My front loading machine washer did not have enough water to wash. water is very low almost low when i saw from front glass door. what hapening, how to adjust the water capasity.
  • 343 Answers
No brand or model number supplied...
Front load washers use very little water. Most modern FL washers don't even fill to the bottom of the door, and it's easy to become concerned..I know how you feel.
If the machine is completing the full wash cycle, it's recognising that there is enough water to continue. Capturing and measuring the amount of water used, and comparing with manufacturers specificatrions can help.
If it stops mid way, it could be because there is a slow or faulty water inlet valve.
Check with the manufacturer/service agent to ascertain the water useage.
You may need to call a serviceman to physically check the machine, for your peace of mind...
Good luck Nomess
Posted on Aug 07, 2010
Broken Glass Sound
OK, who washing the dishes in the CLOTHES Machine?! Broken glass sound? You are sure your neighbor isn\'t playing a trick on you! I am going to guess that you have either a BAD bearing, in which it is time to look at Other Machines as an option. I mean if the clothes are getting clean and it drains all the water? Just shut the door! No I can\'t say that...Can I? Whirlpools (in my opinion) are one of the Best. The problems we are having today are these Front Load Machines are a Piece of Crap! They do not use enough water. You have to use Hi Definition 3X\'s more expensive soap..that doesn\'t Clean the garments. This sounds BAD. I had the same problem and bought a USED Whirlpool Top machine for $150 dollars from a guy who"Likes" to tinker/work on them and three years later...Going Strong! Sorry I could not help you
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jan 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
How much water should be in drum while washing? WE HAVE A MAYTAG mah6700aww series front load washer. When we first used this Maytag front load washer, we actually had a water line that could be seen...
Check the solenoids that admit water into your machine. If they do not open properly when they are energized, you will get little or no water and no cleaning!
Jul 23, 2017 | Maytag Washing Machines
I have been putting my washing on a 40 wash and have been putting enough washing liquid in but my clothes just will not wash, i have felt the glass in the door but it doesnt get very hot, is my washing...
The hot water goes into the machine at a slower rate than the cold water does. Open the hot spigot (water valve) behind the washing machine all the way open, then open the cold spigot just enough to get the desired 'warm' temperature of the water going into the machine while the machine is filling. You may have to shut the door to allow water to flow. Remember that it takes a minute or so for hot water to reach the machine from hot water tank.
Dec 08, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
No water no Spin
Check your 2 in 3 out water valve part# WH13X10029, this responsible for filling of water. By the way wash cycle will not run, until washer sense enough water.
Jul 27, 2010 | General Electric WBVH5200J Front Load...
Washer Glass window in front load door glass is broken.
they should replace it. sounds like problem with unit.proberly only replace door . good luck with it.
Apr 08, 2010 | Kenmore Front Load Washer
Whirlpool fron loader washer leaks at the door
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
Aug 12, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Not enough water per load the cloths get wet but there is no water floating in the drum should there be water visible on the door?
not really...that's the point of these washers..low water usage. the clothes fall into a small puddle in the bottom over and over and rinse often.
Jun 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water level for a front load LG washer?
You're not silly. You could hv said which country you are from..... The water level is usually low, except when the rinsing takes place, when it comes to about half at the glass window. Make sure you turn on the faucet on the wall full when you operate the machine; you can close faucet after wash. (dont forget to open when u begin next wash!!)
Jan 09, 2008 | LG WM-1832C Front Load Washer
Not enough water
run the machine empty. if the water comes to the bottom of the glass window, you're fine. No you don't need to see the soap suds either, too musch soap will cause the machine not to function properly and won't spin out all the water
Nov 15, 2007 | Kenmore 44832 Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
