Question about Samsung SW62ASP Top Load Washer
I have a Samsung SW50ASP and need to replace the start/pause and power buttons, where can these be obtained from
My Samsung washing machine is not getting any power
Press power to turn washer off --unplug from wall plug --w/power off press & hold start/pause button 5 sec.--plug in
Feb 02, 2018 | Samsung Washing Machines
E2 Code - Samsung SW50ASP Washing machine
Water drainage issue. Water is not draining from appliance.
·Check drainage pump filter for blockages (e.g. lint, coins hair, clips)
·Check drain hose and waste connection for kinks and blockages.
Then select a spin cycle to drain
the remaining water in the appliance.
·If problem persists please call CustomerCareline. *
Helpline Contact Samsung UK
Dec 08, 2016 | Samsung Washing Machines
Pauses randomly during films, all front buttons play/pause the dvd
Maybe one or more buttons jammed or wet inside.
Try opening front panel and clean the contacts. If problem persists then it is the buttons controller IC/PCB faulty.
Feb 04, 2018 | Televison & Video
The language has changed to Spanish - how do I change it back to English?
Enter the setup mode, by pressing and holding the play/pause button while powering your car kit on. You must complete the four setup phases, where the first one is precisely the language selection, for your settings to get saved. Browse through the options available for each phase by pressing the volume up or down buttons, and select the option which suits you better through the play/pause button. For each selection. the indicator light will flash green as a confirmation. Upon completion, your car kit will play the standard power up sound, and will start as usual.
Hope it works for you.
By the way, if you car kit's user guide happens to be missing, feel free to download it from this location.
Anyway, please, let me know if I can assit you any further.
Regards, Carlos
Sep 26, 2011 | Motorola Mobility Motorokr T505 Bluetooth...
How do you turn off the samsung yp-z5 mp3 player?
Press and hold the bottom bar of the square ridged around the central button. This is the bar you press to play/pause and start up the player. It should have a power button symbol on it.
Apr 01, 2011 | Samsung YP-Z5 MP3 Player
Samsung DVD (1500) Remote problem.
Try to reset the blu ray player's remote control.
Remove the batteries and hold down the POWER button on it for 30 seconds.
Then replace the batteries with fresh ones
Jul 03, 2009 | Samsung BD-P1500 Blu-Ray Player
DE Error in samsung washer SW50ASP What is it and how do i fix?
De error refers to "Door Error".
You do not need to buy a new machine. You can fix this.
Look at the below mentioned link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
No doubt the above page is for "LG", However it's the basic and would remain the same for all models and machines whether that's GE, LG, Samsung etc....
Thanks for using Fixya.
Apr 28, 2009 | Samsung Washing Machines
Error code e10
Communication failure =E10
1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
position.
2. Press and hold the Select and Pause Cancel
buttons simultaneously for (6) seconds.
3. Immediately after, press and hold the START and
Pause Cancel
buttons simultaneously for (4)
seconds.
4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
position.
The STATUS indicator lights will flash the number of
times for the first digit of the code and the START indicator
light will flash the number of times for the second digit.
The code is obtained by counting the number of times
the lights flash. Example E24: the STATUS indicator
lights would flash twice indicating the 2 and the START
indicator light will flash four times indicating the 4. The
STATUS indicator lights and the START indicator light
will start flashing at the same time. The control will then
pause for 2 seconds, then repeat the code.
Troubleshoot the problem by using the chart on next
page.
To move to the next code, press the OPTIONS button.
To clear code, press the Select botton.
To exit this mode, simultaneously press and hold the
Select and Pause Cancel buttons for (6) seconds to
reset.
if this does not work need to replace control
Sep 07, 2008 | Frigidaire Washing Machines
Samsung SW62ASP Top Load Washer Logo
77 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
