Question about Microwave Ovens
Microwave counting down with excelerated speed and not heating. Amana built in.
  • Microwave Ovens Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 02, 2008
Amana ac01860a doesnt turn but does count down itdoesnt heat either
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 14, 2011 | Amana ACO1860 Microwave Oven
The motor will not work. The interior light comes on, but the turntable does not go around. The cook time counts down, but no cooking occurs.
the turn table motor could have failed, but the counting down will be the monitor switch or a micro switch located behind control panel
Feb 24, 2011 | Amana ACO1860 Microwave Oven
Tray is not rotating and its not heating up
Basic Microwave Oven TroubleshootingTips
heatman101;'][][\
Apr 25, 2010 | Amana ACO1860 Microwave Oven
Microwave not heating, but does count down minutes.
Press clear/reset button and hold 5 seconds. If this doesn't work unplug unit or shut off breaker for 10 seconds.
Sep 25, 2009 | Hotpoint RVM1435 Microwave Oven
Microwave won't heat food, new smart board unavailable?
HAVE YOU THOUGHT ABOUT TRYING TO BUY A USED ONE AND TAKING THE BOARD FROM THAT ONE AND PLACING IT IN YOURS ?
Apr 13, 2009 | Microwave Ovens
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
Timer descends very quickly
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Feb 01, 2009 | Maytag MMC5000 Microwave Oven
Microwave runs, stops and counts down, starts again, etc.
It sounds like its over heating or the magnatron or the Hi voltage transformer. if you open it and start it a fan should be cooling off the magnatron if its not then the fan is bad and thats your problem Worse case is that the power transformers drawing too much current and over heating and shutting down the first problem i explained though I've seen a hundred times. BUT BE very carefull as there is hi voltage inside this puppy and I've seen it grab and throw a grown man across the room!!!! if you know nothing about electrical or electronic devices its best that you leave this repair to a pro. Good Luck
May 04, 2006 | Amana AMV1162 Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
