Question about Miele Touchtronic G892 Built-in Dishwasher
What should I do to start my miele touchtronic ... the intake light is on and I cannot start the dishwasher. Thanks
  • Miele Master
  • 12,061 Answers
Http://www.miele.ca/miele/canada/OperatingInstructions/manuals.asp?ParFolder=Dishwashers&SubFolder=Previous%20models
Above is your link for your user manual. you need this to perform the troubleshooting steps. Below is a website that will show you how to troubleshoot and isolate your issue if that "Fix" I included doesn't work. it is not a panacea for all ill's but it is surprising how many times it works..
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method
Posted on Aug 06, 2010
Intake/Drain light is on, some water is at the bottom of machine, not draining
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | Miele Touchtronic G894 SC Built-In...
Drain intake indicator flashing. We have cleaned all but the intake filter. How do you clean or check to see if cleaning is necessary of the intake filter?
After cleaning the drain, looking at the intake (no filter on ours) and the light wouldn't go off, I just decided to take the ctrl-alt-delete approach and hit all the lower four buttons all at once, bingo, it cleared the light and machine started.
Sep 25, 2009 | Miele Touchtronic G892 Built-in Dishwasher
Miele Platinum dishwasher: Can't get past the intake/drain step
It could be that the drain pump or the non-return valve is clogged. Refer to the manual about how to check the non-return valve. It is under the "Maintanence" section. Here is a link to it:
https://www.miele.com/pmedia/ZGA/TX2070/9953540-000-02_9953540-02.pdf
Nov 03, 2017 | Miele 24 in. Touchtronic Platinum Built-in...
Miele intake light on since new sink,disposal installed
check and see if the disposer drain port plug was removed. intake/drain light means slow drain or no drain
Feb 04, 2009 | Miele Touchtronic G892 Built-in Dishwasher
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Drain light is on and program stops
clean your waster water output pipe,back side of your dishwasher.
This often gets full of food.
Aug 09, 2008 | Miele Touchtronic G892 Built-in Dishwasher
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Miele Touchtronic G892 SC Water leak at base of door
check the rubber seal around the door to see if its torn or smashed. if it is replace it, could someone have set somthing heavy on the door while it was open that would have stressed the hinges. it is most likely one of these problems take a nail file and slid it gently between the door and the body of the dishwasher if it slides in easy where it leaks you know the seal is bad and replace it.
Dec 09, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele Touchtronic G892 Built-in Dishwasher Logo
48 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
