Question about Sunbeam 4214 Iron
Sticking Iron does not glide easily over fabric
  • Carole Anne Jul 07, 2008
    My iron is brand new and it sticks terribly. Does not even come close to 'gligiding'.  I am going to return it.
  • Sunbeam Master
  • 43,501 Answers
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Posted on Jul 15, 2010
A Rowenta electric iron
clean with steel wool or simply get a new iron with teflon base
Jun 07, 2016 | Rowenta Irons
How can I clean the plate of my Oliso pro. It has wonder under on it
get the iron hot. Take a piece of fabric and a dryer sheet. Put the dryer sheet between two layers of fabric. Place this at the edge of your ironing board. With the iron hot, run the sole place over the "fabric/dryer sheet set" several times. This will remove wonder under and many other adhesives from your iron.
May 31, 2016 | Oliso Tg1600 1800 Watts Smart Iron Pro
When I iron a piece of clothing and move the iron forward then back the fabric will wrinkle.
Check the bottom rear of the iron to see if there is a spur sticking up like a scratch. If so use wet sandpaper to get rid of it.
Sep 01, 2014 | Irons
I have just fitted a new solanoid to our steam generator pro express iron. Previously it would continously steam and the answer given was that the solanoid was sticking in on position. now the red light to...
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
However clean very well the surface of solenoid, and see if there are something abnormla in the surface and clean it. and test it again. tight very well the connection of solenoid, can be loose and produce NOT strong attraction.
God bless you
Nov 12, 2012 | Irons
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
My new black & decker steam advantage iron won't glide over clothes, it's almost like it wants to stick to the clothes.
check the instruction manual and see if it says to clean the surface before using it , if not try cleaning it and use it on something old in case it wants to scorch the fabric
Dec 11, 2009 | Black & Decker Irons
T-fal ultra glide easy cord iron stopped working while ironing
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 03, 2009 | Tefal UltraGlide 1569 Iron
Breville steam glide 2200w iron
Hello, dont know if you still have no instruction book for this iron, i have the same iron and found the instruction booklet on there website. go to breville website, and irons and download.
Dec 23, 2007 | Irons
Sunbeam 4214 Iron Logo
106 people viewed this question
Top Sunbeam Irons Experts
Tony
Henry  Thomas
Henry Thomas
Karl H
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
