Question about Magellan GPS
My magellan powers itslef off even if it is connected to a power source. After powering on it shuts down within two or three minutes
  • 525 Answers
Check if it charge if yes change the battery
Posted on Aug 06, 2010
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
How to get a replacement power cord for my Magellan 3045lm that will plug into my truck?
Another way to reach Magellan is through chat. Go to http://www.magellangps.com/support . Click on the chat link icon. You should be able to chat with an agent within a couple of minutes. You can also order online Product Number: AN0207SWXXX
Dec 26, 2014 | Magellan GPS
Monitor blank even though power is on
Totally shut down all power to the PC and remove any connected devices such as a mouse or external hard drive. SHUT DOWN by holding power button long enough to actually hear the PC shutdown.
It is a "fizzling" signal.
Also disconnect power sources that are plugged in. They are not shut down when they still have a power source.
Take a decent break.
Then one by one restore power to the charger, the PC, any other devices (including a printer).
Often this solves the problem. Good luck.
Jan 27, 2013 | Gateway One ZX6970-UM10P All-in-One...
Device will not power on
I found a Magellan Roadmate in the dumpster when I was dumping the trash off my truck.They were even so kind to leave the charging cord.I figured out that the charging cord wasn't connecting to the unit when plugged in.It took 20 minutes to figure out how to pop the case open(retainer tabs on all sides in addition to the screws).Once opened up,it took 5 minutes to repair the solder connections from the power socket to he circuit board.Works like new!
May 31, 2012 | Magellan Roadmate 2035 4370 2036 4040...
It shuts down while driving
Does it shut down only while driving, is it connected to a power source at the time? Does it have the ability to charge and won't hold the charge?
Rylan
Dec 15, 2010 | Magellan RoadMate 1440 Car GPS Receiver
Wants to shut down even when plugged in
this is a very common problem with these magellan 3140 and also the 3100,2000,2200t,2500,4000,4040 and the 4050 most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ... to open the case on a 4040 you must start on the power button side, otherwise you'll break the unit
May 24, 2009 | Magellan Maestro 3140 GPS Devices
Odd shut down delay when power cord is attached
how about running defrag? do this by right clicking on your c:\ drive in my computer and selecting the tools tab. Then you will probably have to run scandisk first but this might help
Dec 28, 2008 | Gateway MX6447 Notebook
Total power failure
same here! first my original car charger stopped working, so i purchased a replacement (a generic one off ebay), plugged it in and the little light on the top right turns on. but i have not been able to turn it on. i've left it charging for at least a half hour and nothing. any ideas?
Nov 24, 2007 | Magellan RoadMate 3000T GPS Receiver
GPS Logo
50 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
