Question about Logitech diNovo Edge 9676850403 Keyboard
I have the DiNova Edge wireless keyboard. It stopped working. The cursor won't even move. I think something may have happened to the settings during the last Windows update (I believe the operating system is Vista). Any idea how I can troubleshoot?
  • 6,784 Answers
HI. Normally when this happens, it will be due to a weak battery or failed sensor that links your wireless keyboard to the CPU(USB sensor module). If you are certain that your batteries are fresh and the sensor is connected to the CPU and working, i wound advise to back up your PC to a previous date before you installed the latest update. The new update may have scrambled the necessary driver needed to control the keyboard and sensor, but i would rule out bad battery or failed linking sensor module first before backing the CPU up in system recovery.
If you are forced to back up the system to a previous date, i would recommend to back the system up about 6 days. All back up options are located in the system recovery sections of vista.
Posted on Aug 06, 2010
I have a uniden wireless mouse and it won't
here ur pc is recognizing ur external hardware that is mouse but cursor is not moving this indicates that bluetooth connection is good and problem comes with the mouse. i advise to meet a good technician and there is nothing to do with it further.
Jun 28, 2013 | Computers & Internet
I'm using a sony vaio Core i7 with Windows 7. While writing something suddenly i found the cursor have moved somewhere else from where i was writing. Can anyone please help?
It could be that your hand accidentally hit the touchpad while you were typing, which would have moved the cursor. I've done this a few times before, so I'm fairly certain that's what happened. The cursor won't move on its own unless someone is controlling it, and it's highly unlikely that you have a trojan or a virus that is doing that.
Hope this helps!
Aug 25, 2011 | Sony VAIO VGP-WKB1 Keyboard
Mouse/cursor works fine on PC but disappears when watching recorded TV using windows media center. model KB3800TPW
Usually when watching something on your computer in full screen the cursor will disappear. If it comes back when you move the mouse then you have nothing to worry about.
May 03, 2011 | Gear Head WIRELESS keyboard/Mouse
Cursor stops moving and i have mess with battereis to get it going
1st check to be sure the batteries are BOTH good.
Power light on does not always mean there is enough to do the job.
2nd if the contacts are loose then slightly pry the contact out a little.
I do mean just a little! All your trying to do is make a better contact.
3rd make sure the batteries AND the contacts are clean!
Any corrosion or dirt/dust may momentarily cause the batteries to disconnect. Once this happens the cursor stops. No power, no cursor movement is possible.
Oct 03, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Ie goes crazy
Dynex is a cheapo brand that usually can be found at Bestbuy. I would not recommend the dynex products at all. You could be getting interference from cell phones, your monitor, a microwave oven, etc.. I have a couple wireless mouse and keyboard sets I got at radioshack that work very well. They only cost me about 20$ and are the Labtec brand.
If you want something a lot better go for logitech products, they are a bit more pricey though.
Sep 12, 2009 | Dynex Multimedia Keyboard
Cursor and pages opening up off the right side of my desktop
This is a monitor setting. use the menu button on your monitor to shrink the screen size from side to side. The menu button usually toggles you through the settings and the + or - buttons adjust the settings.
This happens a lot if your on a small desk and bump your keyboard against a low sitting monitor.
Regards
Mar 24, 2009 | Computers & Internet
Magnifier doesn't work
Try going to Control Panel and click on the mouse icon. Then the mouse properties will appear showing the mouse. In the left column,move your cursor over the right side button click on the drop down and select magnify. Hopefully it will now work.
I had to move the magnify function to the left button because it was to sensitive on the right.
Nov 27, 2008 | Microsoft Wireless Laser Mouse 5000
Microsoft Wireless Laser mouse 5000
hi i have exactly the same problem i can click on things but cant move the cursor i have tried changing the batteries and tried fixin drivers but it tells me the mouse is working fine?
Oct 20, 2008 | Microsoft Wireless Laser Mouse 5000
Wireless Mouse and keyboard stop working (cursor dissapears)
Your keyboard and mouse maybe using a power saving setting try re-establishing the connection between the keyboard, mouse and the computer. If this helps I'd would really appreciate a FixYa! rating if not please don't hesitate to contact me and I will assist you furthur. Have A Good Day!
Oct 13, 2007 | Dell Wireless Keyboard Optical Mouse w0147
Connectiong Problem
check for pair devices and delete the keyboard pairing which is oldest and also delete all the pair devices for a single time.
then switch on your bluetooth select the device and pair it . if still not work then reinstall the bluesoleil and install it again this may fix your problem.
if helpfull rate this.
Oct 17, 2006 | Logitech Dinova Media Desktopuk...
Logitech diNovo Edge 9676850403 Keyboard Logo
57 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
