Question about Car Audio & Video
I own a 1996 ford laser and have just had a dead battery replaced. the radio does not work now and requires a code. i need help obtaining that code.
  • cliggy_123 Aug 06, 2010
    Hello.
    Thank you so much for helping me out. I took the car to a local mechanic and he think that the serial number for my ford laser radio is JCOAAASGNLTTK40585.
    Thanks again for helping out.
    Daniel
  • 1,675 Answers
Hi please can you find the...serial number, it should be either a
M series, C (3 digit code)series, A+C series, L+C series the others are 4 digit codes, these are important to be able to give you the code , if you do not know, then just write everything down you can see on the radio and i will try sort it for you..you can email me at
s.e.morris@hotmail.co.uk hope this helps
Posted on Aug 06, 2010
    Hello.
    Daniel
    Hey.
    Im so so but it seems that i have given u the car serial number instead of the radio serial number. I'm sorry but i dont know what the radio serial number is but i have attached a picture of it. Is there a certain spot on the car where i can locate the serial number? Thanks again.
    Daniel
Battery went flat radio wont work now.how do i get code?
Search Results
    Car Radio Stopped Working after the Battery Died
    cartech.about.com > ... > Car Radio Components FAQs, and More
    First your battery went dead, and now your car stereo is dead, and it's really ... or charge, and you're lucky, then you may find that your car radio fuse is blown.
    radio won't work after new battery installed - Car Talk
    community.cartalk.com/.../radio-wont-work-after-new-battery-installed
    Nov 30, 2011 - Today the dealership did a tuneup, replaced the timing belt, and put in a new battery. I started my car and the radio did not work. They went out ...
    Another Flat Battery - Radio No Longer Works - Hyundai Forums ...
    www.hyundai-forums.com/.../128744-another-flat-battery-radio-no-long...
    Jul 18, 2011 - Also now the battery has been recharged the redio will not work. .... Mybattery went flat, took it out and went to a battery shop who charged it up ...
    Dead battery..now radio won't work - Honda CR-V Owners Club
Dec 09, 2015 | Cars & Trucks
Please can anyone help my elderly neighbour had some work done on his car battery disconnected e has no code ford 600 cd radio code m069766
Unfortunately without the code the radio cannot be activated and you will need to go to a ford dealer to access the code if it is still in their system for which there will be a fee charged. Every radio has its own individual code. You will need to supply them with the vehicle details including the Vehicle Identification Code (VIN).
Dec 07, 2015 | Ford Cars & Trucks
I have a 2006 Ford Taurus and the radio will not work recently replaced battery alternator and starter any suggestions on what it could be I'm check for radio fuse but cannot find radio fuse everything...
all fuse boxes, there is not just one;
and its marked RADIO.
radio will not work (what does that mean)
100% dead
asking for code
display dead or not
or display works but all stations dead.
what.
if 100%dead it can only be 3 things
1: fuse blow , i bet
2, wire cut to radio (called power B+)
3: the radio is dead, bench test it. ask
Jan 20, 2015 | Ford Cars & Trucks
How do I obtain the security code for my Land Rover radio
Take your Land Rover to a L/R dealer they will obtain the VIN from the vehicle and search their archives and should be able to pass on the radio code if radio is correct for the vehicle some radios require removal from the vehcle to obtain numbers from the frame. hope this is helpful.
Nov 29, 2014 | Land Rover Cars & Trucks
My battery went dead on my ford fusion 2008 now my radio doesn't work
As with many newr cars, Your radio probably had a security code which is required to reset it after the radio is removed or power was disconnected from it. You probably have the code written somewhere in your new car paperwork. If not, contact your dealer. They can probably guide you through resetting the code.
Nov 03, 2010 | 2006 Ford Fusion
How to remove a factory fitted radio in a 1996 ford laser
Hi, I need code for radio in Ford Laser GL 1996. Code range is 4 digits long and a range of 1 to 6 numbers to choose from.
Oct 09, 2010 | Ford Car Audio & Video
I1996 ford fiesta with a radio fault /code required
You can get this code from the dealer but they will charge you between £20 to £35 for doing this.
I can confidently recommend this site that does these codes for £3.50. They specialise in Ford radios only. Cheap, quick and always reliable. I've used it myself on several occassions. Click Here.
Hope this helps. Thanks for using FixYa.
Apr 19, 2010 | Code-Alarm Code Alarm Transponder
Radio reads safe
The radio reads "safe" because you lost power to the radio. Either the battery was replaced, the battery was dead, or one of the terminals was disconnected. You will need to take the serial number from the radio to your local VW dealer where he can call in to obtain the programming code for your radio. The dealers usually do not charge in order for you to obtain the code.
Jun 01, 2009 | 1997 Volkswagen Golf
Does anyone have the radio code for a 1994 Ford
Check out my other posts for an idea.
Cheers !
ozzy11
Feb 22, 2009 | 2006 Ford Laser
Radio code serial no M071608
if you do not have radio code .you have to go to the ford dealer with the serial number of the radio as so they can obtain the code
Oct 18, 2008 | Vehicle Parts & Accessories
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
