Question about Dishwashers
I have a Maytag Quiet Series 100 dishwasher. There is an icon with a "3" in it just to the left of "heat dry." I just noticed this "3" light is on and the dishwasher won't start when I push the "start/cancel" button. All that happens is the "3" light flashes when you push any of the other buttons, but it won't do anything else. Any help you can give me would be greatly appreciated. Thank you.
The "3" means hold for 3 seconds to child proof it. When it's on, none of the functions work. When you hold it again for 3 seconds, it turns off and your buttons will work again.
Posted on Oct 06, 2010
  • 12,061 Answers
Http://www.ehow.co.uk/how_6543387_troubleshoot-maytag-quiet-series-100.html
http://www.ehow.co.uk/how_6284004_troubleshoot-maytag-dishwasher-not-fill.html
Above are links to assist you to troubleshoot your issue. Below that is a link for your service manuals, use the manual to troubleshoot and isolate your issue.
I think error 3 is Will Not Drain.
Perhaps this fix below will apply, it may be worth a try?
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
http://appliancejunk.com/forums/index.php?topic=2945.0
Posted on Aug 06, 2010
Heated dry cycle light on
see the cause and fix it:God bless you
Failure Code Condition Check/Repair "L" persists in washer display Lid lock failure Replace switch, linkage, lock solenoid or control board.
Jul 21, 2012 | Maytag Quiet Series 300pan Dish Rack...
I have a Maytag Quiet Series 200 dishwasher. The 3 symbol on the face control panel light is on and starts flashing anytime you push any other button and it won't run. What is the problem?
Hello & Welcome to FixYa
You can press and hold the RINSE ONLY/AIR DRY/HEATED DRY button for 20 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Maytag Dishwashers
I have a maytag quiet series 300 dishwasher. On the control panel there is a green light on next to a picture of what appears to be a lock with a number 3 in the middle of it. I am not able to use my...
press and hold the heated dry button 3 seconds it will unlock the dishwasher. That 3 with the lock around it show you that the dishwasher has been locked out to keep buttons from being able to be pushed. You can lock it and unlock it by holding the heated dry button 3 seconds.
Feb 07, 2011 | Maytag Dishwashers
My maytag 200 quiet series dishwasher has a button with the number 3 next to the start/cancel button and will not start. The 3 flashes but won't start? Any idea what that means?
The control panel has bee locked. Press and hold the heated dry button for 3 seconds until the light next to the lock "3" button goes off. This feature is to prevent small children from starting it. Locking the controls works the same way, hold the heated dry button for 3 seconds will turn it back on.
Dec 13, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Quiet Series dishwasher won't start
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
Oct 12, 2009 | Dishwashers
Maytag Quiet Series 300 Legacy Series Dishwasher
Mine was doing the same thing and I just pressed and held down the heated dry button until the light went off. Then I was able to start my machine as usual. Hope this works for you.
Mar 12, 2009 | Dishwashers
All the lights are flashing on Maytag Quiet Series 300
Try pressing heated wash, heated dry, then heated wash, heated dry. It should reset it. Also try pressing and holding the cancel button for 5 seconds to see if that works if the other doesnt.
Sep 23, 2007 | Maytag 24 in. MDB5651A Built-in Dishwasher
Dishwashers Logo
1,241 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
