Question about Dell Dimension 4600 PC Desktop
My dell dimension 4300 displays when starting up an alert message appears saying, "previous attempts at booting this system have failed at checkpoint [vcls] Keyboard failure
    Champion:
  • 219 Answers
Make sure you keyboard is plugged in well. If that doesn't help try a different keyboard.
Posted on Aug 06, 2010
Alert sound dimension
Please do a fresh install or try to use System Restore to go BACK before this problem happened.
Jun 08, 2013 | Dell OPTIPLEX GX240 P4 1.8GHz 512MB 20GB...
My dell 4600 says several previous attempts at booting have failed at checkpoint (rst)
sheila_barnu,
This error could very well be a motherboard failure. I found a Dell Community Forum link to where the resolved the error. Click the link below view.
Dimension 4600 Error
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 17, 2013 | Dell Dimension 8400 PC Desktop
How do I fix this error "Previous attempts at booting this system have failed at checkpoint USB0?
go into bios and disable usb ports it should tell you while its booting up what key to press to get there like f1 or f2
Dec 08, 2012 | Dell Precision Workstation 670 PC Desktop
Can not boot the system
if u realy want to make ur PC facotry fit....
visit my site
www.sureshayyar.110mb.com
Format Disk page
all detailas and necessary tools are available for download
Feb 05, 2010 | Dell Dimension 8400 PC Desktop
[Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Apr 27, 2009 | Dell Dimension 8400 PC Desktop
My dell dimensions 4600 will not boot
Dont worry.This can be resolved.Goto the BIOS by tapping the F2 key on the restart -Goto the option which says Maintainence>>Event log>>Clear all even logs -Now press F10 to save and exit or press the ESC key just once and Select SAVE and EXIT
Mar 17, 2009 | Dell Dimension 4600 PC Desktop
My dell dimension 8400 bios a03 fails to bootup and displays this alert on the screen: Many attempts to boot the system have failed at checkpoint [Ithr]. how can i recover from this?
You need to reset your bios settings. Open your case and remove the cmos battery for 10 minutes. Caution: unplug all ac plugs before you open your case. put the battery back in and turn it on you should see an error message saying: you need to set system time and date. If you see this then you have successfully reset your bios settings and the defaults should load up. follow the instructions to change your time and date settings and save. reboot and hopefully you can boot up. I hope this works.
Mar 09, 2009 | Dell Dimension 8400 PC Desktop
Can't Do Anything... NEED HELP!!!
"Alert previous attempt at booting the system has failed at checkpoint emem {EMem}."
This is a No Post issue and if youre going to check the quadpack it will show yygg which indicates memory failure.
Quick Step : Reseat memory
If cust has more than 1 memory, test each memory on each slots until you find the memory that’s causing the error message and send a replacement for the faulty memory.
May 19, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
566 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
