Question about Samsung Washing Machines
MY MACHINE WA82V4G IS NOT WORKING & IS DISPLAYING SOMETHING LIKE 3P. WHAT SHOULD I DO ?
Water is not stop automatic
Do you mean: The water continues to run into the drum? If so you need an appliance engineer to check out the incoming water solenoid valve.
Nov 06, 2014 | Washing Machines
Modelno wa82v4g water is not stop automatic so what to do
Check the hose of the water sensor level or water inlet valve
How to check the resistance on the iac in a 2000 acura ti?
Here you go: 2000 3.2TL - DTC Troubleshooting: P1519 (14)
DTC P1519: IAC Valve Circuit Malfunction
  1. Reset the PCM.
  2. Turn the ignition switch ON (II).
    Is DTC P1519 indicated? YES -
    Go to step 3.
    NO -
    Intermittent failure, system is OK at this time. Check for poor connections or loose wires at the IAC valve and the PCM.n
  1. Turn the ignition switch OFF.
  2. Disconnect the IAC valve 3P connector.
  3. Turn the ignition switch ON (II).
  1. Measure voltage between IAC valve 3P connector terminal No. 2 and body ground.
    Is there battery voltage? YES -
    Go to step 7.
    NO -
    Repair open in the wire between the IAC valve and the PGM-FI main relay.n
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s80wa32k72100091519faad01
  1. Check for continuity between body ground and IAC valve 3P connector terminal No. 1.
    Is there continuity? YES -
    Go to step 9.
    NO -
    Repair open in the wire between the IAC valve and G101.n
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s80wa32k72100091519faad02
  1. Disconnect PCM connector B (25P).
  1. Check for continuity between body ground and PCM connector terminal B23.
    Repair short in the wire between the IAC valve and the PCM (B23).n
    NO -
    Go to step 11.
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s0k3a02k77100091519faad01
  1. Connect IAC valve 3P connector terminal No. 3 to body ground with a jumper wire.
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s0k3a02k77100091519faad02
  1. Check for continuity between PCM connector terminal B23 and body ground.
    Go to step 13.
    NO -
    Repair open in the wire between the IAC valve and the PCM (B23).n
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s0k3a02k77100091519faad03
  1. Remove the jumper wire from the IAC valve 3P connector, then reconnect the IAC valve 3P connector.
  1. Measure voltage between body ground and PCM connector terminal B23.
    Substitute a known-good PCM and recheck. If the symptom/indication goes away, replace the original PCM.n
    NO -
    Replace the IAC valve.n
rjaai003_204.asp?menuid=rdbawh030000&sessionid=20a4339a-9fe0-4aa5-b153-7284daac493a&lang=0&dbkey=s0k3a02k77100091519faad04
May 17, 2014 | 1996 Acura TL Series
Amika curling wand gives me err
I have the same problem. On the display it shows Err which is error i think. Can someone help us please?
Dec 20, 2013 | Amika 3P Set With Straightener &...
I have a Bravo 3P pet immune PIR and it says on the connector that the contacts are normally closed. Unfortunately they are normally open. Is there something that I am missing? Even the specs on the...
To work properly, this unit has to have normally closed loop circuit. With power applied, and no motion in its sight, should measure 000 ohms (plus any resistor value in series). When activated..the contact should show infinite resistance(open).
You are only missing something if you're testing it with you in the the motion area.
Trash it otherwise.
Aug 20, 2011 | Bravo Sports Dsc Bravo 3p Pir Motion...
Bob was thrice as old as peter. Six years ago he was 4 times as old as peter . Find their ages now?
Correction: Bob is thrice as old as Peter.
Let b be the current age of Bob, and p the current age of Peter. Now, b=3p
Six years earlier the relations was: b-6=4*(p-6)=4p-24.
Take the 6 to the right side leaving b=4p-18
Remember that now b=3p. Use it in the equation above
b=(3p)=4p-18, This becomes 3p=4p-18 or 0=p-18, and p=18
Peter is 18 years old, and Bob is 3*18=54 years old.
Verification: 6 years ago Peter was 12 years old and Bob 48 years old. 48/12=4.
Aug 10, 2011 | Texas Instruments TI-84 Plus Calculator
When specs say circuit requirement is 40, do they mean the breaker size?
What are you wiring?
Does it seem realistic that you need 40 Amp capacity?
40 Amp circuit breaker is usually 240 Volt and it goes to heat pump, double oven, or some heavy equipment. 40 amp breaker uses 8 gauge wire.
You can figure a circuit with the formula V x A = Watt
If your VA is 7500 Watts and voltage is 240, then Amps is 31.25
Oct 13, 2010 | Siemens /ite Bq Circuit Breaker Bq3b090 3p...
How to operate samsung wa82v4g washing machine. Water does not stay in washer at all.
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Sep 25, 2010 | Washing Machines
ViewSonic E70 VCDTS21569-3P. NO POWER
hi,
Try to check capacitor on the B+ line leakage.
Mar 29, 2008 | ViewSonic E70 17" CRT Monitor
Open Questions:
Washing Machines Logo
100 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
