Question about GE (PSS26MSRSS) Side by Side Refrigerator
How do i clean my fridge that is not self defrost and when did they stop making them
  • 4,793 Answers
Switch off at plug,open door and let the unit self defrost(do not use sharp objects or hot water/steam to hasten defrost)
when defrosted wipe out with clorine bleach,syringe drain hole(s) and wipe dry,the bleach smell will dissipate in about an hour,then close door,switch on and fill at least 1/2 full(any less and the unit will run very ineficiently)leave door closed as much as poss until temp is between +2c/+5c(the ideal temp)ensure all seals are clean and not perished.
Posted on Aug 06, 2010
Refrigerator not cooling
The self defrosting mechanism is fubar. Check out the defrost timer and defrost element for proper operation. Chances are that the element is open.
Jun 25, 2016 | Samsung RF266ABRS Bottom Freezer...
Westinghouse fridge turns it self off to defrost is this normal
If your second hand fridge is over 5 years old, then it might be time to buy a new one. Most fridges nowadays have a lifespan of 5-8 years the most. Danni
Jan 10, 2013 | Refrigerators
Freezer is starting to frost up, what could the issue be? how can i determine and fix?
1 Could be a bad door seal letting moisture in.try cleaning the seal and area around it.
2 Bad defrost timer.self defrosting only.
3 Setting is too cold.
4 Clean out condenser,unplug fridge.condenser is in the back lower part of fridge.May also be located on the back of fridge.
5 Low on freon.
Jan 04, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
When it goes into self-defrost mode, the freezer goes up to approx. 40 degrees, frost is on the items, the ice cream gets soft, and items start to get moisture in the wrappers or containers. Is this...
no it is not normal, your defrost termination switch is stuck or contacts are welded together, termination switch is there to protect from overheating of freezer, defrost timer puts system into and out of defrost but termination switch keeps the heaters from over heating the area, chances are you will need a defrost timer as well, manufactures recommend you change both when one or the other goes bad, also clean your condenser coil and make sure good ventilation around fridge bet there are lots of dust bunnies and plastic bags between the counter and fridge
Sep 17, 2009 | Refrigerators
Fridge & freezer warm clicking noise is coming from compresser
Clean all the dust and lint accumulation from under the unit, remove the condensation collection pan and clean it, and make sure the bottom fan is running.
I can't emphasize strongly enough how much of an enemy the accumulation of dirt and dust under a refrigerator can be its worst enemy. It can make the refrigerator exhibit symptoms of much more serious problems. Sometimes a good cleaning can have it operating like new with no real 'repairs' whatsoever.
Aug 22, 2009 | Refrigerators
Warm fridge cold freezer
Hi,advance thermostat setting, to get colder , it's possible you got defrost problem, is there excessive ice building inside back of freezer? to determine if you have a defrost problem, unplug ref. for about an hour,let it defrost, let all ice melt away, it's better to remove your produce, keep doors open to speed up defrosting, after defrosting and cleaning plug back your ref, and let it work for another hour, and check result, if it's o/k, put back your produce, let me know, during hot summer months, regular use (opening) of ref, could cause excessive ice build-up evap. if after defrosting and cleaning ref. work good for 3 to 4 days, but start doing the same thing, let me know, it means you got a defrost problem. also check your thermostat, but first defrost and clean it, that could just be your problem. good luck.
Aug 13, 2009 | Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Candy fridge freezer
it should come back after about 20 mins only and should cool back after about 10 mins.
i'm afraid the buzzing sound could be coming from your compressor which can not start. the over current relay is tripping off after 20 seconds to prevent the compressor from burning up.
i suggest to unplug the ref, let it cool for 1 day, re plug it after a day and observe the compressor if would run.
if the buzzing sound is still there and the unit is no longer cooling, then the compressor is not running.
check the relay of the compressor. it could just be the relay.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Candy CPCA240FFK Bottom Freezer...
I have model number ARB1914CB, 4 years old and the fridge part has pretty much just stopped working. Tiny bit of cool air coming in from the back vent but the "running" noise of the fridge is no...
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Aug 20, 2008 | Amana Refrigerators
Fridge is leaking water all over the place.
The defrost drain opening or drain hose is plugged up with ice or crud. If the drip pan is bone dry, it's a sure sign that the drain opening or drain hose is clogged. Trace the drain hose back to see where it pick up the condensate in the refrigerator cabinet. Remove whatever pieces you need to to clean that sucker out. Door gaskets are torn or not making good contact with the cabinet. No? Well then where's all that water coming from, Einstein? It can only come from the humidity in the outside air--your fridge can't make water, dontcha know
May 10, 2006 | Maytag MBF2256H Bottom Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
54 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
