Question about iLO (2 GB) MP3 Player
Will not turn on
My ilo will not turn on. The screen does not light up. I check batteries and if it will still transfer music from my computer. Both are yes! It is unlocked. I did try to turn on and listen, just in case the screen was out.
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
I am trying to sync my ilo mp3 player to my windows media player. I hooked up my USB cables and turned on my player and my computer does not recognize my device. What do I need to do?
HERE IT GOES. YOU HAVE TO GO THROUGH MY COMPUTER R ATHER THAN USE THE WINDOWS MEDIA PLAYER. I HAD THE SAME ISSUE. OPEN YOUR LIBRARY FIRST. THEN GO TO MY COMPUTER. PLUG IN YOUR DEVICE THIS WILL ADD YOUR E DRIVE TO MY COMPUTER. YOU THEN CAN CHOOSE ALL MUSIC OR INDIVIDUAL TRACKS. DRAG YOUR MUSIC TO THE E DRIVE. RIGHT CLICK THE E:DRIVE. THIS SHOULD TRANSFER YOUR MUSIC TO THE E DRIVE. I BROUGHT MINE TO MY FREIND AND THIS HOW HE SHOWED ME.
Jul 02, 2009 | iLO (2 GB) MP3 Player
It doesn't work the same
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
May 17, 2008 | iLO (2 GB) MP3 Player
Will not turn on
jst ******* people
May 01, 2008 | iLO MP3 Player
Won't read music
Check and make sure that the format you are trying to play is compatible with the player. For instance, iTunes files won't work with this player.
Also, you could be trying to load DRM-protected files from a service like Bearshare. Yuur screen will tell you the files are transferring, but they are really not transferring b/c they have DRM protection. There is not currently a free way that I know of to remove this DRM-encryption, although you can probably buy download rights from your music service.
Unfortunately, the ILo site is down, so their is no way to get a firmware upgrade in case this model is another victim of the Windows Media Player upgrade - WMP 11 messed up a lot of mp3 players regardless of manufacturer.
Mar 14, 2008 | iLO (2 GB) MP3 Player
What music service works with the ilo mp3 player?
Try Lime wire or rip music from a cd to a windows media player then syncronize ur ilo to your computer and transfer!
hope i helped
if you need to know where to get lime wire for your computer then go to
Limewire.com its free!
--sara
Jan 11, 2008 | iLO (2 GB) MP3 Player
Donot know how to work it
-Plug in your mp3 player
-Go to your folder with all your songs 'My Music' and find your music files.
-Either select all your songs, open them with 'Windows Media Player' and transfer them that way.
-Or 'Open My Computer' then open 'iLo' and drag the songs from where your songs are located [My Music] to the 'Music' folder in your iLo folder.
[MyMusic] Song.mp3 >drag to> [MyComputer/iLo] Music.
Please rate
Dec 27, 2007 | iLO (2 GB) MP3 Player
Can somebody help me?
-Go into your downloading program, select a song and go 'Locate file/Open Containg Folder', you should be in your folder with all your songs. or go 'My Music' and find your music files.
-Or 'Open My Computer' then open "iLo" and drag the songs from where your songs are located [My Music] to the 'Music' folder in your iLo folder.
MY ilo mp3 player will not start unless it is connected to a computer.
i fixed one recently that wouldnt turn on like yours, a part on the inside broke off and i resoldered it. if you dont mind, you might open it and have a friend whose good with electronics look around and see if anything is loose, disconnected, fried
Sep 30, 2007 | iLO (2 GB) MP3 Player
Ilo mp3 player won't turn on
Do you have music on it? Maybe its playing something, and it just turned off the screen.
Aug 25, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
21 people viewed this question
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
Allen Benge
Level 1 Expert
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
