Question about Marantz Audio Players & Recorders
My new /old stock marantz sa 15s1 does not recognize any sacd in either sacd or cd mode (normal cds sound wonderfully). I tried another - used - sample and it has the same problem. Are there any recognized fault with this series? Thanks
4 Suggested Answers
  • 20 Answers
SOURCE: Marantz SA-1 installation question
Does your Marantz have an "optical" or "digital" out?
If so, use them. Assuming you have a quality receiver/pre-amp/amplifier it will have it's own D/A converters.
If you plug into the receiver's CD inputs you will be using the D/A converters in the Marantz.
If you plug into the DVR/SACD inputs - it depends on the receiver et al.
Try both. See if one sounds better. Select the one that sounds best. For a top-notch system you need high quality from cables to receiver, and speakers. You system can only be as good as your weakest link, so what sounds good/great to your ears, that is the best!
Cheers
Posted on Mar 27, 2009
SOURCE: Hi, I have just got Marantz SA7003 SACD player. It
Are you inserting multi-channel sacd discs rather than 2-channel?
Posted on May 08, 2009
AJIN G
  • 6694 Answers
SOURCE: My Marantz SA-11S1 sacd player
hi,
just purchase a lance cleaning cd. It will be available in cd shops. insert it in the player. it will clean the lance. after cleaning insert the hybrid SACDs and watch is it reading. If not then the laser pickup unit of you player have some problem. You have to relapse the same.
ok
Posted on Mar 08, 2011
Testimonial: "Thanks for the prompt answer and "to the point" orientation. Thrustworthy Service!"
Diagnostic software
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 08, 2014 | Televison & Video
My Marantz SA-11S1 sacd player can't read many hybrid SACDs anymore. Do you recommend lens cleaning? Help please...!
hi,
ok
Mar 08, 2011 | Marantz SA-11S1
It no longer reads all cds sacds it use to, thought cds were bad,bought second cds and still will not play help love the sounds
When you say it doesn't read SACD's do you mean it doesn't put out 5.1? Keep in mind that you have select the SACD multichannel area and use the 5.1 analog outputs for that and NO digital output will be produced.
The manual...
http://www.retrevo.com/support/Marantz-SA8260-manual/id/511bh850/t/2/
Dec 28, 2010 | Marantz SA8260 CD Player
My Marantz 6110 will not shut off-turntable keeps spinning after arm returns
My Marantz 6110 wasn't working right. I had it repaired at a stereo store. They told me the grease was old and had hardened which made it difficult to operate the way it was supposed to. They cleaned it and used new grease. It's been working great for the last 10 years. I hope this helps.
Dec 23, 2010 | Marantz Reference TT-15S1 Turntable
Marantz CDR-510: Playback is good , recording is distorted
If this brand of media is new to you and the symptom is unique to it, I'd try a different brand.
Monitoring during record would never reveal media problems as there is no immediate playback after record as on old-school 3-head tape recorders.
I've had similar intermittent problems and I never could find a pattern to it except that it always seemed to be on low-end media. My best advice would be to try to find a pattern in your instance and make a change that avoids it. Then publish what you learned for us.
Good luck.
Mar 14, 2010 | Marantz CDR510 2-Disc CD Recorder
Will no longer play Red Book CDs - says either
just replace the ribbon wire of your cd player or check lense.by. jhuntech17
Oct 26, 2009 | Marantz SA-11S1
Marantz pm 15 s1 amplifier and marantz sa15 s1 Cd player
There really is no point in  connecting the two components with an optical (=digital) cable, if you didn't want to use the SA-15s DAC- and analog output section you might aswell have bo bought the chiepest one you could find...
To get better sound than the SA-15s analog outputs can provide, you would have to spend a load of money (not as much as for the SA-15 but quite a bit) on a DAC - and the DAC would only work with CDs, you would still have to use the SA-15s analog outputs to listen to SACDs.
So in conclusion:
-Use the SA-15s analog outputs
-If you have other digital sources that you want to use - if you care about their sound quality - you can sell/return the SA-15s, buy the chiepest CD-Player you find (only look and feel matter) and spend the rest on a good DAC. (note: SACDs won't play on this setup)
I'm using a PM-15S1 with a DAC (Apogee Mini DAC, Studio-Equipment, nominal price ~1000$, got mine 2nd hand for 400€ ) myself. A DAC is usually the better choice over an expensive CD-Player - especially if you've got other digital sources (PC, ...) - but you'll probably lose a lot of money if you sell the SA-15, so think about it (IF you're still thinking about it, I realise that your question is 8 months old...)
anyway... have fun with the PM-15, it sure is beauty
Jan (Hamburg, Federal Republic of Krautistan)
Jul 01, 2009 | Marantz PM-15S1 2-Channel Amplifier
Distortion on left channel of analog output
Based upon your description, the most likely caue is the D-A converter chip inside the marantz. This is a relatively common failure. Replacing the IC should resolve the problem.
Dan
May 20, 2009 | Marantz DV8300 DVD Player
Cheers
Mar 27, 2009 | Marantz SA-1 CD Player
190 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
