Kenwood AR 404 burning w/ open flame.
I dusted off an old Kenwood receiver, plugged it in and nothing but the standby light came on after repeatedly pressing the power button. I took the paneling off and found that the 6.3AL 250V fuse was blown. Replaced the fuse, plugged the unit back into the wall and the damn thing burst into flames in some random spot on the main circuit board. The new fuse was blown, too. I replaced the 2nd fuse. Near where the fire happened, I found some adjustable nobs and turned them using trial and error. adjustment found a spot for the nob that prevents the fire from restarting when I plug the receiver back in. So now the LCD and everything is coming on for about 10 seconds and then shutting down. The standy light starts flashing. Can you help?????
Danny
Knoxville, Tennessee
You are literally playing with fire. Obviously the unit is in dire need of service! Please, take unit in for check out by a pro/tech
Posted on Apr 27, 2008
The pilot light will not stay on for more than 5min. If I light the fire when its on,it just goes out. The fire is a Fusion 2/7
I assume this is a gas log? If so, you have dust in your pilot assembly. Turn everything off and let it cool. Note the opening where the pilot flames burns. Use the wand from your vacuum cleaner and place it over the opening for the pilot flame. Gently tap the side of the pilot assembly while holdign the vacuum above the opening. This will lift the minute dust particles out and allow the flame to burn nice and blue again. These logs have Oxygen Depletion Valves on them. The pilots are very sensitive to dust.
Jan 18, 2011 | Heating & Cooling
Hook up for an AR 404 receiver
Copper is positive, aluminum is negative. OR One of the wires should have a white (or black) stripe on the insulation...this is negative wire. OR If using 18 gauge extention cord wire, the positive wire will have small grooves running the entire lenght (very difficult to identify, unless you have good eyesight) Hope this helps.
Jun 11, 2009 | Kenwood AR-304
I have an old Kenwood receiver that does not power up anymore. Not even the red standby light glows. I have power to the unit but that is it. I have checked the fuses on the inside but after that I am no...
If the voltage was 110, the polarity should not have made a difference. In all probability, the input power transformer has an open primary. This can happen with a power surge or just because of age. If you have an Ohmmeter, with the unit unplugged, measure across the 2 input pins for the main transformer. It should read about 3 ohms or less. If it reads infinity, it is open and must be replaced.
Keep us posted,
Dan
Mar 12, 2009 | Kenwood Audio Players & Recorders
Kenwood VR 208
It works sometimes, mostly the volume bottem
Nov 26, 2007 | Kenwood VR-506 Receiver
Kenwood VR-307 Receiver standby light blinking
Hello, sorry to say this, but there is a hardware error. Possibbly something is wrong at the output stage. Please send it to tech for a repair. But first disconnect the speakers and then try to turn it on. If there is no change the error is still present. Best regards. Arpi
Jul 17, 2007 | Kenwood VR-307 Receiver
320 people viewed this question
 Grubhead
Grubhead
