Question about Fagor Washing Machines
Fagor FE 539 Problem: Filter When I remove the filter for cleaning I find it very difficult to put back. It's always been a problem and now it seems to be getting worse. The filter seems to screw in lopsidedly and I have to work at it for about an hour before it settles in. Thank you Margaret
SOURCE: How to clean filters
The fine fitler screws out by twisting the entire unit counter-clockwise. The threads are built into the filter unit itself. There are no screws to remove. Hope this helps.
Posted on Jan 05, 2008
  • 2039 Answers
SOURCE: Stuck filter screen screw on DeLonghi BAR32
i got a saeco vienna digital i got the same problem that screw jam the same as our i clean the filter with water and air if you whant to try something try to soak in decalcifier it gonna melt the calcium cheers
Posted on Jan 16, 2008
eagle338
  • 4889 Answers
SOURCE: Miele leak when switched on for wash, from filter unit front LHS bottom of machince
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
Posted on Aug 21, 2008
  • 1462 Answers
SOURCE: Indesit wil 103 filter
stale smell may be due to using liquid detergent - change to powder.
filter may be of two types. if in the front, unscrew cap and just pull. may be difficult is a foreign object like a bra wire is stuck inside.
other type of filter is in the large diameter pipe from bottom of machine to pump. take off small back bottom panel and undo this pipe at the machine end and filter is inside this pipe. pull out and clean
Posted on Sep 04, 2008
SOURCE: Krups XP7240 leaks
The grind selector knob can be removed with the following steps: 1) Remove screw on side near grinder (do not let the screw fall into grinder, :-) ), 2) use sharp knife or similar to pry off cover with three dots. This should be easy. 3) Now you can rotate the grind selector and see that the white clear plastic does not rotate and the black does. There are two little pieces (one black, one clear plastic) on opposite side from grinder that slide over eavh other to keep this knob 'locked' into place. 4) again with a sharp pointed knife or similar you can separate these two pieces to 'unlock' them. This is made easier by lifting the side of the bean holder by the grinder gently and tipping it up. Be careful not to force anything too much. The black part should pop off. 5) Now you can lift off the clear bean holder.
After this good luck. We made it farther into the machine, but could never get to where we needed to go to fix our problem.
Krups must be congratulated for designing a machine that cannot be repaired and must be replaced with new purchases.
Posted on Jan 11, 2009
F02 fault cleaned out the filter but still wont work
Possible that the inlet flow is low, Clean the inlet filter, check the inlet flow. Check the drain filter and if this was clogged, then the chances are that the valve must be removed and cleaned.
Sep 04, 2014 | Fagor Washing Machines
Fagor oven has error code F06
I cleaned the smoke filter, took of the top cover, in front of electronics is the brown smoke sensor. I took of one wire off the sensor, started the oven (beware of not shortcutting anything) the f06 error message had disappeared. I put back the wire, mounted the top cover and the oven functions like new.
Nov 28, 2012 | Fagor 5HA-196 X Single Oven
Fe 738 do not spin
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 04, 2011 | Fagor Washing Machines
Our fagor fwm714it washing machine door will not open after the cycle finishes or when turned off. the machine has been showing the error code F07 of late.
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 27, 2011 | Fagor Washing Machines
How can I change the fuel filter in my Hyundai Santa Fe 2004?
You simply locate where it's installed. Loosen and remove fuel hose clamps first. Plug any fuel hose ends with bolts of appropriate sizes. Remove the bolts and nuts holding the filter to the engine.
Replace filter with new one, and bolt to the frame. Connect back the hoses. Hint: its good practice to disconnect the negative post of the battery before starting this job.
Oct 21, 2009 | 2004 Hyundai Santa Fe
HOW TO CHANGE OIL ON A 2002 HYUNDAI SANTA FE. IM 19 YRS OLD AND WOULD LIKE TO HELP MY GIRLFRIEND AND CHANGE IT FOR HER. A DETAILED DRAWING POINTING OUT THE OIL CAP AND THE DRAINAGE AND FILTER FROM...
Lift your Hyundai Santa Fe using a jack and then place the car on jack stands. If you don't have jack stands, drive the car onto a set of wheel ramps.
Pop the hood and remove the dipstick and oil filler cap. The dipstick is near the front engine compartment with the oil filler nearby.
Gather an oil drip pan, a 17-mm wrench, oil filter wrench, cleaning cloths and a new oil filter. Slide under your Santa Fe.
Change the Oil
  • Locate the oil filter and oil drain plug underneath the car. The drain plug is on the bottom of the oil pan, and the filter is to the side of the oil pan.
  • Remove the oil drain plug using the 17mm wrench. Pull the plug out quickly and let the oil drain for 10 to 15 minutes. Check the gaskets and threads for damage. Replace these components, if necessary.
  • Take off the oil filter using an oil filter wrench. Dump the old oil into the oil drip pan and put on the new oil filter. Tighten the oil filter by hand, and then replace the oil drain plug using the wrench. Clean off the excess oil.
  • Go under the hood and add oil. Turn on the engine and check the oil pressure gauge to make sure it rises. Let your Santa Fe run for a minute.
  • Lower your Hyundai Santa Fe and turn off the engine. Take an oil reading on the dipstick. If the oil level isn't at full, add a bit more oil.
Thanks
Kinldy rate the answer
Smith
Jul 08, 2009 | 2002 Hyundai Santa Fe
Oil filter
i always just put some on the o-ring before i put it back in but no you dont need to have oil on it,
Nov 10, 2008 | 2000 Husaberg Fe 600
Oil filter
Nov 10, 2008 | 2003 Husaberg Fe 501 E
Oil filter
Nov 10, 2008 | 2000 Husaberg Fe 501
Oil filter
Nov 10, 2008 | 2005 Husaberg FE 450 e
Washing Machines Logo
51 people viewed this question
Top Fagor Washing Machines Experts
Marvin
Marvin
Vernon Taylor
roeb
Are you a Fagor Washing Machine Expert? Answer questions, earn points and help others
