrator(password might be blank, u can give it a try).If successful u would be on a desktop screen with safe mode on all four corners.Now go to start->control panel->useraccounts->select ur son's account and remove the password.This is worth a try.If it doesnt work the only option is to reinstall the windows(if u cant remember the pwd for your son's login)
regards
Abhilash
Sep 20, 2010 | Computers & Internet
Hi: I have a 9yr old profile refrig, mod #tfx25prb...
What is your refrigerator cold setting? Try lowering the temp to to the medium setting.
Items in the lower part of the fridge will freeze if the setting is too high. (P.S. Cold air "sinks" so the lower part of the fridge will be colder. Cutting the "number" setting on the fridge does stop air flow though.
Oct 03, 2017 | Refrigerators
Console interface problem on the switch
HyperTerminal sucks. Use PuTTY and make sure you have the correct baud rate of 9600 set.
Putty Link:
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
Mar 30, 2010 | Cisco Catalyst 3550-24 24-Port Ethernet...
No POST/Black Screen
Believe it or not, clearing the CMOS might actually help. Make sure you do it right by completely unplug the power cord or turn off the PSU, then take the battery out.
It also sounds like the CPU might be too hot. Look under the fan of the heatsink and see if there is any dust that will block the airflow. When the computer is on, touch the heatsink and feel if it is really warm. If it is really warm, it's a good sign, you might just need more airflow. If it is cold, you might need to reinstall the heatsink/apply new thermal compounds.
Mar 07, 2010 | Gigabyte Computers & Internet
Start-up problem - just stays on apple icon
try putting in the original install disk and do a repair or restore. The notebook should have also come with some diagnostic software. If not, contact Apple and have them hook you up. He can always use the computer at the library..... good luck!
Jun 03, 2009 | Apple Computers & Internet
My tom tom one XL turns on but doesnt go past the start up screen
If you are talking about the Main Menu that shows only 5 icons, tap change preferences, then show all menu options. From there you will see all the icons and menus that are available for your One. Thanks for using Fixya!
Jan 26, 2009 | Tomtom ONE GPS Receiver
I was given a Nintendo DS Lite with a R4DS card with games already on the card as a gift. It was working find until I removed my card and used one of my sons games and try putting my R4DS card back. Now...
I can help u the problem is u must have touched the R4 ds card i have one too u see but even the slightest touch of the R4 ds card will make it freeze so try not to touch it.P.S. your takin advice from a 9yr old
Dec 04, 2008 | Nintendo DS Console
Ps 3 games wont start
ah this promblem happend 2 me after playib cod4 and in game music switchin off 2mute. then a blank screen came up in da ps manual is says if this happens let it load and switch off from controller not from bak or it can cause malfuntion if u did that u have 2 send ur ps3 system back 2 sony .........lol hope ya still got warranrty
Apr 09, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
114 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
