Question about Cub Cadet Garden
My cadet will not drop the blkade to cut grass
  • 144 Answers
There is a very tight spring usually connected at the back of the lever used to drop the deck and than attaches to the deck. You may need to reconnect the spring or get a new one. Sometimes if you accidently rammed a stick or something in that area where the spring is, the spring will just pop off and need reattached. If there is no spring, follow the lever and find out where it goes, then go from there. Maybe a bolt missing or something like that. It is simple though.
Posted on Aug 06, 2010
Why will a cub cadet lawn mower cut grass a few mi. then stop cutting?
Sounds like the electric PTO clutch is bad and needs to be replaced.The straps within the clutch brake causing it to get out of position and the clutch keeps disengaging. You can buy the clutches on line cheaper but they don't last as long.
Apr 22, 2015 | Cub Cadet Garden
How do i restart my cubcadet model cc46es after it stalled because of grass
disengage pto start up move to alredy mowed area shut off and clean grass from under deck restart it turn on pto cut grass
Jul 11, 2014 | Cub Cadet Garden
Runs good first five minutes,but while cutting grass the rpms drop down and bairlly will cut the grass,just spits and sputters whats wrong?
Hi Dewayne, I think you may have a problem with the coil. It sounds like it's heating up while running and then it's open too much. It may also be muck in the fuel tank. Check them both.
Aug 02, 2013 | Cub Cadet Garden
I have a cub cadet 1000, it's approx 4 years old, i was in the middle of cutting the grass and the mower stopped running. Tractor runs mower will not come on. Is there a switch or module that nee
check the clutch on the end of engine drive shaft it is the same as a car air con clutch put power on to it and it should click so most likely the wire from switch to clutch
Apr 22, 2013 | Cub Cadet Garden
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
My cub cadet 1042 leaves a stip down the center when mowing. I have new blades put on by the dealer and this seems to be an ongoing problem.
I had the same. design of the deck is not good. grass will build up and insolate (like a donut) the blade from cutting the immediate blades. FIX - replace custom blades with "Gator Blades and the claws will free up the cluster of interferances of grass, kick it out, thus allowing the blade free space to cut the immediates blades of grass.
Hope this helps as it was my last trial of fixes. IT DOES WORK.
J THOMAS
Apr 26, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet zforce
hello
check mower deck is not caked up with grass if it is it will not get enough air movementto force the grass up the chute
also try cutting in 2or3 passes so that you are not forcing too mush grass up the chute
hope this helps
Mar 13, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
81 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
