Question about Samsung Syncmaster 17" 720N Monitor
My montiour makes auto adjust and shows it's menu & it also change brightness without I touching it's buttons (need help)
  • 29 Answers
Open case remove little plug from back of switches kepp it out close case ....fixed but no power light or buttons picture is fine ; )
Posted on Nov 28, 2011
Okay, here I am again, wanting to know how to add cable channels to my Hitachi C21 F800S TV. It currently only shows one channel, BET. Please help! Thanks!
1 Press menu button to enter the menu screens for the following optional adjustable settings.choose
2-tune
3-AUTO SEARCH (Activate to auto search & preset receivable broadcast stations)
-if it don't work change this
4Press menu button to enter the menu screens for the following optional adjustable settings.choose
5-tune
6-BAND (change the band system for tuning (i.e. VHF-L,VHF-H or UHF).
if VHF-L don't work try VHF-H or UHF and restart all over
good luck
Oct 05, 2014 | Televison & Video
Cannot adjust brightness or contrast
There is no way to do it by mouse click. But most monitor's have an auto adjust button
Feb 06, 2013 | Gateway HD2200 LCD Monitor
After i tun my ipod touch on is stays on a black screen
Tweaking the brightness settings on your iPod touch saves your eyes from unnecessary strain.
Changing the brightness settings can be done quickly if you're on the go.
Adjusting the brightness of the screen can make the device brighter if you're in a dark environment or darker if you're in a bright environment.
Alternatively, you can set the device to automatically adjust to the level of brightness it's exposed to.
Press the "Home" button to return to your iPod touch's home screen.
Tap the "Settings" app.
Tap "Brightness." A scroll bar appears at the top of the screen.
Press and hold your finger against the circle on the scroll bar.
Drag your finger to the right to brighten the screen and to the left to darken the screen.
The screen's brightness will change as you move the circle.
Alternatively, tap the ON/OFF toggle to the right of Auto-Brightness to have the device automatically adjust itself based on the detected brightness level.
Tap the "Home" button just beneath the iPod touch home screen to save your changes and return to the device's home screen.
if this is not or cant fix the problem you might have restore it to factory settings
You can use iTunes to restore iPod Touch software.
Apple recommends using the latest version of iTunes to complete this process.
Follow these steps to get the latest version of iTunes and restore your iPod Touch software.
Back up your iPod Touch's data to your computer before the restore to prevent losing data.
You'll need to reinstall it after the restore process.
Connect to the Internet and install the latest version of iTunes from the Apple website.
Make sure your iPod Touch is connected to your computer.
Pick "iPod Touch" in the Source pane of the iTunes program.
Click on the Summary tab.
Choose "Check for Update."
Select "Restore" and follow the instructions to finish restoring your iPod Touch.
although it does sound like a hardware problem with the ribbon cable leads so if this fails and you are tech savy you could try to open it up and to have a look
hope this helps
Oct 17, 2012 | Audio Players & Recorders
My jvc is showing black and white what do i do
Hello
Just reset the picture adjustments and se whether the colour comes up or not. If not, autotune it once more.
Reset resets all picture adjustments (tint, color, picture, bright, detail, color temperature, dig.
noise clear, Color Management and Dynamic Gamma) at once to the default settings.
Press the MENU button
To RESET
Use [up-down-prog up-prog dn buttons] To enter
The onscreen menu disappears for a moment,
and then the settings are reset to the default
setting for all the picture adjustments.
Press the MENU button when finished
To autotune
?† To AUTO TUNER SETUP
Up or Down button To operate
To choose CABLE or AIR
Press the OK button to start
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen
Mar 21, 2011 | JVC HD-61Z575 61" Rear Projection...
Have a 16" dell flat screen monitior. The display are very dim,and make for hard viewing. Tried to push buttons on computer but a locked icon flashes up. Tried holding the buttons to unlock but did not...
You need to hold the menu button for 15 seconds until the lock icon changes to unlock. Then you should be able to adjust the brightness of the monitor, assuming that the backlight is working properly. Hope this helps you.
Jul 29, 2010 | Dell E171FP 17" Flat Panel LCD Monitor
Brightness!
mcdevito75 here, You can try this, 1 of the buttons should say AUTO presss this button and the monitor will automatically adjust, and Or press the MENU button and see if there"s a brightness feature, I believe there is, you can use the little arrows on your monitor within the MENU options. First try the AUTO.
Jul 04, 2010 | KDS Radius RAD-7c 17" Flat Panel LCD...
Contrest & brightness menu always pops up and
there is a problem in micro controller chip in the monitor replace that biggest chip in the monitor problem will be solved
Feb 28, 2010 | ViewSonic VP920b 19" LCD Monitor
Auto adjust doesnt work
try to push the menu button for 5sec, maybe it will be solve the problem..
Jul 11, 2009 | Samsung SyncMaster 913N 19" LCD Monitor
Samsung Syncmaster 17" 720N Monitor Logo
108 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
