Question about Sony 2GB Memory Stick PRO Duo Memory Card
Sony Hi, I have this Sony Cybershot camera. I recently inserted a Sony memory stick of 1 GB into it and when I turn on the camera, it gives "Format Error" The camera works fine with Internal memory. Please advise on what to do. Thanks in advance, zrinz
  • Anonymous Jun 02, 2008
    Same problem with the ScanDisk 2 GB memory stick. The Sony Memory Stick Reader/Writer Just Blinks and is not recognized by the computer and when I put it in the Sony Cyber-shot camera is says that the stick is not formatted but provides no avenue to format the stick using the camera.
  • mylight2 Mar 15, 2009
    i have the same problem i have a new camra and i have a 8gb memory and the camera will not read it but it will read a 2gb
  • 1,257 Answers
There might be a problem with the file system you are using with with memory stick..insert it into card reader > format it with fat 32 file system..and insert it again to solve your problem.....if problem still persist .insert your memory card into mobile and goto your memory card > now select option > there you will see format memory card > so it will format your memory card with correct file system that your mobile wants.....
Please let me know your feed-back.
Technical Associate
Posted on Apr 28, 2008
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
Recently purchased Sony Cybershot DSCW180. Took 3
Yes, you need to have memory stick because camera has limited internal memory that can store few pictures only.
Put new memory card, format it through camera Menu and copy internal memory pictures to memory stick, take our memory card from camera and delete internal memory pictures either one by one or format internal memory through camera Menu.
Dec 02, 2009 | Sony Cybershot DSC-S950 Digital Camera
Problems with my Sony Cybershot W210
1) Make sure that you're not using more than 4 GB memory stick pro duo with the camera. Then try to remove the memory stick and capture 2 images in the internal memory and turn OFF and turn ON the Camera and check. If the error message comes, its the issue with the Camera itself and requires service after resetting. to reset the Camera, select Initialize under Main Settings 1 menu under Settings. if the issue persists, the camera may require service
If its working fine, transfer all the images to the Computer and format the memory stick. Formatting will delete all the contents. If the issue persists, memory stick should be replaced.
Sep 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
I purchased a Sony cybershot DSC- S930 and inserted the Lexar memory stick (supposedly compatible with a sony camera) and upon turning the camera on there is an error message stating there is not internal...
The camera does not recognize the card because
1. Card not compatible
2. Camera cannot handle such a large capacity.
3.Card not inserted correctly.
Maybe a recent firmware update can address the 2nd limitation.
Hope it helps.
Sep 11, 2009 | Sony DSC-S930 Digital Camera
Cybershot DSCw80 doesn't read memory stick
Have you tried a different/new memory stick other then the one it came with? It is possible that one is no longer working. Once you try that I can assist you further. Also please take a moment to accept and rate my solution accordingly.
Thank you,
Feb 27, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
DSC F707 Error C:13:01
Can't use Memory Stick PRO's on the DSC 707, they won't format. The technology of the PRO's postdates the 707's.
Aug 10, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Dsc-s700 format error
If you have a computer with a memory card reader that takes the stick. insert it into the computer and goto my computer find the memory stick drive letter and format it their then retry the stick in the camera. also try to go into the cameras menu and try formatting it their if you cannot format the stick it is very possible it is bad.
Mar 21, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony Cybershot DSC S650 Memory stick not formatting
Well I have the same camera.
And mine won't turn on.
Suggestion dont trust this camera.
Or maybe it just can't hold that much memory.
Mar 15, 2008 | Sony Cybershot S650 Digital Camera
Format Error in Sony Cybershot
it could be a faulty memory card, but a more likely cause is that this stick isn't formatted yet. you can format it usually by bringing up the camera menu, then going to tools and format. you can also format it by using windows and a cardreader or your camera.
Mar 04, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
ho un problema con la mia cybershot dsc-t5 come posso risolvere l'errore di formattazione C:13:1 su una memory stick duo prodotta da neo
Jan 02, 2008 | Cameras
Sony 2GB Memory Stick PRO Duo Memory Card Logo
281 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
