Question about Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
My dc05 gathers dust and pet hair in the filter at the top of the cylinder and does not pass into the cylinder. I have replaced the filters and the sponge.
You have lost the rubber insert at the bottom of the canister. The bottom of the center cone normally fits into this and blocks the bottom of the cone. It would have fallen out when you emptied it.
Posted on Oct 01, 2010
Filter keeps clogging up ie what gets picked up goes into the filter not cylinder?
Hi there, it's Jack at Dyson.
I'm confident I know what the issue is here - it sounds like you may have accidentally discarded the bin inner when emptying your machine. Without this in place, dust and debris will pass through the system and onto the pre-filter, rather than being separated from the airflow and captured in the clear bin.
The bin inner is the coloured cylindrical plastic section with a black rubber seal, which usually sits inside the clear bin as shown here:
If you've recently emptied your DC05 it's worth checking to make sure the bin inner hasn't fallen out. If you can retrieve it, it should simply push firmly back into place inside the clear bin.
It's also a good idea to wash both parts of your machine's washable pre-filter, as it may still contain dust even if it looks clean on the outside. Use cold water without detergent, and allow at least 12 hours for both parts of the filter to dry completely before replacing it in the machine:
I hope this helps. If you need any further guidance you're welcome to give the Dyson UK Helpline a call on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
Mar 06, 2015 | Dyson DC05 Cylinder Bagless Canister...
Filters
Step by step filter washing instructions can be found in the support section of our website.
Please visit http://support.dyson.co.uk/support/dc05/dc05-standard/how-to-use-your-dyson-vacuum/wash-the-filter/filter-washing-video to learn how to wash your filter and for more information on maintaining your DC05.
If you need further assistance please call our Helpline free at 0800 298 0298.
Best wishes,
Jessica
Feb 16, 2012 | Dyson DC05 Cylinder Bagless Canister...
Why does my filter collect so much dog hair and decreases the suction of the machine. I clean and change (alternate) filters everytime I vacumn, that isn't normal, is it? It seems like I have a seal or...
You obviously have a pet and it's good to see your machine is doing it's job. The only reason you could lose suction while collecting pet hair is due to the pet hair being a solid mass and air not been able to flow through the filters.( must be a lot of hair). Suction loss is only when the particles passing through your machine are dense therefore it will reduce suction and airflow . Very common on vacuum cleaners. Do not worry too much . Also check to see if you have Amy cracks in the seal between the drum and the vacuum cleaner itself
Jul 15, 2011 | Dyson Vacuums
I purchased a Dyson DC05 cleaner from a garage sale.The suction is great,however I noticed that the debris does not swirl around in the cylinder when I am vacuuming.I think the suction could be even...
Hi there VacuumGuru from Vacuumspot.com.au here. You will find there are 2 reasons will not spin in a dyson DC05. 1 is that it is missing one of the 2 parts in the dust container, there should be an upside down funnel in there and a rubber boot on it. Without those dust just goes either to the bottom of the bin or to the filter. The 2nd cause is that even though the filters have been cleaned they are simply too old. When you hold the washable filter (the one with the plastic outer and the foam insert) up to the light and take out the foam bit you should be able to see light through the filter. If not you are probably only running on maybe 80% suction which still works but isn't as good as it could be.
The filters are available here if you need them.
Hope this helps! :)
Oct 06, 2010 | Dyson DC05 Cylinder Bagless Canister...
My Bissell will not **** up pet hair or dirt
Dirt hair and such will build up in the hoses of that vacum. Take them apart stretch them out and run something through them to make sure they are clean.
The other problem is the filter in the bottom of the cup. At least on some models there is a filter that gets totally pligged with dirt and dust. Take it apart, wash it out and them put everything back together.
Heatman101
Mar 21, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
Dyson animal vacuum 07 --5 years old no suction
the only way to fix the problem is to clean out the motor filter that's inside, the filter is around the motor and they don't do replacements for this part, as its not accessible by normal use, you need to remove all the case screws and disassemble the hole case, this site may help you https://manchestervacs.co.uk/DysonForum/index.php?topic=76.0
Jan 08, 2018 | Dyson DC05 Cylinder Bagless Canister...
How many filters does Dyson DC05 has?
The DC05 has two filters.  In terms of air-flow through the machine, one sits between the bin and the vacuum motor, the other is after the motor and is effectively the exhaust filter. The one that's missing on your machine is the first filter - it consists of a blue foam disc contained within a yellow surround (the base of the surround has additional filter material built in to it). Both components are washable (but be sure everything is absolutely dry before re-installing after washing).  The filter you can see under the bin is the second (HEPA) filter. This one is usually quite long-lived but, if your machine has been used without the first filter in place, the HEPA filter almost certainly needs replacing too.  The machine should never be used without the first filter in place, as that will risk serious damage to the motor and will certainly shorten its life.  Incidentally, user manuals can be downloaded from dyson.com.
Jun 05, 2009 | Dyson DC05 Cylinder Bagless Canister...
Dyson DC05 problem with filters.
First, and for sure, the problem is in the collection unit (CU), not the filter.  Is it possible that something is missing from the CU?  When you remove the CU to empty it, and you lift off the top, a conical yellow part remains attached to the inside of the lid; another yellow part remains in the bottom of the CU, with a big black rubber seal on top.
I think the problem you describe will occur if that black rubber seal is missing, displaced or damaged (perhaps it dropped out with the dirt and you didn't notice).  A healthy seal between those two yellow parts inside the CU is essential.
Please rate my response if this helps.  If it doesn't help, also let me know and I'll think again.
Apr 18, 2009 | Vacuums
Dirt and hairs not going into cylinder
It's not the filter that's the problem.  Air should go first to the cyclones, then to the filter, so the filter catches only those finest dust particles that are not trapped in the cyclones.  The most likely cause of the problem is that the cyclone pack is not properly seated, with the result that at least some of the dirt-bearing air is going directly to the filter rather than passing through the cyclones first.
Apr 18, 2009 | Dyson DC11 All Floors Bagless Canister...
Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum Logo
334 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
