I can ear noise and the water goin in but the cycle not goin round
  • kaseem Aug 06, 2010
    my ariston margherita cd12t washing machine cycle not going round-the water goin in but not spinning
  • 15,935 Answers
It is likely your lid switch has failed.
What is the mank and model of your unit?
Thanks!
Posted on Aug 06, 2010
    President:
  • 1,554 Answers
We may not be able to help you unless you specify the make and the exact model number of your machine. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated herein.
  • 1 more comment
    sorry the make is ariston margherita cd12t
  • Jahn27
    Jahn27 Aug 06, 2010
    The issue is likely a worn motor carbon brush. If the machine fills in then start and apparently completes the cycle without the drum turning, then it is indeed a worn carbon brush.
  • Jahn27
    Jahn27 Aug 06, 2010
    Replace the carbon brush to address the problem.
Got half way down lawn was cuttin ok then made funny noise blades goin round but not cuttin grass now
sounds like you might have hit something and the blade is now loose .
Mar 17, 2016 | Garden
I replaced the drain pump but machine is making a noise like its goin through spin cycle when turned on. Water drains right out aswell HELP
if the pump is working all the time then it will be the program board
make sure that after you replaced the pump the drain hose outlet was higher than the tub or all the water will run out
Feb 23, 2016 | Washing Machines
Where's the pressure valve on my rhino combi90? Freezing
is this gas or electric unit . call repair man is best advice
Dec 18, 2014 | Water Water Heaters
My washer wont spin,
If you had to empty the water manually, i.e the outlet pump did not drain the water out then I would suggest the pump is either blocked or has failed. This will normally prevent the spin cycle from occurring. Try checking and cleaning the pump filter out.
Dec 31, 2013 | Frigidaire ATF6000ES Front Load Washer
I have a gateway T2895 PC that makes noise when I turn it on
ok noise comes from fans, drives or maybe other moving parts would be useful for 2nd round solution to know where noise is starting?
listen with ear near tower and let us know and is it high pitched or clicking sound
Jun 03, 2012 | Computers & Internet
Water heater keeps running
yes it could be the cause; so could a wrong; too high setting
remove power using the house main circuit board panel then: remove the
two panels upper and, lower pull back the insulstion and, you will see:
a round plug with a hexagonal flange these are the heating elements (flanges)
and, the thermostats (brown retangular switches with a red dial; check the dial for temperature that might be too high a setting.
Jul 31, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Cycle won't start just makes a humming noise
if you have just installed this machine or it has been moved out make sure that the water supply taps are on as the humming sound could be the water selanoids (electronic water vales that allow water to flow) if there is no water in the machine it will not advance, check water selanoid, check to see if another prrogram give the same fault, put your ear close to the machine to see if you can lacalise the sound (never remove the the caseings without turning power off 1st very real chance of electric shock)
Jan 15, 2010 | Siemens WXLI1240 Front Load Washer
Whirlpool DU8900 XT-5 the water comes in at beginning of cycle and the heater heats the water, but the machine does not go any further. it kinda' hums but no water gets pumped and moving. at end of cycle...
if you can hear a low humming noise when it should be pumping water round, then suspect the circulating pump.
fault can be motor capacitor - low cost part
or
pump seized - see if you can turn it by hand
Sep 15, 2008 | Whirlpool Dishwashers
Won't connect to any cycle
Do you hear any noises during the cycle, does water come in and drain out ?
Jun 30, 2006 | Indesit WA 125 Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
