Question about MSI 694T PRO (6309-470) Motherboard
PC Not Starting
We have just moved house and when I put our computers back together mine did not work.
The wifes PC is just fine however mine is a different story when I initialy hooked everything up and turned it on the monitor showed CHECK SIGNAL CABLE. So I ran through the basics and rechecked all the connections and all were fine. Next I tried my wifes monitor and same thing, next was a Grapics card swap (i tried 3 seperate cards) still nothing, I even tried my old Celeron chip but still no go. I have pulled the whole PC apart cleaned and dusted everything and reassembled and again nothing. I have noticed (stupid me should have seen this right at the start) that it is physicly not booting up, all fans are running mother board lights are only getting to stage 1 hard drives are lighting and it gets to first beep then no further. I also have no keyboard and mouse activity. My Hardware is MSI 694t pro mother board, 1.2gig Celeron chip 1.2gig DDE ram. Previous to the move no issues the PC never left our hands so I know it wasn't dropped or anything like that. My next step (unless you guys have any ideas) is to go out and buy a whole new setup because I don't know what has failed.
Cheers from OZ
When you say "...put computers back together..." what does that mean?
Check video cable pins. Check disk drive connector...make sure they are pushed in tight on mobo and drive connector.
Posted on Apr 27, 2008
Power button on my laptop does not always work
I actually solved my problem a couple months ago. I thought it was the power supply, and took it to the Best buy, where for free just plugged in a different power supply with no change to the computer. That left the internal connection, so I opened the case (which was quite easy to do) and the place where the power cord connects to the motherboard has a small silver housing. I just kinda wiggled mine around until the light of the power supply came on again, and put it all back together. No problems since.
Hopefully that might work for you.
Jul 13, 2011 | Computers & Internet
Not draining an erro comes up E20 on it
E20 = draining issue. The most common problem is a blockage at the drain pump.
This can be checked by a DIYer with general hand-tools.
1st. Unplug the washer! We don't want to get shocked.
2nd. There is a lower panel on this unit which can be removed by removing two screws at the bottom. Remove this panel to gain access to the drain pump area.
3rd. Find a big diameter black hose coming from the bottom of the wash tub and follow it until it gets to a plastic housing with an electric motor sticking out the side. (there will be a smaller diameter hose coming out of this plastic housing as well this is your drain hose)
4th. Remove hose clamp on large black hose and remove hose from pump (water will flow! be ready)
5th. Check hose and pump for blockages... One of the most common is under-wires from the wife's bras. Spin impeller of pump to insure that it moves freely.
6th. Put it back together in reverse order of taking it apart. Try unit out by starting a cycle without clothes. Then put it in a spin cycle to see if water drains.
May 17, 2011 | Frigidaire GLTF1670A Front Load Washer
It is displaying a loading but there is no disc and it will not move. I have reset it like it says in the manual but no luck.
yes bad electronics took mine apart put it back together it worked fine till i turned it off . you have to tap or hit the front above the buttons and sometimes move stuff around then it will work wires boards but be sure its not plugged in
Sep 07, 2009 | Kenwood DV-605 Multi-disc DVD Player
No sound out of left speaker
To fix this I took mine apart. But I suspect it was the red and white speaker outputs. I unscrewed the screws and moved the red and white speaker outputs around and then put the thing back together. It now works again.
Aug 02, 2009 | Boston Acoustics MicroMedia Computer...
My Maytag Quietseries 300 has suddenly stopped draining H2O
My Maytag Quietseries has the same problem after less than 2 years. Mine is caused by using granular dishwasher detergent, which is the most common type of detergent. I took apart the entire pump inlet section (need a torx scew driver and a small socket for the impeller) and found the white abrasive material from the detergent (Cascade in my case) was packing in and pluging up all areas of the inlet. After I cleaned it all out & reassembled, dishwasher was back to 100%. Also noticed the normal cycle worked much better as well.
Jul 22, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
I took the cover almost off and now don't know how to put the harness back together
have you received an answer yet??? I have had to take off and put back on mine at least 10 times now.....If you still don't have an answer I will take mine apart and re-cover and write steps down as I is a hard cover to take on and still takes me about 20mins to get it all may want to consider buying a easy remove cover to go overtop of your pre-existing one. Let me know if you need help
Jun 28, 2009 | Cosco Alpha Omega Elite 5-Point 22-155
Cpu not starting after power outage
need new power suplly that one got shot and make sure your on hi end protecter never on wall ok
Jan 30, 2008 | Computers & Internet
Moved and now my comuter wont do anything
Try reseating the memory.  I have moved computers and 9 times out of ten the memory came loose.  So just take out the sticks make sure they're not too dusty then put them back in.
Oct 16, 2007 | Compaq Presario 5000 PC Desktop
Dopped tv, worked fine, now not picture but has sound
Most drop damage is in/around the area of the flyback xformer.My Motto==PVAT! With magnifier examine PCB for crack(s).May still be fixable.
Jul 31, 2007 | Sony KV-36FS100 36" TV
MSI 694T PRO (6309-470) Motherboard Logo
117 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
