Question about D-Link DSL-G604T Wireless Router
Hi how do i log in to my d-link wireless router so ican change password and set up wireless cont
  • 12,061 Answers
OK if you DO NOT know you logon & password, you will have to reset the router, remove from the power and locate the button inside a small hole at rear, press this in for a few seconds, and now your router is set to default settings and the login and password is admin, both times. You login by connecting up via an Ethernet cable and use a browser and enter the default address of the router into the address bar, 192.168. ..... and press enter. enter the login and password, admin admin Then it is a simple matter of following the instructions to set up your connection. I have given you a link for your user setup manual below get it and it shows you exactly how.
You will need your ISP Provider's logon and password.
www.cstuff.co.nz/.../D-Link/DSL-G604T%20GenII%20Installation%20Guide.pdf
All in the downloadable manual above.
Posted on Aug 06, 2010
How to log in dlink
How to Log In to Link Wireless Router eHow
  • Share
  • ? Tweet
  • ? Share
  • ? Email
Save Be the first! To log in to your D-Link router and change its settings, visit the router's Web interface and log in with the administrative password. You can usually find the interface address and the password on the bottom of the router or in the manual. The most common addresses are 192.168.0.1 and 192.168.1.1, and most D-Link routers either use the password admin or have a blank password by default. If your router also asks for a username, use admin.
"" frameborder="0" marginwidth="0" marginheight="0" scrolling="no" style="border: 0px currentColor; border-image: none; vertical-align: bottom;"> Promoted by
Step 1: Log In
Visit the router's interface address, such as 192.168.0.1, in any Web browser on a computer connected to the router. If you plan to make changes to your wireless settings, use a computer with a wired connection to avoid getting disconnected after each change. Enter your password -- or leave the box blank for routers without a password -- and click Log In.
Read more : http://www.ehow.com/how_8404370_dlink-wireless-router-login.html
Oct 27, 2015 | Computers & Internet
I try to change the password and Ican't finish the configuration, now the router is inoperative
If the router still lights up and you can see it's wireless network on your computer, you're in luck. The first thing I would recommend is trying to log into your router with your new password. Often, when you're changing your router password, it restarts to complete the process and logs you out, but it appears as though it's frozen or broken. If you cannot log in, I would then recommend doing a hard reset of your router by pressing the tiny "reset" button on the back for 15 seconds, then unplugging the power. Stop pressing the reset button, then plug the power back in. Your router should be back at its default settings, so you can log in and try to change your password again.
Sep 15, 2011 | D-Link DIR-615 Wireless Router
How can i changed the password of my router?
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings. From the center screen, select your encryption type from under the Security Options heading If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router: Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Hope this helps don
Feb 18, 2011 | NetGear WGR614 Router
How do I change the name from D-Link to our personal name please?
Log into the router and change the SSID or wireless network name Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, set the user name to Admin and leave the password box empty. Click Log In to continue. Go to the setup tab and it's there under configuration seesection 3 of the manual
Here is the manual
ftp://ftp.dlink.co.uk/dir_products/dir-615/DIR-615_Manual.pdf
please vote ta
Feb 03, 2011 | D-Link DIR-615 Wireless Router
Hi,I'm trying to access the configuration page of my D-Link DVG-G1402S by typing http://192.168.15.1 into internet explorer however but nothing happens. It doesn't prompt a username and password, just says...
For you to access the router settings page make sure that the rouer is connected to the computer using an ethernet cable so that the computer will be able to comunicate with the router. Then open a browser type 192.168.0.1 on the address bar. The default username is admin and the password is blank. Then you can now change/check the wireless setting page and change it with your desired settings.
Thanks for using Fixya.
Jan 27, 2011 | D-Link Computers & Internet
Need to reset my password
If you need to reset your password for wireless access, or your password to login to your router, you will first have to be logged in to your router. Most routers settings require that you are physically connected to the router (not wirelessly connected) to make changes to the settings. Enter your router's IP address into your browser and you will be prompted to enter your router's username and password. Once logged in you can make changes to the settings such as wireless access and passwords. If you want to completely reset your router and start over, there is usually a small button on the back or bottom that you can push with a paperclip, hold it in for about 15 seconds with the router powered on to reset it to factory settings. Then you can set it up again from scratch.
Sep 16, 2010 | D-Link DIR-625 (790069292637) Wireless...
Hello sir/madam i have problem with D-link router i never change password but now i can not log in the old password why?
Hi do you mean log in to change routers settings or connect to the network which is broadcast by router. If you mean first log in to router settings etc. If your old password don't work you should find a reset button somewhere on router if you press it it will take router to default settings and you can use default user name and password to log in. If you mean connecting to the network you should go to the settings of your router connect to the router by network cable and put 198.162.1.1 in your internet browser put your username and password (which you can find in manual or on internet (just google "D-Link DI-624M Router default username password) and check what password is and change if you like. You should find it in wireless----> security settings. Good luck and please don't forget to let me know if that was any helpful.
Apr 23, 2010 | D-Link DI-624M Router (DI624MRE)
Need two find my networks wewepkey or wpa password.cant connect m
Usually, you can log into your router to find the WEP and WPA password via the configuration screens. At least you can change them to something else if you don't remember your old passwords.
Jan 07, 2010 | Microsoft Wireless Network Adapter Xbox...
How do I set up a password for my wireless router D-Link WBR-2310
Log onto your router by opening your web browser and put in 192.168.0.1
user : admin
password : none
and change your password settings
Jul 11, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I need to change my WEP password
You will have to log into the wireless router and change the wep passkey.  Normally to log in, go to internet explorer and log into 192.168.1.1.  You will then be asked for your credentials.  Then you can change the passkey.
You should upgrade your wep to a WPA for more security.
Jan 31, 2009 | D-Link DI 514 Wireless Router (DI-514)
D-Link DSL-G604T Wireless Router Logo
494 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
