Question about HP LaserJet 2820 Printer
My HP Laserjet 2820 Printer has started printing a wide brown strip down the middle of every page printed. I have checked the rollers on each colour cartridge but there is no discoloration to explain the strip. Do you have any idea what is causing this and how I can fix it?
    Sergeant:
  • 238 Answers
Try with a new cartridge. if no change then your printer need a servicing.
Posted on Aug 06, 2010
How do I clean the rollers on my laser jet printer, it prints with a long black strip in the middle of the page. Hp laser jet 1320
Most likely the heat roller is breaking down in the fuser. The fuser must be replaced. But before going that far, replace the toner cartridge, as it may have a bad cleaning blade. 85% of all print quality defects are cartridge related. This particular model of machine has a very brittle heat roller that more often than not wears out prematurely. This is true across the board for all of the newer HP low end laser printers unfortunately.
Sep 30, 2009 | HP LaserJet 1320 Printer
Hp laserjet 1320 printing blank pages
check printer door, there is a small plastic piece wich pushed down (to open) lasser scaner cover. if this piece is broken you can get blank page
Jun 30, 2009 | HP LaserJet 1320 Printer
Hp 2820 prints only on right side of page
Yes, you will need to replace the drum unit as well. be sure to shop around so you can get the best price because some people mark up the price for that part. You can check the status of your supplies from the printer itself by pushing the "menu" button the printer and scrolling through until you see something about supplies status then press the check mark button.
Jun 02, 2009 | HP LaserJet 2820 Printer
HP Laserjet 5P shading edges of page
This is probably due to a defective cartridge, Charge Roller or Transfer roller.
Check the cartridge for a band of toner still on the drum.
Check the Charge roller for oil or smudges, this roller should be a lighter color and should be relatively free of toner or marks.
Same as the Transfer Roll, which will be dark, though excess toner should be evident.
A relatively smooth straight line is generally the cartridge.
A rather wavey or broken line is most likely the rollers.
You can however attempt to print a large amount of pages (25-50) in an attempt to clean the parts, however if either part is defective they will need to be replaced and no manner of printing will clean them.
Apr 14, 2009 | HP LaserJet 5p Printer
There is a black line down the middle of the page when we copy.
When you say "It does not do this when we are printing directly from our PCs" do you mean this printer is networked? And are you connecting a computer to it manually to print correctly? Or are you printing to another local printer that is attached to your machine?
Either A) the printer in question needs cleaned or has another problem. B) has incorrect drivers installed on the clients printing to it. or C) Has a problem with the network.
Feb 10, 2009 | HP LaserJet 2820 Printer
HP 2820 CLJ, ONLY PRINTS DOWN ONE SIDE
ok typical carousel misalignment
http://www.fixya.com/support/t400576-printing_right_side_only#SameProblemContinued
just take a big screwdriver and check for stuck cartridges
Nov 05, 2008 | HP LaserJet 2820 Printer
Print issues
Look at the fuser, and see if you can see a bad area on the fuser roller, matching the position on the paper. I suspect a bad fuser. Fusers need to be replaced periodically, and typically via a maint kit which replaces several feed rollers as well.. How many pages have been printed.. Print a config sheet to display this information.
Nov 04, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 1012 Printer prints ghost images
I ran the hp toolbox "cleaning" mode too and it did not help the problem at all. I still have a dark smear concentrated in the middle of the page, and ghost images repeated lighter all the way down the page.
Aug 21, 2008 | HP LaserJet 1012 Printer
HP 2840 Colour Laserjet Printer Problem
Don't ever use compataable cartridge for printing .
(1)Check for printer sleave damage....
(2) check for any noise from printer when printing noise from fuser section.
(3).. Print a Demo color level page ...
(4)Check for scaner section ......
Thank you.
Feb 04, 2008 | HP Color LaserJet 2600n Printer
Red dots on left of page
You need to measure the distance between two dots (In milimeters if possible). After that I may be able to determine what is causing the problem.
Jan 24, 2008 | HP LaserJet 2820 Printer
HP LaserJet 2820 Printer Logo
235 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
