Question about Microsoft Xbox 360 Console
Xbo 360 dvd drive does not open solution
I Have Heard that it is possible to fix by replacing the dvd drive, I am going to try it, if you have not opened your xbox, you may send it to microsoft for 100 dollars, but if oyu have you already voied the warranty?
    Sergeant:
    Champion:
  • 427 Answers
If you have voided the warranty, they wont fix it fir any price. I would send it to irepairsquad.com. They do free diagnosis.
Posted on Apr 29, 2008
The CD tray wont open on my xbox 360
Do not attempt this fix ur self if your not familar with the dvd drive parts . The problem is the band on the dvd drive motor under the disc tray is slipping . To fix this use a rubber band. Step 1 Remove your dvd drive unscrew all 4 screws , 2 remove green board carefully . 3 unscrew any screw under the disc tray and remove this disc tray , step 4 get a rubber band a small rubber band and replace the band thats slipping put your dvd drive back together and ur good to go . If you do NOT want to do this your self you can go to Solomodsdotcom and they will fix the dvd drive for you . Google search to to replace rubber band on 360 dvd drive . You tube has videos on how to but i wouldnt recommend doing it your self if your not familiar with the parts .
Aug 07, 2010 | Microsoft Xbox 360 Console
I replaced my xbox360 drive and it only plays movie dvds it will not play games
This is not the drive that is faulty just too much heat you can fix it yourself using a good guide at home or send it in and they will fix it for you.
Jun 28, 2010 | Microsoft Xbox 360 Console
It will not read my disk
This can be caused by a dirty laser in the drive. Try cleaning the laser with a q-tip and alcohol. If this does not fix the problem, the laser may need to be replaced. Contact Microsoft and see if the unit is still under warranty.
Mar 29, 2010 | Microsoft Xbox 360 Console
Xbox 360 fails to read xbo 360 games. System turns on and works properly, able to play arcade games from harddrive and read dvds to play movies. When 360 games are inserted into tray the error message...
sounds like ure laser is on the way out has the drive been changed at all? try cleaning the laser with a cleaning disk if still no joy its a new laser by the sound of it might be cheaper to find a repair shop local than sending it to ms
Apr 17, 2009 | Microsoft Xbox 360 Console
360 reads game discs but it won't play game and it says play DVD
The problem is that the laser is either dying out, is dirty, or is not getting enough power.
so try to fix it using these steps...
- first open the 360 and pull out the dvd drive and open it up too.
- clean everything out good with compressed air, and q-tips dipped in alcohol.
- now you need to adjust the power going to the laser.Sometimes you may have to try multiple settings before getting it justright. Just keep adjusting the resistance lower and lower until itworks.
- if you tried multiple settings and still get the errors, then either get a replacement drive, or a new laser for it. Click Here for how to properly install the new laser.
- if you get a replacement drive, please not that there is a key in the pcb of the drive that must match the key from the motherboard, so you must either spoof firmware with the key, or swap out the old pcb board and put it in to the new drive.
If you need more dvd drive repair help click here
Dec 23, 2008 | Microsoft Xbox 360 Console
Xbox 360 starts up randomly, tray opens and closes spontenaously
I have the same Problem my X box came on spontaniously and the DVD tray opens and closes non stop till I get the RROD code. it will play games and DVDs only if it stays closed long enough to start then it opens up and starts the cycle all over. I opned up the DVD drive and can't see any thing blocking any thing I even used a Q tip to pit a little oil on the screw meckanisim that opens the drive and blue it out with compressed air. and it did not fix the problem I am going to have to buy a new drive my Drive is a Philips drive.
Nov 21, 2008 | Microsoft Xbox 360 Console
Dvd rom
I,ll assume this regarding the X-Box 360 ?
If you,ve replaced the Drive on a 360.
It will not work, due to the fact that the dvd rom drive, is paired to the motherboard. you can,t simply swap a faulty drive.
When the 360 boots, it,s looking for a Key On the dvd rom, before it will initialise it, and bootup.
I,d suggest looking on the net, regarding XBOX 360 drive flashing. if you still have your original drive, keep it. as your xbox won,t boot without it. you have to backup the drives key ( number ) And have it reflashed onto a replacement drive.
you could try a laser lens cleaner. Or possibly laser unit replacement.
Mike @ compurepair.
****please do-not Rate this post, Until your problem has been resolved ****
Mar 08, 2008 | Video Game Consoles & Games
Error Message
Be sure to wipe clean around inside hole on 360 game disk it has info laser scribed that tells the system what game it is.It might also need a laser adjustment.
Dec 26, 2007 | Microsoft Xbox 360 Console
Message "To play game put game in xbox 360 console"
Pick up in the DVD is bad or weak and will need replacing.
Or replace the whole DVD unit.
Make sure the disks are clean and not too scratched up
Check here for more things to try
Nov 07, 2007 | Microsoft Xbox 360 Console
Xbox360 game issue
ur dvd drive lens could be scratched. which means ur kinda screwd besides buyin a new 360 that is. lol ps i have the same problem n im screwd too i think peace, sk8abird
Sep 19, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
