Question about LG Washing Machines
LG WM-14225FD - making bad grinding type noise when in use
It will be your pump that circulates the water. i have had mine replaced four times during its 6 year life! its common, not to be confused with the drain pump.
Posted on Sep 22, 2010
2 Suggested Answers
  • 97 Answers
SOURCE: my lg wm 14225fd is making a banging popping
this sonde like the drum needs to be rebalenced this needs to be done once a yr. you well need to call a repair person its covered under your warrenty.
Posted on Dec 23, 2009
Lg wm makes loud noise when changing speeds, grinding sound
It sounds as if there is a problem with the tub bearing of the machine, replacing this is a job left to professionals.
Sep 06, 2014 | LG WM2501HWA 4.2 cu. ft. Front Load Steam...
Change rubber boot on lg wm-14225fd clothes getting soiled on boot
If your seal isnt leaking why not try cleaning your machine by putting on a boil wash with a flushing agent such as OUST . Dont put any laundry in and once you have started the programme then increase the water level by carefully pouring about 6 kettlefuls of water thro the dispenser.If your m/c has a variable thermostat make sure this is also set to 90oc.Allow to go thro programme and you will find your machine also smells a lot better.
Dec 17, 2011 | LG Washing Machines
Washer say on screen LE and will not turn.. Also when manually turn the turn hear grinding noise too.
Grinding noises are bad. If you are lucky, you got an item (like an underwire support from a bra) between the inner and outer tub, which may be removed through the heater or drain openings in the tub. If you are un-lucky, your rear tub seal failed, causing the rear bearing to fail, or the shaft broke loose from the 3 arms of the spider which drives the inner wash tub. Either of those things is $$$ and a lot of work to repair, involving removal of the outer drum, seperation of the outer drum halves, and repair. (translation: minimum 2 hours labor if you've ever done one before)
Feb 28, 2011 | LG WM-2277HW Front Load Washer
Ok my LG front loading washer agitates but when it comes to spin it makes a very irritating high grinding noise and does not spin. There is no error displayed but that may be because I stop it before it...
I have a similar problem. The washer was showing error code UE, but would tumble when empty in test mode, but would not spin and made a grinding noise. The bolt that attaches the rotor to the motor was loose and the rotor was spinning on the spindle that rotates the drum. I tightened the bolt, and it spins when empty, but still gives a UE error code when full. Remove the rear cover and check the tightness of the center bolt.
Dec 16, 2010 | LG WM-2277HW Front Load Washer
What dose oe mean on the display and it makes a grinding noise when it drains the water i think
Drain error: Not fully drained in 10 minutes. Causes: Drain hose too high. objects in pump, drain hose kinked, drain hose air locked, bad control.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 27, 2010 | LG WM-2277HW Front Load Washer
My lg wm 14225fd is making a banging popping
Dec 22, 2009 | Washing Machines
Grinding noise from the drum motor
My brand new one is doing it only after 1 week. I'm also interested in it. I'm thinking of pulling it apart and watching it and trying to find out where it's coming from exactly.
Jul 19, 2009 | LG WM-3677HW Front Load Washer / Dryer
LG WM 14225FD eu code
EU --- error means ---Unbalanced load is sensed three times during a spin operation. to resolve the issue ----Open lid. Rebalance laundry load and close lid.· Check wiring harness
· Check unbalance switch
· Check circuit board
Mar 14, 2009 | LG WD-1280FHD Front Load Washer
Lg intellowasher DD 7.5kg WM14225FD error code OE
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Oct 01, 2008 | Washing Machines
Washing Machines Logo
450 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
