Ac unit ran for 4 hours and the temperature reading on thermostat stayed the same so it wasnt registering the temperature in house is it a faulty thermostat
    President:
  • 3,773 Answers
Get a thermometer and check it against the thermostat
This should give your answer
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 06, 2010
Ford bantam rocam 1.6i 2006 temperature high but water is not boiling. Is one of the sensors faulty and where is all sensing units installed?
you might have an air lock in the water system.
start the car leave the cap off put you bower on hot and leave for 10-15 mins if should get the air lock out
Apr 19, 2014 | 2006 Ford Bantam 1.6i
I cannot get my wintair room air conditioner to stay on! It keeps cutting on and off, going from fan to air conditioning. Need help!!
It sounds like your air conditioner is doing what it is supposed to do. The compressor kicking in and out is an energy saving method of using the ac. When the thermostat (ball attached to evaporator coil) registers the set temperature the compressor kicks off.
Jun 28, 2010 | Heating & Cooling
My temperature gauge is not registering and my check gauges light comes on when im at a stoplight.when im driving the oil pressure is fine but when i come to a stop or idle the check gauges light blinks on...
A faulty temperature sending unit. It should be located on or near the thermostat housing. If any of your gauges reads zero, the check gauges light will come on. Sometimes even if the fuel gauge gets too low, it will trigger the light. It may be the connection at the sending unit. It may have become loose so wiggle it and make sure it is securely connected to the sending unit. If the temp. gauge needle pegs at the top of the gauge, it means the sending unit has grounded out and is faulty. If it jumps, reads off or not at all it could be a faulty sender or a bad connection.
May 26, 2010 | Chevrolet 1500 Cars & Trucks
Fuel guage & water guage are not working properly the fuel guage reads ful then will go to empty after you drive it for awile - the water guage only goes up to a quater
The gas tank sending unit has a float on it to register the amount of gas in the tank. The float is probably faulty which will cause erratic readings and is a fairly common issue with some GM units. Replacement of the sending unit should resolve that issue. As far as the coolant temperature gauge, it could be a faulty temperature sending unit or a thermostat that is stuck open or someone removed the thermostat. This will cause the engine to never reach operating temperature which in turn makes the engine run rich and can clog cat. converters and destroy some sensors.
May 08, 2010 | 2001 Chevrolet Venture
I am renting a house which has a Trane heat pump
If it is a heat pump it may not have enough oomph.
Oct 20, 2009 | Amana PTH123B25AJ Heat Pump Air...
When i was fixed a problem in central ac trane i found decreased in freon r22 and the suctione line was freezed, i charged the ac with froen gas r 22 then i found that the suctione line changed and begin...
You are still low on freon. Charging AC by superheat and subcool
First charging a unit by superheat, this is only for Acs with an orifice or capillary tube.
Optimum superheat is 12° to 15° at the compressor or suction line outside the unit.
Hook up your gages and put a thermometer on suction line (large line), start the AC. Measure the temperature of the suction line and read the pressure on your gages. Theres a temperature scale on your gages for R-22 or R-410A the needle will show you the pressure on the outer scale and if you follow it down to the R-22 or R-410a inner scale that is the saturation temperature for that refrigerant, (you can also use a temperature pressure chart), now read the thermometer, let’s say the suction temperature( the thermometer) is 67° and the saturation temperature (the gages or temp. press. Chart), is 55°, subtract the saturation temperature from the suction temperature, 67°- 55° = 12° superheat.
Charging by Subcooling, this is for Acs with a thermostatic expansion valve, it’s common to see a sight glass on the liquid line (on these units with a sight glass just clear it, when, indoor room is at approximate set point of the thermostat). Optimum sub cooling is 12° to 15° at the outdoor unit.
Hook up your gages and put a thermometer on liquid line (small line), start the AC. Measure the temperature of the liquid line and read the pressure on your gages. Theres a temperature scale on your gages for R-22 or R-410A the needle will show you the pressure on the outer scale and if you follow it down to the R-22 or R-410a inner scale that is the saturation temperature for that refrigerant,(you can also use a temperature pressure chart), now read the thermometer, let’s say the liquid temperature( the thermometer) is 100° and the saturation temperature (the gages or temp. press. Chart), is 114°, subtract the liquid temperature from the saturation temperature, 114°- 100° = 14° subcool.
Oct 05, 2009 | Heating & Cooling
AC Thermostat is set to 78 but wont cool past 79 or 80
If your unit is running 24/7 you are either low on charge or the unit is to small for your house.
A 20° temperature difference is about normal for the room air vs the air coming out of the ducts, but the room air and the leaving air should keep getting colder and colder.
An air conditioner should cycle approximately 3 maybe 4 times in an hour if it's properly sized.
As for the thermostat thermometer they are very cheap and are more for reference than actual temperature, so if 78° is not comfortable, then you should set it lower but not rely on thermostat being accurate or what the thermometer is saying as long as it is consistent.
The air conditioner and thermostat can also be set below 78°, there's a lot of people set them at 72° and below with no problems.
the only thing is if you have real low humidity you'll need to watch indoor coil or the suction line (the big line) on your outdoor unit and make sure it doesn't freeze up on you.
Sep 13, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
AC comes on and stays on until you move the setting up to around 90. At times the unit will not cut off no matter what setting you choose. If it cuts off at 90 after manually moving it there, you only have...
If the house is actually cooling, but the thermostat thinks in 90 degrees in there, you definitely need a new thermostat. If the house is actually 90 degrees, the AC SHOULD cycle on and stay on till it reaches the preset temperature. Since it doesn't make sense that you would complain about the AC cycling on at 90 degrees, I can only conclude that you have a faulty thermostat.
Jun 11, 2009 | Dometic Rooftop RV Air Conditioner
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Engine wants to stall
You need to Clean the throttle body bore and the throttle valve plate using a clean shop towel and some carb cleaner. The DTC P0128 is Engine Coolant below the minimum thermostat regulating temperature. You need to replace the thermostat, it comes as an outlet housing assembly. You will have to remove the alternator to gain access to this housing.
Jul 20, 2008 | 2003 Chevrolet TrailBlazer
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
