Question about Kenmore Dryers
Model 70832991 was in a kneehigh flood. Works, but won't heat! Otherwise it works and clicks like it wants to heat,but doesn't.
  • 171 Answers
Could be a number of things but try starting with the thermal fuse and the ignitor.  the water probably damaged one or both of these.
Posted on Aug 06, 2010
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
2012 Ford Fusion rear turn signal still doesn't work after replacing the bulb.
If the front works, then the bulb socket/wire should be the issue. Otherwise if front and back dont work, then flasher.
Jan 31, 2013 | Ford Cars & Trucks
Dryer has power but doesn't spin or heat up
Check to see if the door switch "clicks" when you push and release it. If the switch is bad, the dryer won't run. Here is the part in case you need it.
Oct 30, 2012 | Frigidaire FGQ332ES Gas Dryer
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
I need help on installing logitech quickcam v-ugb35 with windows 7 Ult
If your windows 7 system is set up as 32 bit instead of 64, that's why it doesn't work. according to the logitech website that camera will only work with windows 7 in 64 bit mode...otherwise it won't.
Jul 03, 2012 | Logitech QuickCam for Notebooks Deluxe
My dryer will heat but won't turn, I replaced the Dryer motor but it still doesn't turn. The door switch works fine, when I push the start button it clicks like normal and when I open the door I...
Have you looked for a belt on the drum of the dryer? Mine has a motor but it is attached to a wheel that turns large belt that extends around the drum.
Oct 03, 2017 | Roper Dryers
I'm getting an orange spark on my 1983 ford ranger, 2.3 4 cylinder. Replaced the coil, the distributor cap looks brand new. This truck is excessively flooding and when it does crank, it won't...
yes it could,, if you don't have the correct spark,, the firing would be weaker also, check the wires themselves to the plugs, and also the rotor , just because the cap looks brand new doesn't mean that its not arching inside the cap,, allowing the contact to get a reduced spark, if you replaced the coil, then its after that in the electrical circuit,, which brings you back to the cap, rotor, and wires. normally 3 wires won't go bad all at once unless there is a heat problem where the wires are routed, so I would just replace the cap and rotor, and see how it runs after that .
Oct 04, 2011 | 1983 Ford Ranger
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
Dryers Logo
37 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
