Dear sir, I want to know all the porgraming codes for Ricoh FT 4822 Photocopier because MY photocopier creats problems for me every day. plzz send me complete programing codes for photicopier.
  • 12,061 Answers
Http://www.download-service-manuals.com/manual.php?file=Ricoh-1740.pdf
Please find above your service manual at this link above, inside are all the things you need to know to service and repair.
Posted on Aug 06, 2010
Error 365 what the solution of it
SC-365 Image storage error VI out of specs, drum, drum potential sensor, charge corona, dirty optics FT 7950, 7960, 7970
Nov 24, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
How do i restrict use to an aficio MP2550 photocopier
Hello sir; You may go to user tool key open up copy setting,looking for user code setting.
Jun 03, 2009 | Ricoh Office Equipment & Supplies
Large broad grey lines on all photocopies
Hello sir; The problem you have , you do need a drum cleaning blade to replace and also image transfer roller need to clean with alcohal.
May 26, 2009 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh FT 4427
It's an analogue photocopier, black & white.
Not worth much, but was a very popular model in its day.
If you're just after a straight forward copier, it should do the job.
Feb 25, 2008 | Office Equipment & Supplies
Ricoh photocopier 1075 code sc541
500's usually means overheating problem
contact service support from your local authorized dealer
Jan 10, 2008 | Ricoh Aficio 450 Copier
RICOH Photocopier machine - problem
The code you are getting is actually E-101 there is not enough space on display to display the whole code so in future if you get a code again press the # key and you can see the whole code .This code is an exposure lamp code , so either your exposure lamp is blown , or got lose connections , or you moved the machine and the scanner klimed off its rails and cant go back to the hime position .Try to enter the service mode by pressing yellew c 107 and hold down blue c all in sequence ,the number 1 will star to flash , press 5 then # 810 # then 0 # switch on and of and see if it works other wise send me a reply and ill see how i can help you .thanks
Jan 06, 2008 | Office Equipment & Supplies
Hi it is the polygon motor failure error
2nd motor down on this link is what you need.
Nov 30, 2007 | Office Equipment & Supplies
MY PHOTOCOPIER IS ASKING FOR CODE SC194
Nov 30, 2007 | Ricoh Aficio 1018D All-In-One Laser...
134 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
