Question about Hitachi Deskstar 7K80 HDS728080PLA380 80GB 7200rpm 300MBps Serial ATA II Serial ATA/300 I... (0A30356FT) Hard Drive
Where can i find a driver for a deskstar hds 728080 plate 20 Many thanks
I need a map chip & onwers manual for a Lowrance HDS 5 like insight. Serial no. 102574610. Where can I get them?
here is the manual
HDS-5, HDS-7, HDS-5m & HDS-7m - Lowrance
https://www.lowrance.com/.../Lowrance.../HDS-5-7-5M-7M_OM_EN_988-10041-00...Sonar references do not apply to the HDS-5m and HDS-7m GPS only units. Manual Conventions. When you are instructed to press a button in this manual, the ..
Software Upgrades here
Lowrance HDS 5 Software Google Search
and finally Mapping
mapping for Lowrance HDS 5 Google Search
and specifically, INSIGHT
Insight Genesis - Download free Lake, River and Coastal Maps
https://gofreemarine.com/insight-genesis/Make your own maps and download free maps from the community. Insight Genesis' cloud-based software does all the work, automatically processing ... with sonar signals from your existing Lowrance, Simrad or B&G transducer. ... The cloud automatically backs up all your data, protecting against lost or damaged SD cards.
Jun 26, 2017 | Lowrance Boating
Deskstar harddrive
What is the model number of your unit?
Nov 01, 2012 | IBM Deskstar 40GV (DTLA-305020) 20 GB Hard...
I have ibm deskstar 20GB. Problem is that i want to connect it as an external drive through usb connector. It detects but no partition is shown in my computer. i try all jumper setting define in manual...
In Windows 7, you can use Disk management to detect and create a partition on this drive if necessary.
Steps: 1. Connect your external drive through a USB port.
2. Click Control Panel - System and Security - Create and format hard disk partitions (under Administrative tools)
3. Your drive should appear in the table below. Select the external disk and Right Click on it. You will be presented with several options (Create partition, Format, etc.). Select whatever is applicable in your case.
4. Your external drive should now be detected by Windows 7.
Mar 23, 2011 | IBM Deskstar 40GV (DTLA-305020) 20 GB Hard...
My unit didn't come with a manual. where can i get one other than from lowrance, which wants to charge me $20
Click Here!! For the installation guide!!
If this was helpful please rate with a 4 thumbs up!! Thanks for using fixya.com!!
Apr 17, 2010 | Lowrance HDS-8 GPS Receiver
I have a Hitachi DeskStar T7K250 - hard drive - 160 GB - ATA-133 and a masscool UHB 330U 3.5 IDE to USB case for it, however windows will only stop at ''searching for preconfigured driver folders.'' Help...
This is typically a corrupt mass storage driver in windows. You can try removing C:\windows\driver cache (may be c:\windows\system32\drivercache too.
Then reboot; and see how it works. This resolves most of of the issues. http://techrxgb.com (please join us on facebook for hints / tips and tricks)
Feb 25, 2010 | Hitachi Deskstar T7K250 160 GB Hard Drive
I want to install a Hitachi Deskstar drive and the
Based on normal configurations, you should make sure that the pin settings on your main boot drive is set to master, and then make sure that your Deskstar is set to slave. If that doesn't work, then you might have a Bios setup issue. Let me know.
Thanks
Mark
Dec 18, 2009 | Intel D915GAG Socket 775 Motherboard -...
Lowrance HDS-5 won't load Navionics
You may just need to update the softwear on the GPS, you can download it directly from Lowrance.com along with instructions on how to install it.
May 24, 2009 | Lowrance Hds-5 GPS Receiver
Transducer for LOwrance HDS-5
is the HST-DFSBL lowrence transduser combatible whith HDS-5 unit?
May 02, 2009 | Raymarine B60 12 Tilted Element Transducer...
HITACHI deskstar hardrive. model HDS722580VLAT20
Send it to TechRx, Inc. we are a data recovery company in Wisconsin. We offer free shipping and estimates. I have specific tools (hardware) that will SA emulate Hitachi drives; and that makes for easy recovery of your data. http://techrxgb.com
Nov 15, 2008 | Hitachi Deskstar T7K250 160 GB Hard Drive
Computers & Internet Logo
287 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
