I do not have a charger for my laptop. Model: AGM20. We tried another universal charger, and still the laptop will not charge? It does not even switch on.
  • 6,826 Answers
The battery may be dead or shorted out and won't take a charge.
How old is the battery? If it is over 2 or 3 years old, it may be bad.
Posted on Aug 06, 2010
  • 64 Answers
I have had lots of laptop's in for repair, this is the power connector on the motherboard - it becomes dislodged from the solder point's inside.
If you find a good computer store they will repair the connector (just needs a full stripdown and a blob of solder to make it connect) I charge £25 for this work, but some will advise you need a new motherboard and charge well over the odds for just a blob of solder.
Good luck with finding a good computer engineer (or someone that is good at soldering)
Where can I purchase a charger for my POWER ON BOARD - BRIGHT BAR - MODEL WLB26P
That unit could be 10 years old!
VECTOR
4140 S.W. 30th Ave., Ft. Lauderdale, FL 33312
Toll Free: (800) 54-HOW-TO
WLB26P
Jan 31, 2016 | Computers & Internet
My laptop not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
Or: 2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
Or: 2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/laptop-ac-adapter/universal-ac-adapters.html
Oct 28, 2012 | Computers & Internet
My laptop doesnt charge propely
the charging port in the laptop is either loose or has a bad soilder on it.
Apr 22, 2012 | Fujitsu Siemens ESPRIMO MOBILE V5535...
Targus charger wont charge laptop when laptop on?
The laptop does not recognize the charger due to a different wattage/ amperage or is not powerful enough to charge the laptop while the machine is powered. I have seen many problems with hps/compaqs and the Targus Universal Charger and recommend the HP universal charger for those models instead.
May 23, 2011 | HP Compaq nw9440 Notebook
Cell won't charge even with a new battery
Try to use or buy universal charger. Get your battery and charge it to universal charger. so that you can use your phone. This is the easy way so you can use your phone.
Jan 25, 2011 | Cell Phones
Computer wont charge with universal charger
Please check the technical specifications of your computer charger and see that your universal charger fulfills the same. Generally it is found that the universal charge may supply the required voltage but may not provide the required amperage. That is the reason most of the electronic companies insist on their chargers. If your charger is not working please get one from the company rather than using the universal charger and the spoiling your computer. Universal chargers are OK for some of the electronic devices which do not require higher currents.
Dec 27, 2010 | Dell Inspiron 1525 Laptop
Laptop will not charge..
First of all, it could definitely be something with the battery. Batteries have a finite life-time, and yours might had reached it's end...
Anyway, chargers for laptops are quite "unique" for each brand, sometime even for each model. There's a chance that by your "trial and error" you might even caused more damage... :/ You should CAREFULLY take a look on what your laptop consumes, in terms of VOLTAGE and CURRENT. Connecting incompatible charger (even if it's plug fits perfectly) might (and often will) damage your battery and/or the motherboard.
With that said, try replace the battery (if you can try it without buying a new one - better), then use your ORIGINAL charger. Of that doesn't work - use a replacement branded charger. If that doesn't work either - you might need to check it the laptop still works.
Mar 10, 2010 | Dell Computers & Internet
Computer wont charge. Plugged up and still wont charge. Is it internal, battery or charger?
I'm not asking if the computer will charge, I'm asking if when you have it plugged in does the computer operate normally. You should be able to take the battery out of a laptop and plug in the computer in and the computer should still operate.
Nov 07, 2008 | Computers & Internet
Troubleshooting with Toshiba Satellite A75-S211 Notebook
try more chargers, if posible one made for u;re model , so that u;ll know if the charger is the problem !
i susspect that not the charger gives u hard times but the computers power managment hardware/software .... U can try to open the computer, and look for burned, blackened, smoked, components (capacitors usualy), and if so change them (if possible)
Feb 20, 2008 | Toshiba Satellite A75-S211 Notebook
Computers & Internet Logo
42 people viewed this question
Alun Cox
David Payne
David Payne
