Question about Acer Computers & Internet
Hello. five minuets a go.. i go to update my BIOS.. and my Notebook willl rebot until the BIOS update is finished.. then.. my Notebook not Turn ON again.. Please Reply me ASAP. Thank's
    President:
  • 2,571 Answers
If you fail to update the bios, you may be left with a broken, unrepairable worthless laptop.
There are a few guides available on google, depending on your laptop make.
look here at the first result in the list. You may just be in luck :)
http://www.google.co.uk/search?hl=en&q=failed+laptop+bios+update&meta=
Posted on Aug 06, 2010
Bios update failed.. Now all i get is 8 beeps and no display? Any solutions?
Hello,the only way to fix this problem is to prepare original bios file at your USB stick.But first you need to made this USB bootabile(put some universal BIOS fasher software from internet),than put the original file (bios)inside.when its finished try to find another PC (correct),pick up your BIOS chip,(the case of BIOS must be the same as another correct PC!!!!!!!!! IT IS VERY IMPORTANT),than turn on correct PC,run bios ,set USB stick as 1st bootabile device,save changes and restart PC,after that you will see universal Bios mask,you have choice to run bios file you already put on USB stick,DO NOT START FLASHING BIOS!!!!! PICK UP THIS BIOS CHIP FROM HIS CASE,THAN PUT YOUR BIOS CHIP (CHANGE CHIPS UNTIL THIS PC IS STILL WORKING)press enter and this PC will flash your BIOS with correct file.When its finished TURN OFF THIS PC(dont restart).Pick up your bios chip,and put it on your moterboard place for Bios,also put the bios chip from regular (correct)PC to its place,and you are finished.start PC you are using to fix problem ,just to check everything's OK,THAN TURN ON YOUR PC,IT MUST BE WORKING,9its look like risky job but dont worry its ok
I already fix lot of this problems,only check-dont short pins of chip,or turn chip at wrong direction,best luck :)
Dec 16, 2013 | HP Pavilion 1214 QW701AAR Refurbished...
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
My Dell Inspiron 1545 keeps freezing. It doesn't respond and I need to power it off. This happens once every hour of use.
It is very possible you have malware infecting the systemm. Get the download below, install and update. Then when the program starts, perform a quick scan, let it run and when the scan is finished, hit the show results button and then delete all that it finds. Then rebot the machine.
http://www.filehippo.com/download_malwarebytes_anti_malware/
Dec 17, 2009 | Dell Inspiron 1545 Notebook
I need to resore the bios on a Satellite NB A135-S4467
This sounds more like a windows problem than a bios issue. I only do a bios flash as a last resort or if there is new features that I need.
May 04, 2009 | Toshiba Satellite A135-S4527 Notebook
Bios update
Hello!!
I am not sure after installing which update the display has gone. I mean Windows update or HP software update or BIOS update.
Let me take the senario of the BIOS update and assist you in this regard.
If the display has gone after installing the BIOS update, then the issue cases are 1. Installed wrong BIOS update 2. Notebooks might have restarted or hanged while installing the BIOS update.
In both the cases BIOS will get currupt and there will be no display on the notebook.
Solution for the issue is: If you notebook is under warranty, HP will arrange for mail-in repair, plss contact HP. If the notebook is out of warranty, then you need to contact HP authorized service center.
Aug 07, 2008 | HP Compaq nx7300 Notebook
Laptop froze when trying to download Bios
The bios is a very touchy thing, if you screw them up you will have a door stop. Reboot the computer and start the bios update again. This time download and save the bios update to the hard drive and then run it from there. You should never run any type of bios program from the internet, you should ALWAYS save or burn to disc, then run. The internet is entirely to unstable for such an important update, if there's a glitch or loss of connection, even only for a millisecond, it can ruin your machine. If you cannot reboot and finish the update, get back to me and i'll see if I can get you through this.
Jun 25, 2008 | Toshiba Satellite A105 Notebook
Losses charge really fast
The computer should work, long enough until recovery completes and BIOS updated, with mains power plugged in, and the battery may need to be replaced.
May 16, 2008 | Toshiba Satellite A75-S226 Notebook
Hello
turn on the computer Press F2...that opens the bios setup screen...
Mar 24, 2008 | Compaq Evo N610C Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
