Question about HP LaserJet color laser printer
My HP 4700 printer suddenly can not print on both sides, yet it used to print on both sides. I can't see the option for duplex on its printing menu. Pls help
  • 903 Answers
You can enable duplex printing from your computer, if it somehow got turned off. Open the printer program, and under Configuration Settings, click Duplex Mode, then click Enable Duplex Mode and then Apply.
At the printer, you can find the Duplex options by clicking Menu and scrolling down till you see Configure Device. Duplex is in that menu.
Posted on Aug 11, 2010
HP Officejet 4315 All-in-one I am a Mac user and I cannot do duplex printing or two sided printing
Mac uses a generic driver for all printers. have you verified that duplex printing is check under the printer options?
System Prefs -> Print & Fax -> select the printer, Options and supplies -> driver.
NOTE: if it says print using "Generic postscript driver" you will need to install the manufacturer driver for the printer to get the option to turn on the duplex printing.
May 23, 2011 | HP OfficeJet 4315 All-In-One InkJet...
I cant stop my printer printing both sides of the paper
After you attach the two-sided printing accessory (duplexer) to your product, you do not have the option to print on both sides of the paper when you try to print. The two-sided printing option is not available in the print dialog box.
NOTE: The HP Automatic Two-sided Printing Accessory (Duplexer) ships with some printer models and is available as an optional accessory for others. Solution First, choose your operating system. Next, follow the steps to make sure that your printer driver recognizes the duplexer. Show all ' Hide all hpweb_1-2_plus.gifhpweb_1-2_minus.gifWindows XP Follow these steps to make sure that your printer driver recognizes the duplexer. Step one: Add the Duplex Unit to your printer settings
  1. Click Start , click Control Panel , and then click Printers and Faxes .
  2. Right-click the printer icon (c01601478.gif ) for your HP product.
  3. Click Properties , and then click the Device Settings tab.
  4. Click the plus sign (+ ) next to Installable Options to expand the list.
  5. Click Duplex Unit (for two-sided printing) , and then select Installed from the drop-down list.
  6. Click Apply , and then click OK .
Step two: Set the Two-sided printing preference
  3. Click Printing Preferences , and then click the Features tab.
  4. In the Paper Saving Options area, select Automatic from the Two-sided printing drop-down list.
  5. Adjust other print settings as needed.
  6. Click OK to save the settings.
hpweb_1-2_plus.gifhpweb_1-2_minus.gifWindows Vista Follow these steps to make sure that your printer driver recognizes the duplexer. Step one: Add the Duplex Unit to your printer settings
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), and then click Printers .
  6. Click OK to save your settings.
hpweb_1-2_plus.gifhpweb_1-2_minus.gifWindows 7
Oct 31, 2010 | HP Photosmart Premium C309g multifunction...
In the past I was able to choose the Manual Option which allowed me to print on both sides. Now every time I choose this option, it goes to Off. Can you please help me with this problem?
Many printers support duplex printing, but they don't all make the duplex option available in the same way. With some desktop printers, choosing duplex means that the printer prints all of the copies of the first side of a page, then pauses and asks you to flip the sheets that it just printed and return them to the printer, after which it prints all of the copies of the second side. This method is called manual duplexing.
To print on both sides of a sheet of paper:
  1. On the File menu, click Print.
  2. In the Print dialog box, in the Name list, select the printer that you want to use.
  3. Click Properties.
Note The information in the Properties dialog box varies depending upon the manufacturer of the printer you're using. With some printers, you will see a Layout tab with a Print on both sides option on it. With other printers, you might see a Features tab, and the duplex option might be called something like Two-sided printing. Explore the various tabs in the Properties dialog box until you locate the duplex printing option.
  1. Choose the duplex printing option that you want.
The options will be called something like Long edge (or Flip on long edge) and Short edge (or Flip on short edge). Whether it's better for the paper to be flipped on the short edge or the long edge depends upon the type of publication you're printing. You might need to print a test publication or two to discover which option works best.
  1. Click OK to close the Properties dialog box, and then click OK again to close the Print dialog box and print your publication.
Sep 25, 2010 | HP Deskjet 2460 InkJet Printer
Does the hp psc 750 do double sided printing
I have not used that specific printer, but from all I can determine, it is not a duplex printer. However hp offers these suggestions on how to determing if your printer is duplex: <br /> "To find out if your printer supports duplex printing, refer to your printer manual or look for the <b>Two-sided (Duplex printing)</b> or <b>Print on both sides</b> drop-down menu in the <b>Printer Properties</b> dialog box on your PC (sometimes found in the <b>Printer Shortcuts</b> tab).<br /> If you can
Aug 20, 2010 | HP PSC 750 All-In-One InkJet Printer
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
Duplex printing
On the workstation go into Control Panel, select Printers, highlight the proper printer, Right Click for secondary menu and choose Properties.
Select Device Settings tab, look under Installable Options, Click on Duplex Options field and select proper setting.
This may differ from printer makes and models.
Feb 17, 2009 | HP Color LaserJet 5500hdn Printer
Option to Print on both sides does not appear
Check your driver. If you are using a recent version of "HP Universal Printing PS" driver, the duplex option is in the finishing tab.
Feb 10, 2009 | HP LaserJet 4650 Color Printer Manual...
HP C4200 Printing both sides
Some printers automatically print on both sides of a page (automatic duplex printing); other printers allow you to manually reinsert pages to print the second side (manual duplex printing); and some printers do not support duplex printing at all. To find out whether your printer supports duplex printing, you can check the printer manual, contact the printer manufacturer, or check the printer's properties by clicking Properties in the Print dialog box.
To find out whether your printer supports duplex printingThe options in the Print dialog box can vary depending on your printer options and configuration.
You can use the following clues to determine whether a specific printer supports duplex printing:
  • Check your printer manual or consult your printer manufacturer.
  • Click the tabs in the Print dialog box and review the options. If options such as print on both sides of the paper, duplex printing, or two-sided printing appear on any of the tabs, the printer probably supports automatic duplex printing.
Notes
  • If you are printing to a combination copy machine and printer, and the copy machine supports two-sided copying, it probably supports automatic duplex printing.
  • If you have more than one printer installed, it's possible that one printer supports duplex printing and another printer does not.
To manually set up a printer to print to both sides of a sheet of paperWith some printers, you can use the Manual duplex check box under Printer in the Print dialog box. Word will print all of the pages that appear on one side of the paper and then prompt you to turn the stack over and feed the pages into the printer again.
You can also use the following procedure to set up your printer for manual duplex printing:
  2. In the lower-left corner of the Print dialog box, in the Print box, click Odd pages.
  3. Click OK.
  4. After the odd pages are printed, flip the stack of pages over, and then in the Print dialog box, click Even pages.
  5. Click OK.
Note Depending on the printer model, you might have to turn and reorder the pages to print the other side of the stack.
Sep 08, 2008 | Office Equipment & Supplies
HP LaserJet color laser printer Logo
1,154 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
