Question about Dell Inspiron 1720 PC Notebook
My Dell Inspirion 1720 laptop suddenly won't recognise its battery. It works when plugged in but turns off immediately if the cord is taken out. Do you know how to make it recognise the battery again? Thanks!! Sabrina
    Scholar:
  • 45 Answers
To recalibrate the battery, complete the following steps:
1. Plug in the AC adapter.
2. Allow the battery to charge until the Battery Charge light turns off, showing that the battery is fully charged.
3. After the Battery Charge light turns off, unplug the AC adapter.
4. Turn on or restart your Notebook.
Reset the BIOS:
1. Restart the notebook.
2. Tap the F2 key as soon as the manufacturer logo appears.
3. Using the arrow keys, navigate to Exit menu and select Get defaults values. press f9 key to load default settings
4. Navigate to Exit menu and select Save Changes and Exit
5.go to the dell web site and update the Bios>> http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R192441&SystemID=INS_PNT_PM_1720&servicetag=&os=WLH&osl=en&deviceid=12916&devlib=0&typecnt=0&vercnt=6&catid=-1&impid=-1&formatcnt=0&libid=1&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=264348
Click on the link and try to download the latest bios for the same.
Posted on Aug 06, 2010
The battery on my Dell 1720 is good, recognised by the computer, charges but will not power the computer. Removing the power lead causes immediate shutdown
You say fairly new. I wonder how new because if the battery is permanantly charging every time you use the laptop it degrades very quickly and you will be lucky to get more than 6 months out of it. If it has been stored, NiCad batteries grow "fingers" of cadmium and tend to go short circuit or leaky. The only real way to test it is by substitution.
Dec 14, 2013 | Computers & Internet
My laptop won't turn on. I tried taking out the battery, a different battery, a differnet power cord. It won't turn on. Is there a way to reset it?
Are there any lights or indications on the battery itself that might tell you if the battery is good? I had a laptop with a similar problem and it turned out to be both a bad battery and a bad "power brick". replacing both fixed my issues. Also, try holding the power cable at the point where it connects to the laptop and push to the left or right. A friend's laptop would only start if you held the power cable to the left. Otherwise, it sounds like a mother board issue. Sorry.
Oct 11, 2012 | Dell Inspiron 8600 Notebook
Can't turn on my mini netbook inspirion - help
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Mar 31, 2012 | Dell (INSPIRION MINI 10) Netbook
I have a dell 1720 that was working great. I went to plug in the power cord and the green light went out on the power box and nothing happened when I pushed the power switch on the computer. The power...
the charging port and or motherboard is grounding out
that is to say positive and negitive coming together
wont damage the charger
once you plug the charger out of thhe laptop and outlet then plug back to outlet the light will return
has to be look at by a technician
Jun 02, 2011 | Dell Inspiron 1720 PC Notebook
Dell 1720 says plugged in not charging , works fine on cord , now that battery is down will not work on battery alone . meter when pushed will light one white light then goes out. battery bad ?
Hello there.
Unfortunately, your battery is "dead". I used to have Dell notebook for several years, and on everyone, after 1 year, battery gone. If your battery is still under warranty go to official Dell service and let
they replace it. If not, you have to buy a new one, and it is at least 130$.
I hope I was helpfull.
Sincerely,
Steve TM
May 29, 2011 | Dell Inspiron 1720 17" Widescreen...
I have a dell inspirion 1720 laptop and neither USB port is working
You need to install the motherboard or chipset driver. That should take care of it.
Thanks
Jul 05, 2010 | Dell Inspiron XPS M140 Notebook
I have a dell inspirion 1720 laptop, unfortrunely i let my friend borrow it and now a password is required for nit to boot
Here is your information
http://www.fixya.com/support/r3656360-dell_portable_computer_bios_hard_drive
Mar 08, 2010 | Dell Inspiron 1720 Notebook
I have a Laptop, Dell Inspirion 9100. Recently it
I would suggest testing your laptop with another adapter, first. Then you'll know whether to replace the adapter, which is priced around $50.
Aug 01, 2009 | Dell Computers & Internet
Dell Inspiron 1720  PC Notebook Logo
227 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
