Question about Fellowes DM15C Shredder
Broken off DB-0812D mini-transformer from PS 67Cs Fellowes shredder
Purchase a 220/240 volt to 15.6/15.6 volt transformer and run flying wires as it will probably be larger in physical size.
I used a M7230 from Aztronics/Altronics.
Silicon the transformer in place to stop it falling apart while in its place.
Posted on Nov 01, 2012
SOURCE: My shredder stopped working
This shredder is supposed to reset after 15 minutes.
Posted on Dec 10, 2007
fellowesrep
  • 102 Answers
SOURCE: Fellowes Shredder keeps running
You should be able to flip up the cd cover and visibly see the sensors in the center of the paper entry(look like little LED lightbulbs) Clean with a Q-tip dipped in rubbing alchohol. This should solve your problem. If it doesn't you probally have a burned out sensor. call 1-800-945-4545 to check with customer service.
Posted on Feb 22, 2008
fellowesrep
  • 102 Answers
SOURCE: Fellowes 220c-2 repair manual
call Fellowes Customer Service 1-800-945-4545
dlundmark
  • 797 Answers
SOURCE: Fellowes Shredder Parent Part # 38605
If this unit is worth it to you, you can build your own gear.
Here is a link to get plastic repair materials to make plastic parts. This site also will have materials for repairing plastics.
Another possibility is to search Ebay for a unit like yours which has other problems. Never can tell... it may be there.
Make sure you ask for the model of the unit in your search (on the NET as well. The serial in this case is not needed.
Posted on Jul 26, 2008
SOURCE: Broken plastic gear tooth - Fellowes P55-C Shredder
hi,
i had the same problem on the fellowes fs5m model. i opened up the machine and found that the plastic gear was completely worn on one side.
i just found this website online for spare parts: http://www.wheelermachines.com/fellowes_parts.htm
haven't called them yet. if they don't have it i might try the belzona compound.
good luck,
marie
Posted on Nov 02, 2008
Looking for a basket for a fellows 65c
You can only buy new one or block a microswitch inside. Basket from Fellowes PS-67Cs can be used too. If you use this shredder privately just block the microswitch.
Nov 10, 2014 | Fellowes Powershred PS-65C Medium-Duty...
Ps-60 repairs
I own a Fellowes PS 60 shredder.
It could be that the sensor has trash or it is sensing something. Check it carefully if you see trash/debris cleanit with a Q-Tip or air blower - !DO NOT USE ANY WATER OR SOLVENT! -
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Mar 27, 2013 | Fellowes Powershred PS-60 Shredder
Red and green light is on but it wont shred
Nov 13, 2012 | Fellowes Powershred PS-60 Shredder
Wiring diagram for a Fellowes PS 60CC shredder
I DO NOT THINK THE LINK WILL HELP YOU, BUT AT LEAST YOU WILL HAVE IT.
Jun 29, 2012 | Fellowes Powershred PS-60 Shredder
When plugged in and turned on, both the red and green light come on and it does not work forward or in reverse
Mar 27, 2011 | Fellowes Powershred PS-60 Shredder
Fellowes Powershred PS 60CC stopped working
Jan 14, 2010 | Fellowes Powershred PS-60 Shredder
Db-0812d pcb mounted tranformer in my fellowes ps-77cs shredder has burnt out - need tech details of this transformer to enable me to find a replacement
Judging by the number of Google responses to DB-0812D it appears that this little transformer is mounted so that it hangs on its connectors = upside down from the intended mode and the slightest bump placing the power unit back on the collector bin can snap it off. Bad design on an otherwise good machine.
Action 1. Bin it.
Action 2A. Buy a different make [which may have other problems] - or...
Action 2B. Buy another the same but use hot melt glue to ensure the DB-0815D will stay in place.
Dec 29, 2009 | Fellowes Office Equipment & Supplies
Fellowes PowerShred PS 40 with defective switch
Its just seated together with the gear/blades housing ,
make sure you didnt miss one screw, then pry and pull upward its just stuck as the gear housing and blades are pressed in and seat firmly making it seem like its stuck , over time all that paper goo is also binding it up .
Heres a few sites that have gears another that has manuals you may have to call or email as not all parts are listed on website
http://www.compax.com/shredders/parts.html
http://wheelermachines.com/manufacturer.html
http://www.manualsonline.com/ex/thread/view/idThread/1735067
May 16, 2009 | Fellowes 3011001 Shredder
Fellowes DM15C Shredder Logo
1,454 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
