The code E20 is showing on my w/machine,whats the problem?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
E20 on AEG Elecrolux and zanussi is machine not draining efficently. blockages in the machine or drain can cause it. if your model has a filter or coin trap clean that out. or dismantle the pump to look for something jamming the impellor. may need a need pump.
Posted on Aug 06, 2010
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
Shows code E20, what does that mean?
From the manual, available here:
http://www.serviceforce.co.uk/pdfs/U26183.pdf
E20: problem with water draining
Try emptying the drain filter, normally at the bottom of the washer
Oct 12, 2010 | AEG L16820 Front Load Washer
What does e20 mean? The display shows an error of e20. Looks like the water is not pumping out during the regular wash.
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump.
Please post back for any further assistance.
Daniel
Jul 31, 2010 | Frigidaire ATF6000ES Front Load Washer
Error code E20
Hello there
the Dreaded E20 fault is a drain problem
washer will show the E20 code and may not spin.
So i would first look for a clog in the hose right before the water pump there is a little cup in the black hose that could be full of suff if so empty the cup and it should work good after this
hope this will help you out
Best regards Michael
Dec 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
E20 code. Not draining
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Jun 06, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Washing Machines Logo
147 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
