Question about Canon PIXMA MP980 All-In-One InkJet Printer
My Canon Pixma MP980 All In One won't scan documents to my computer to which it is attached. It will scan to a USB memory stick but not to the computer. It keeps giving the error message that the "image" can't be found. What can I do to correct this frustrating problem. I have un-installed and re-installed the software 3 times and replaced the power cable and the computer connection cable in vain. It used to scan to my computer but not any more. I run Windows XP Home edition. Thank you, Christina Weate
SOURCE: USB Problem in installing Canon PIXMA MP160
the USB cable you are using may be of poor qualit. Try a USB2 compatible cable that is thicker.
Posted on Sep 24, 2007
SOURCE: Canon PIXMA MP780
The problem is not the printer or the make of printer: The problem lies with the PC
Posted on Dec 14, 2008
  • 2692 Answers
SOURCE: Canon Pixma ip1800 won't install on Vista
Did you update the software 2/20/09 also ? Download both the software and the driver. Uninstall the whole thing and start over.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=14991#DownloadDetailAct
Posted on Feb 26, 2009
  • 1126 Answers
SOURCE: I have an canon pixma mp480 connected to a windows
Is the printer connected via USB to the XP computer?
How did you map the shared printer (ie; what port)
When you're on a Vista machine, go to Network, find thw XP computer, explore, can you access the printer through this method? I need to know if Vista machines were set up with this printer on Local Port or Connected to this machine.
Posted on Jun 22, 2009
CosmaP
  • 409 Answers
SOURCE: Windows XP SP3 will not recognize the printer is connected.
It could be the cable, but most likly it is a damaged driver. try uninstalling the printer and all the drivers then reboot and resinstall it. You could also run "sfc /scannow" to see if any system files are damaged.
Posted on Jul 11, 2009
Tip
Drivers and Manuals for PIXMA MP980 Windows and MAC OS
Here I will show you where to find drivers and manuals for the Canon Pixma MP980 Wireless photo all in one printer.
Drivers for this printer are available for Windows 98, windows ME, windows Xp, Windows Vista, windows vista 64bit editions, windows 7 and windows 7 64bit editions.
On the Mac side drivers are available for Mac OS X 10.3/10.4/10.5/10.6
A full on screen manual, quick start guide and other instructions are also available.
To download these drivers and or documentation for your printer please visit
THIS PAGE
Note that the picture below reads mp730 but the actual page linked will be for mp980
1. Click on Drivers & downloads
2. Select your OS ( Operating system, windows, mac etc )
3. All available drivers, documents etc will be available below.
For some of the documents a PDF reader may be required to open and read / print them.
To obtain a PDF reader, read this page
PDF Documents. Pdf reader(s)
Thank you for reading and I hope your printer is up and running again.
-Ekse
on Mar 11, 2010 | Canon PIXMA MP980 All-In-One InkJet...
How can you set up canon pixma ip2700 with out a cd rom on computer
Copy the CD driver onto an USB memory stick using a computer with a CD drive, then insert the USB memory stick into your computer and install the printer driver.
Jul 17, 2012 | Canon Pixma iP2700 InkJet Photo Printer
My Canon MP980 Print/scan/photo Series printer is printing everything that is in color in yellow. I have cleaned the heads & nozzles. What is wrong?
Causes : Blocked by dry ink. Solution : Your Color i.e. Cyan & Magenta were malfunctioned/blocked. So try to clean them up tightly.. thanks
Sep 02, 2011 | Canon PIXMA MP980 All-In-One InkJet...
Canon mp 980 won't even copy or scan if any ink runs out. Is there any way to change that?
Sorry, but no. As far as I know that's how all of these all-in-ones work. If the printer doesn't work because the cartridges run dry, nothing else works either. They don't allow you to use the scanner as a standalone piece.
Jul 06, 2011 | Canon PIXMA MP980 All-In-One InkJet...
I have a PIXMA MP 150 I lost the disk to load it back on to my repaired computer. Im also on dial up, Can I down load the software to get this working again ? Serial # JCBA87074
Find a friend with high-speed access.
Buy a USB memory-stick.
On your friend's computer, access CANON's web-site:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=12764
and download from the web-site to the USB memory-stick.
Carry the memory-stick back to your computer, and install.
Oct 29, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Mar 28, 2009 | Canon Office Equipment & Supplies
Printing directly from a memory stick via the MP600 USB port
Your printer may not have the ability to recognize the files you have in the stick. Did you ever think of that?
Jun 20, 2017 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP980 All-In-One InkJet Printer Logo
118 people viewed this question
old marine
old marine
