Question about iHome IH24S Portable Stereo Alarm Clock Speaker System for iPod Silver
My ihome (iH24) has no display on the screen. i think it was caused by the breaker in our house tripping yesterday. i want to know how to fix it. i tested replacing the batteries, testing the outlet and the outlet worked fine.i need help.
My wight knight wk767 condensing tumble dryer keeps tripping the electrics in my house when i turn it on the reset button at the is ok what is the cause .
Simply there is to much load on the breaker so its tripping to protect your home. I'm not an electrician so I am giving you info based off my experience. Some houses, most I think, have a special plug for the dryer and you can buy a different plug that screws on to the dryer depending on which plug your home has. You may need to upgrade your existing plug in the wall if its an older house. Also, I believe that circuits is on its own breaker separate from the rest so it shouldn't Tripp anything else but the dryer\washer. You can easily fix this yourself if you are confident in dealing with shutting off the electricity and rewiring the outlet or the dryer plus. If not then a electrician can do it easily allbet at a fee. Often times the Home depot or Lowes reps will give you advice but you have to understand its only advice. I would take a picture of the plug and the wall outlet and the breaker. This way you have something to show them at the store when you ask about the plug. One other thing it might be is that the dryer has a bad hearing element or sensor and its drawing to much current causing the trip of the breaker but usually dryers have a $50 fuse on the back that's supposed to blow out first.
Dec 07, 2014 | Dryers
Dyson dc33 troubleshooting
i would try plugging it in at someone else's house and see what it does.
I need more info on this matter. i assume it will trip just one breaker in the breaker panel. if it is tripping more than one your breaker, your box is not wired correctly and you need to call an electrician immediately before your house burns down. is the sweeper new or used? if know for sure your wiring is ok in the house then your sweeper has a loose connection or bad motor and you need to have it fixed or throw the sweeper away. the money you loose by fixing or throwing away is a very small price compared to a fire.
Aug 29, 2014 | Vacuums
Electric range breaker trips at night when all asleep, resets ok
Are you sure nothing else is using power? Sounds like a ground fault to me. Any devices which could cause harmonics which you can think of?
Feb 14, 2013 | Computers & Internet
Aqua spa pack breaker tripped
A breaker trips if it getting feedback. Feedback can be caused by water or a crossed wire, or an electrical component failure. You said it's pumping water on the ground so the pump is working. Then if you put it back in it trips, so you pump isn't able to push the water to where it has to go and therefore your getting a pressure buildup which falls back on the pump sensors and stops it before you blow up something, it is saving you from disaster of property or personal injury, this is a good thing. You have a clog in your pipes or you have a valve that is closed that shouldn't be, but it's the back pressure that is blowing the breaker I think. I take it it is on an isolated circuit in your house and isn't sharing anything else that could be drawing to much on that circuit. Anything electronically new in your house? I don't think it's electrically related just asking.
Jul 14, 2012 | Aqua Pool & Spa
I recently lost power to part of my house and now my ac won't cool. I don't know the manufacture but it's model # nhp024akc1 ductless central ac unit. I was thinking it had a circuit breaker trip but I...
if the breaker tripped its in your electrical panel, your breaker panel, but the fuse may have blown in it, if it did, its an easy and cheap replacement
Aug 03, 2009 | Heating & Cooling
200AMP Breaker trips same time every night
Something doesn't sound right here. You indicate 2 200Amp breakers. With a single service entering the house, this is not possible. The "sub-panel" to the pool house is more likely a 100Amp setup, yes? If not, you have a bad setup and it should be corrected. I would suspect that you are attempting to pull too much current to the pool and that is what is tripping the breaker. Also, these breakers should not be run over about 80% of their capacity for the long haul. If they are, they tend to age and get either real sensitive causing tripping when it shouldn't or you can run 500Amps through it and it won't trip.
My suggestion is to revisit the setup. If the pool house is fed from the main panel, make sure that the breaker for it is not 200Amp. Second, try disabling the pool house breaker to see if that is the source of the problem and look more closely there.
Keep us posted.
Dan
Jun 29, 2009 | Electrical Supplies
My bunn is causing my breaker to trip
The heating element going bad in the coffee maker.
Mar 17, 2009 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Iron causing electrical fuse to trip
I would almost definitely say yes. Have a friend or family member bring their iron over and try it. I can think of no other reason why it would trip a breaker. Let me know what happens.
Jan 26, 2009 | Tefal UltraGlide plus 1656 Iron
My krups 9000 keeps on setting off the saftey switch at the main powerboard off my home
you mean house breaker i guest you tried the machine somewhere else and if still blowing breaker check the power cord open it maybe with vibration power wire are toughing themself inside machine cheers
Jan 26, 2008 | DeLonghi EC140 Espresso Machine
iHome IH24S Portable Stereo Alarm Clock Speaker System for iPod  Silver Logo
203 people viewed this question
Top iHome Audio Players & Recorders Experts
Marvin
Marvin
Wesley Elsberry
Wesley Elsberry
Level 1 Expert
ray gallant
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
