Question about Panasonic Viera TH-42PX80U Plasma TV
Hello, I have one fine (1mm) vertical lines on Panasonic Viera screen corlor is bright, Flikering blue. Smetimes more lines. yesterday five lines, today one line again.
  • thierry_devr Aug 06, 2010
    Error on model type: my screen model is Panasonic TH42PV60EH
  • Panasonic Master
  • 11,800 Answers
This can be caused by these defects:
1 - the connections to the plasma panel are loose. To fix that you must open the case of the tv and reseat all connectors to the panel.
2 - the memory of the image processor(or in rarer cases th processor itself) has failed so you end up with image corruption - the image board must be replaced; this will cost you around $150, without labor. By your description this appears to be your case.
3 - the plasma panel itself has suffered a damage in the pixel lines connections - this cannot be fixed, terminal, the tv should be used as is or junked.
Posted on Aug 06, 2010
  • thierry_devr Aug 07, 2010
    Dear,
    Thank you for your solution proposition.The lines apprear in all connection type and even when all cables are unplugged.
    Is this something that happens frequently with Plasma screen? or with Panasonic?
    Is there a better brand/solution for a new tv?
  • Azrael SRL Aug 07, 2010
    Since the defect is present even without any cables connected then the defect is located in the plasma screen - this is unfixable.
    Highly uncommon on modern plasma's, much more common on LCD's. But it's a common way to go on older plasma panels like yours. Any modern plasma tv has virtually eliminated the problem so you can buy one without a problem.
    Personally i would avoid Samsungs (too may unrelated reliability problems) but everyone else will be just fine. Just go into a shop and look for the one with the best image - and try them, in shop they are usually pushed to their absolute maximum, no room for improvement afterwards.
    My personal best, the one for i save all my money - Panasonic Viera TC-P50VT25
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
How to fix vertical black line on panasonic viera th-42pz80
If you let me know in which location of the screen is located I can assist with the possible cause since the vertical line can be caused by different items based on where its located on the Screen such as center of screen, or far right side or midle of the right half side of the screen. Reply to this same post with where the line is located and I will assist you with it.
Oct 16, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Thin coloured lines running down center of tv. Panasonic Viera.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP TO SOLVE THE PROBLEM.....
Aug 07, 2011 | Panasonic Televison & Video
Vertical line down the screen about 2 inches thick
HOPING THIS WILL HELP TO SOLVE THE PROBLEM....
Aug 06, 2011 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Thin blue vertical line left of middle on screen
Sounds like a faulty Plasma Display Panel.
Contact Panasonic and find out if it is still covered under warranty.
Please remember to rate my solution to show your appreciation.
Amardeep
For more tips visit my blog at http://thegeektweet.wordpress.com
May 28, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
PANASONIC VIERA 50", BLACK LINE COMING UP FROM BOTTOM OF SCREEN
this problem sounds like bad solider on the vertical IC chip.
re solder pins and should run fine.
Jan 11, 2009 | Televison & Video
We have a panasonic viera flat screen tv which has developed a vertical blue line that runs down the middle of the screen. any ideas?
sounds like it could be your flyback going out (cost around $70.00) for part if you replace yourself!
Dec 06, 2008 | Televison & Video
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic Viera TH-42PX80U Plasma TV Logo
117 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
