Wifi is not working. Device manager ic unable to search that. how to replace that.
    Scholar:
  • 86 Answers
Hi i got your issue
Please try with the folowing steps
Step 1) Unplug and replug the adaptor -check with the light status
Step 2) Uninstall and reinstall the adaptor
Still if you have issues Your drives seems to be outdated you need to update drivers from the particular website of your adaptors
Thank you
With regards
Priya
Posted on Aug 27, 2010
Wi-Fi stopped working on my Gateway NV77H19u. I can connect to the Wi-FI from a different laptop. Is there an external switch on the NV77H19u to use Wi-Fi?
Your Gateway either has corrupt drivers or has forgotten your WiFi.
Go into your device manager and remove the WiFi device. Then have your computer search for any hardware changes. It will find your wifi device and reload drivers. If this does not work, you have a bad wifi card.
Semper Fi,
Z
Jan 31, 2018 | Gateway Computers & Internet
Windows 8 Updates disabled WIFI connections
look in the device manager an see if there is a driver loaded for the network devices
if not then see if you can find a driver on the makers website
see that the wifi is not disabled or turned off
May 09, 2015 | Computers & Internet
I have a surface tablet unable to connect to wi fi
Solution 1 - Reset TCP/IP stack
To reset your TCP/IP stack, do the following:
  1. Right-click on the Start Menu button and open Command Prompt (Admin)
  2. Type the following command and press Enter: netsh int ip reset
  3. Reboot your PC and check if you're able to connect to WiFi network. If you can, you're good to go, but if not, type the following commands in the elevated Command Prompt and press Enter after each one:
  • netsh int tcp set heuristics disabled
  • netsh int tcp set global autotuninglevel=disabled
  • netsh int tcp set global rss=enabled
  • ipconfig /flushdns
Solution 2 - Re-configure WiFi Adapter
Maybe reconfiguring your WiFI adapter will solve the problem. To do so, follow next steps:
  1. Go to Search, type device manager and open Device Manager
  2. Right-click on your wireless adapter and go to Properties
  3. Go to Power Management tab, uncheck Allow the computer to turn off this device to save power and click OK
  4. Modify the default power plan, and switch it from high energy savings to low
Jun 30, 2014 | HP Compaq nc6000 Notebook
Windows 8 keeps losing WiFi config
You can test it with an external wifi adapter. I use Edimax nano USB WiFi adapter (it cost around $15) and it has its own drivers and applications. Please don't forget to disable your internal wifi adapter after installing the external wifi adapter.
Feb 27, 2014 | Microsoft Computers & Internet
Unable to activate wifi, unable to connect wifi from my acer one d260
Check if device driver is installed:
1. press windows logo + R 2. type devmgmt.msc 3. check network adapter if there is a wireless device available
If there is a missing driver, pop in the acer driver CD and install the wireless driver from there.
to run the wireless manager, press Fn + F3 to turn the wireless on
Jun 26, 2011 | Acer Aspire One PC Notebook
Lost my wifi and sound
reinstall the device drivers. right click on My computer then select manage. Under device manager, you'll see the devices that have an exclamation point. Remove and reinstall.
Apr 20, 2011 | AMD IC Power CN5560 Notebook
My wifi does not work it doesnt allow me to search for wifi in the area the only way i can get enternet is if i connect it to the Ethernet
click start and right click on my computer click manage click device manager click network adapter this is the network device right click device and uninstall connect it to the Ethernet restart computer windows should find hardware and install it. Then check for windows update
Jul 27, 2010 | Computers & Internet
I've lost my WIFI drivers on my Acer Aspire 3003LC.
go to device manager then network adapters then right click on your wifi device and select update drivers and tell the wizard to search online for drivers device manager is located:right click on computer(mycomputer)-->properties-->device manager:steps are a little different in xp but about the same.it is important to put in your operating system
Apr 23, 2009 | Computers & Internet
My USB ports no longer detect devices when plugged in.
Updating, or in some cases reinstalling, the drivers for your computer's USB interface should resolve this issue.
Locate the iPod in Device Manager
  1. Connect iPod to the computer.
  2. Quit iTunes if it launches.
  3. On the Start menu, click Control Panel.
  4. In Control Panel, open Administrative Tools. Note: If you don't see Administrative Tools, look at the left column in Control Panel for a link that says, "Switch to Classic View," and click it.
  5. Double click the Computer Management shortcut.
  6. In the left column, click on Device Manager.
  7. In the right column, click the plus (+) icon next to Universal Serial Bus controllers to expand this selection.
  8. Locate the iPod in this list. In some cases one of the entries will have "iPod" in its name. If no such entries are present, the iPod is most likely represented by "USB Mass Storage Device."
  9. Note: A red "X" appearing next to the iPod's entry in Device Manager indicates this device is disabled. To enable this device, right-click its entry in Device Manager and choose Enable from the shortcut menu.
  10. Update the USB driver
    1. Right-click the iPod's entry in Device Manager and choose Update Driver from the shortcut menu.
    2. In the Hardware Update Wizard that appears, select "Yes, this time only" to allow Windows to connect to the Windows Update Website. Click Next.
    3. Select "Install the software automatically (Recommended)" and click Next. Windows searches for updated drivers and installs any it finds. If Windows is unable to find updated drivers on its own, continue with step #4.
    4. Click Back.
    5. Select "Install from a list or specific location (Advanced)" and click Next.
    6. Select "Search for the best driver in these locations."
    7. Select "Include this location in the search" and type the following in the field below: C:\Windows\INF
  11. Click Next. Windows searches this location for drivers and installs any it finds. If Windows is unable to find updated drivers on its own, you must reinstall the USB drivers as shown below.
  12. Note: During installation, if a message appears stating that the software you are installing "has not passed Windows Logo testing" click Continue Anyway to continue installing the drivers.
  13. Reinstall USB driver
    1. Right-click the iPod's entry in Device Manager and choose Uninstall from the shortcut menu.
    2. In the resulting dialog box, click OK.
    3. In the Device Manager window, right-click Universal Serial Bus controllers and choose Scan for hardware changes from the shortcut menu.
    4. Windows automatically reinstalls the necessary USB drivers and attempt to remount the iPod. Regards...
Apr 06, 2009 | HP Compaq d530 CMT PC Desktop
Computers & Internet Logo
24 people viewed this question
Alun Cox
David Payne
David Payne
