Question about Toshiba A70-S256 Notebook
How do you replace the power jack socket? - Toshiba A70-S256 Notebook
    President:
  • 2,571 Answers
Its not something the average person would try.
You need to open the laptop, Un solder the existing power socket, and then resolder the new power jack, you may only need to resolder the old power socket.
You may need access to to underside of the motherboard, so you may have to fully remove it.
If you make one mistake with the soldering iron, you could completely destroy it.
Here is a step by step guide to replace it, if you do wish to try.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Posted on Aug 06, 2010
  • 734 Answers
I'm a laptop repair specialist. The DC Power Jack is soldered to the motherboard. While I am able to do this repair I no longer take the trouble because there are many vendors on eBay who perform the service for half, or less than half, of what I'd have to charge a customer.
Go to eBay and in the search window type in "Laptop DC Power Jack Repair". You will be re-directed to a page with many choices of vendors where you simply send them the laptop and they return it repaired. You should expect to pay between about $85 to $125 including all shipping.
Take care,
TheSelkie
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
Dec 01, 2010 | IBM ThinkPad T41 Notebook
Where i can buy, power socket for my amilo pro v2010?
Just one example,
http://www.laptopjacks.com/view_part/For-Fujitsu-Amilo-Pro-V2010-DC-Power-Jack-FJ41420.html
The power socket in the laptop that the AC adapter (Charger) plugs into is a DC Power Jack.
Type Amilio Pro V2010 DC Power Jack in your browser search bar, press the Enter key.
To add:
Nov 07, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
How do I replace the DC power Jack socket on my ACER Extensa 5620 .Mosel NO MS2205
Here is a place to buy a dc jack for the motherboard:
http://www.buy.com/prod/ac-dc-jack-power-port-connector-socket-for-acer-extensa-5220-5420-5620/q/sellerid/23962916/loc/101/215782024.html
This video will show you how to replace dc jacks in a laptop:
This page has the service manual for your laptop:
http://www.scribd.com/doc/13062016/Acer-Extensa-56206419-Service-Manual
Sep 22, 2010 | Computers & Internet
Battery not charging !!!. replacement of new batter also has the same problem. and old batter suddenly started charging by meddling with the cable for once. and then again the same problem. would it be...
Looks like either the power jack of your adapter is experiencing a bad connection. Check if the power adapter's cable near the jack which plugs into the laptop is not severely bent.If this is the case, then you will need to replace the power adapter.
If this is not the case, check the DC socket where you plug the power jack into the laptop. This socket might be loose or broken. If this turns out to be the case, then your laptop needs to be disassembled in order to re-solder or replace this socket, depending on its condition.
Aug 28, 2010 | Dell XPS M1530 Notebook
How do I replace fujitsu 2727 power socket
Get it fixed by going to jackfix.com , replacing the dc power jack requires taking apart the entire laptop, then removing the motherboard, and finally desoldering the power socket, and resoldering the new jack, and putting everything back together, its no job for a beginner. Not being rude at all, but if you have to ask how, dont attempt. http://www.jackfix.com , they have replaced many power jacks for my laptops, as well as my companies, they give a lifetime warranty, and will ship the laptop back to you within 24hrs. believe me, I have tried different companies, and they are def best.
May 11, 2010 | Fujitsu AMILO PC Laptops
Power socket is loose
dc jack socket for Sony VAIO VGN-FW is very easy to loose, I think you can replace the cabled dc jack, no solder work, plug in and work, see this reference page: http://www.lapdiy.com/sony-vaio-vgnfw-series-power-jack-port-connector-dc-in-cable-p-2647.html
the above item is with ground cable, it is known that sony FW uses both harnesses with or without ground cable, you can cut the ground cable directly if your laptop does not use it, or order from this page for the one without ground cable: http://www.lapdiy.com/sony-vaio-07300012492a-power-jack-port-connector-dc-in-cable-p-2782.html
hope this can help you
Feb 04, 2010 | Sony VAIO FW Series VGNFW275JH
Power socket for sony vaio is broken how do I
On a Sony, many times the power socket is a separate piece that can be replaced. Unlike many laptop motherboards, these power sockets are a separate item the plug into the motherboard. \
Bad news is you have to dissassemble the computer to get at it.
Dec 22, 2009 | Sony VAIO FW Series VGNFW275JH
Hi i asked for my ibm t40 laptop dc jack to be replaced and i have looked in my profile but all i can see is dc jack for a printer my problem is changing the dc jack on my ibm t40 LAPTOP
Problem with power socket on the laptop, it may caused by a dry solder joint and needs to be resoldered or the power socket may be faulty and needs to be replaced. Either way to fix this, it requires the laptop to be dismantled to get at this power socket. Get a quote to repair, as it could cost a few dollars.
If it is a faulty cord/plug on the power adapter, this can be checked with a multi-meter. When you connect the multi-meter probes to the power plug the voltage should be steady and the reading should be slightly higher then the voltage that is printed on the label on the bottom of the power adapter. If the voltages fluctuates as you wriggle the plug then you have a broken wire in the plug. Replacing the plug would not cost much.
Jun 20, 2009 | IBM Computers & Internet
I need to replace AC Power Adapter Socket, Where do I find this to purchase??
you may check follow website find your laotop DC jack and chose a good price one.
http://shop.ebay.ca/items/__HP-Compaq-V2000-DC-jack_W0QQ_kwZHPQQ_kwZCompaqQQ_kwZV2000QQ_kwZDCQQ_kwZjackQQ_ckwZPresario?_trksid=p3286.m104.l1199
how to change the DC jack:
please reference the manual page 3-1, to disassemble all covers.
and replace the DC jack.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00444244/c00444244.pdf
hope help you fix it.
May 19, 2009 | HP Compaq Presario V2000 Notebook
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Toshiba A70-S256 Notebook Logo
133 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
