Question about Canon Office Equipment & Supplies
Error "CHECK" 5100 is being displayed in the screen of the fax machine JX-201. Kinldy suggest for a remedy.
  • 1,219 Answers
these means that you have carriage error. In most cases these happens when clutch of scaner assy is dirty or has too much grease on it.
Solution would be to remove upper cover and manualy rotate the scaner gear to go in home position and use small amount of wd40 on clutch.
If you want service manual, you can contact me on emma.servis@gmail.com
Posted on Aug 06, 2010
CHICK!5100
I have given the solution 4 jx 300
for ur machine answer is same
Search 4 canon jx 300 chk 5100
May 19, 2012 | Canon FAX-JX200
Kindly send me full users guide for cannon fax JX-201
It's so much simpler when you provide a Country for the fax machine, but no matter. A couple of minutes with a search engine reveals it's Asia. Send? Here's a file, you can look at or print. http://support-in.canon-asia.com/contents/IN/EN/0900782802.html
Carl
Apr 08, 2011 | Office Equipment & Supplies
Mesin fax saya merk canon FAX JX-201,,masalahnya tidak bisa untuk email keluar dan masuk,dilayar terdapat tulisan !!CHECK!! 5100... bagaimana cara untuk memperbaiki tanpa harus pergi untuk service??
saya mau bertanya.
mesin fax diakntor saya tidak bisa menerima fax yang mau masuk, ketika ada fax masuk lampu penerima fax menyala tetapi data fax yang dikirim dari pengirim tidak mau tercetak.
bagaimana solusi nya? mohon bantuan jawaban nya, pak.
terimakasih banyak sebelumnya.
Dec 06, 2010 | Canon Office Equipment & Supplies
Want to fix error !!check 5100!! on JX-200 fax machine.
Hi;transparant plastic ribbon that serves to guide the chariot is dirty clean with alcohol and cotton
Aug 17, 2010 | Canon FAX-JX200
I rifil canon Fax -JX 201. 1st time It Good worked. But 2nd Refill icant get photocopy; But it say "No ink" .How to Reset that error
by refilling the ink crg. you probably destroy head electronics. Buy new one ORIGINAL, and try then.If you must refill ink be carefull, rather buy new reffiled ink, where the chip is resetted.
Hope that helps!
Aug 10, 2010 | Canon FAX-JX200
MACHINE GIVE ERROR CODE 5100?
I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100. Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
May 30, 2009 | Canon FAX-JX200
Chek 5100
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Thanks for using Fixya.
Apr 02, 2009 | Canon FAX-JX200
Canon Fax JX-500 will not print any faxes
Just press the on/off button once this should do it.
Jul 16, 2008 | Canon FAX-JX200
Getting CHECK 5100 on a Canon Fax-JX300
THIS FAX CANON JX-200 EVERYTIME CODE 5100 WILL BE COME HOW CAN SOLVE YHE PROBLEM?
Apr 27, 2008 | Canon FAX-JX200
139 people viewed this question
old marine
old marine
