Question about LG Microwave Ovens
Fuse blows off imeadiately model mh-1296mz wiring dia reqd
NEED APPRATING MANUAL
Posted on Jan 11, 2011
KItchenAid microwave KHMS1850S: interlock switches replaced, but fuse keeps blowing
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/khms1850s.html
Jan 27, 2015 | KitchenAid Microwave Ovens
My LG microwave oven 3850w4a043b is working but not heating up?
Check the microwave fuse. It is in a plastic fuse casing on a wire. The fuse is about 1/8 dia x 2inch. Be sure to replace it with exactly the same rating.
Jan 15, 2014 | LG Microwave Ovens
Us lgservice com
Check the fuse inside the oven.. It is on a wire housed in a white plastic. Twist it and the fuse comes out. The fuse is about 1/8 inch dia. by 2 inch. Be careful to replace it with exactly the same rating.
Jan 14, 2014 | Microwave Ovens
Oven turns on but will not heat
Check the fuse. It is on a wire plastic fuse case colored white. Twist to open, replace a fuse 1/8 dia x 2 inch with an exact replacement. Be sure that the cover is placed back well when you are done.
Jan 08, 2014 | Microwave Ovens
Need manule for model mh 7046sqz i need help
That's not showing up a valid US model number.
Try here.
Apr 14, 2013 | Microwave Ovens
Whirlpool microwave fuse has blown multiple times
It depends on which fuse and when it blows. Wish you had mentioned that.
But usually it's a defective door switch or door switch mount.
If the fuse blows at random times while it's cooking, it may just be a loose fuse holder. Those have to be replaced due to metal fatigue, not just squeezed tight with pliers.
If it blows as soon as you hit "Start" to begin cooking, you have a shorting high voltage capacitor.
If it blows when you open or close the door, you have a loose or defective door switch or latch.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Nov 21, 2012 | Microwave Ovens
LG microwave oven Model MH-1296MZ is not fuctioning, fuse checked ok. Pannel lights are not glowing, pannel lights slowely slower stop glowing in one year period. Thanks in advance mohammad Nazeer
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
Sep 05, 2011 | Microwave Ovens
I have a whirlpool microwave oven MH 7130XEZ-1. When I turn on the power, the shelf support sparks and flames. Do I need to but a new machine?
you need to remove the shelf support. If you can see bare metal in the oven. You need to get a bottle of white appliance touch up paint and paint over the bare metal. This sould solve the problem.
Jul 07, 2009 | Microwave Ovens
LG Microwave MH-685HD Owner's Manual
Try this website: http://www.service-manual-owner.com/lg.html You may have to email the person to get the manual?
Jun 16, 2009 | LG Microwave Ovens
Breaker blows
When you turn it on? You mean when you plug it in?
When a microwave blows a breaker but not the fuse, it's often a shorted monitor switch (usually the middle door switch) or one of the other two door switches, or a loose or broken door switch mount.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 15, 2007 | Whirlpool MH2155XP Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
