Question about Clarion Car Audio & Video
HEY I HAVE A CLARION 41EX THREE WAY CROSSOVER ITS OLD SCHOOL ON THE THE FRONT AND REARS THERE'S A INPUT AND OUT RCA BUT ON THE SUB THERE'S ONLY ONE RCA CURIOS HOW TO RUN THE RCA SHOULD I GET Y SPLITTERS RCA'S AND SPLIT THE RCA COMING FROM MY DECK TO MY MONOBLOCK ?
STP162
  • 132 Answers
SOURCE: how to wire in a cross over
You didn't say if it was active or passive, but here is both:
Passive crossovers are easy to install. By definition, the only type of connections they require are to your speaker line. They typically get installed between the end of the speaker wire and the speaker. Connection should be fairly simple, just like hooking up the speaker itself.
Now F-Mod crossovers modify the audio signal before it is amplified. They accept the patch cord from your receiver on one end, and then plug directly into the preamp inputs on your amplifier. They are also easy to install, and don't require additional wiring.
 An active crossover requires a little more work. You have to connect 12-volt power, ground, and a turn-on lead. The active crossover gets installed between your receiver and your amplifier. A lot of active crossovers have both speaker-level and preamp inputs, so they can usually work with either type of connection. The outputs will be preamp connections to your amplifier. Hope that helps.
Posted on Oct 22, 2007
LVT7857
  • 116 Answers
SOURCE: i have a kenwood head
No. I would recomend running front and rear to the crossover. Use the sub out on the deck so you have total control of subwoofer output at your fingertips. Your deck should have at LEAST an 80hz crossover built in. Any further fine tuning can be done at the sub amp.
Larry T
Winona Lake,IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
  • 306 Answers
SOURCE: 6 output RCA. 1 lable
yes the sub out on this radio is mono. but to feed you amp will require two rcsa so get a y adaptor to feed both inputs on the amp.
Posted on Feb 07, 2010
vetteman3002
  • 2299 Answers
SOURCE: When i connect rear speakers
Either you have the back speakers hooked up to the sub woofer output channel on the head unit. Or your amp has a built in crossover. Not letting the higher frequencies get to the speakers.
Posted on Nov 05, 2010
  • 147 Answers
SOURCE: hi i trying to figure out how to wire up my rca's
The "Front output" from the Pioneer deck would connect to the "Main In" on the Clarion EQ. I'm assuming that your Clarion EQ can only deal with one input, and will send the adjusted (equalized) signal out both of the outputs.
The "Front output" from the Clarion EQ should go to the "Front Input" on the 4 channel amp.
The "Rear output" from the Clarion EQ should go to the "Rear Input" on the 4 channel amp.
The "Sub output" from the Pioneer deck would connect to the Left/Right Input on the Epicenter. The Left/Right Output on the Epicenter would need a Y-splitter for each side, so that you could connect each amp separately. One suggestion would be to use one sub amp for both subs.
Posted on Mar 07, 2011
I have a true sunfire sub and an onkyo 703 that has an rca connection for the sub. My question is do I connect my side channel polk 65's directly to the sub in jacks or directly to the reciever? If
The input jacks on the subwoofer panel are for connection of satellite speakers to it's crossover. The outputs are for the crossed over signal input to your receiver or amplifier, as there will be no amplification or channel processing from the subwoofer connection. It's only an optional crossover that may have a sonic advantage over the crossover in your receiver.
What you also can do is connect the speakers directly to the 703 and set the crossover frequency on it.
Dec 07, 2011 | Sunfire True Sub MK II Subwoofer
Trying to wire two amps to cmd3 unit. is the best way to just "y" off one of the rca jacks
It depends on what you are going to use the amps for. If you are adding just speakers then yes, but if you are adding subwoofers, I would suggest a crossover. It will allow you to have high, mid and sub output with one input. Good luck.
May 14, 2011 | Clarion XMD3
Does this unit have RCA line out jacks......
According to the specifications on the Clarion website it has:
  • 4ch/2V RCA Output (Front/Sub)
    So in answer to your question I believe it does have RCA line out.
Mar 07, 2011 | Clarion DB285USB Car CD/ MP3 Player
Hi i trying to figure out how to wire up my rca's i have a pionner deck in on the back of it it has front output,rear output,sub output ,and also a audio output .now im trying to up it to a clarion eq that...
Feb 18, 2011 | Clarion Car Audio & Video
I've problem getting any Sub sound from Sony STR DB840. The sub is ok and I've correct setting on my reciever with sub enabled. When performing tone test... I can hear sound from all connected speaker...
make sure sub is working .Power it up , remove sub RCA jacks from receiver .Gently tap on RCA with fingers.You should here a hum when touched .You can also try audio from TAPE REC OUT .If you dont get audio .Check setting at sub .If it working okay check setting at receiver and or sub level at receiver
Jul 20, 2009 | Sony STR-DB840 Receiver
Alpine CDA 9827 using aux mode with ipod shuffle via rca inputs
Unfortunately, the rca outputs are to control an amplifier or crossover. They do make an ipod adapter for that radio, which allows you to control the ipod through the radio. Best Buy or any Alpine dealer should carry something for around $25.
Jul 05, 2009 | Alpine CDA-9827 CD Player
I have a kenwood head unit with 3 rca outputs,front,rear and sub.my crossover is a kicker kx3 and it only has front and rear in and front,rear and sub out.my question is how do i hook up the crossover...
Larry T
Winona Lake,IN
Jan 28, 2009 | Car Audio & Video
How do i connect an HU JVC KD-AVX1 to a Clarion EQS746?
use the front pre out from yur radio. and fade on your radio all the way to just the front. as if you were trying to only hear music from your front speakers.
Feb 07, 2008 | Clarion EQS746 Equalizer - 7-Band In-Dash...
Car Audio & Video Logo
149 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
