Question about HP Photosmart C5280 Printer
C5280 printer has loud clacking noise on the right side when ink cartagecome to rest after their travel across the printer. There are a few tiny ink platters of black ink on the inside of the printer mostly behind and around the ink holder basket. The alert notice on the printer continually tells me I have a paper jam. I have gone through all of the teps listed on the HP Support help internet site. I can not clear that paper jam notice. The roller that pulls the paper up for perparation does not react or move at all. The paper remains in a neat stack. I ame determined to save this printer if I can. Will you help me? My equipment is for home use. Window Vista HP Vavilion Media Center HP Photsmart c5280 all-in-one copier, scanner, Printer I am in the USA-born in Oklahoma in 1933
    Genius:
  • 2,785 Answers
Your printer has hardware problem so plz take it for servicing
Posted on Aug 06, 2010
Testimonial: "Thank you. Your speedy reply did help. I was advised to replace the printer. Thanks for your help."
  • 1,218 Answers
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Posted on Oct 14, 2010
Xerox 6330 loud clicking sound
Check the rails the paper tray sits upon. see if the one on the right side is damaged or dislodged. You didn't say if the noise happened when you printed from the 2nd paper tray.
Apr 01, 2014 | Xerox Phaser 6360 Laser Printer
Ink cassete is jammed
Hp 5280 is just a pile of garbage. Make loud gear stripping
noise and won\'t load paper. Tryed all the fixes. I think all
these cheap printers/scanners are programmed to stop
working a certain time so they can sell you more JUNK !!!!
MW
Aug 07, 2013 | HP Photosmart C5280 Printer
My Photosmart C4780 makes a loud clacking noise before printing
Has it just started this? Some printer can be a bit noisy. The plastic gears and parts can use a little bit of Silicon Spray, you may want to dab it on with a Q-tip or similar tool.
Jan 18, 2013 | Cisco Photosmart C4780 Wireless AllInOne...
We have 2 different HP printers with the same problem. When the ink carrier goes all teh way to the right side of the printer they do a loud gear noise for a few seconds. My e-mail is...
That is a necessary process, typical on HP as well as other brands and should not cause any issues. the process tells the system where the heads are located and travel ability.
Sep 28, 2010 | HP Office Equipment & Supplies
Check printer 5100 whaat is this problem and how do i fix it
Ink buildup. The B&W and color cartridges abut and shoot ink through a thin metal strip with a tiny ****, visible when opening the unit. The strip rests right up against the cartridges. A grayish strip where you'll see a dark line running across. That's ink. Carefully remove this ink with Q-tip and rubbing alcohol. Additionally, the printer head cleaning pads on farthest right side are caked with ink. Manual advises to replace these parts. They can be cleaned with Q-tip and Rubbing alcohol also.
Jul 02, 2010 | Canon PIXMA MX310 All-In-One Printer
Loud clicking/clacking when paper feeds
Your rollers may be worn and when they are trying to pick up the paper they are not able to . Buy taking your printer to an authorized technician for a maintenance cleaning this should resolve your issue.
Jun 08, 2010 | HP D1660 InkJet Printer
Won't print. makes loud clicking noise from right side front of unit (ink cartridge parking area)
Please have a look at the noise troubleshooter available for your printer at the HP online support site. Click here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 29, 2009 | Office Equipment & Supplies
Loud ratchet noise
Have you been using ink cartridges other than store bought? Reason I'm asking is that i used a refill kit, and tried those half price refill places, only to find ink was leaking out when not in use & clogged up the ends where the cartridge moves across. take a flashlight & look at the ends of the track that the cartridges slide across on, you may see a build up of ink, that won't allow the cartridge to travel as far as it needs to go to run properly.
Nov 06, 2008 | HP LaserJet 3330 All-In-One Printer
HP Photosmart C5280 Printer Logo
781 people viewed this question
Ben Johnson
