Question about Garden
How do you remove the centrivical clutch assembly to replace pull cord.
    President:
  • 1,545 Answers
The centrifugal clutch is usually just threaded on a threaded part of the crankshaft. This sometimes can't be seen because the clutch itself hides the threads. You can remove it by getting a flat, blunt object such as a flathead chise and placing it against the raised section or ear on the clutch near the center, not where the pads are and tapping it with a hammer. This will of course cause the engine to rotate too and it's mounted on the engine's crankshaft, so...you before attempting the clutch removal, remove the spark plug and turn the engine till the piston is down (look inside with a light) and insert a length of clean, soft rope...that way when you turn the engine, the piston will compress the rope and lock up (without causing any damage) allowing you to remove the clutch.
Posted on Aug 08, 2010
Briggs & Stratton 9000 diagram/repair manual. For the pull cord assembly. FREE
If you are going to be repairing B&S air cooled engines, may I suggest that you make a handy tool for repairing the pull cord starter. To access the pull cord assembly, remove the blower housing to expose the backside of the pull starter. All of the B&S pull start engines have a starter clutch that secures the flywheel to the crankshaft. These clutches go bad after a while. Go to a local repair shop and ask if you can have an old B&S starter clutch. Take it apart and keep the spindle. Have someone weld a T bar handle to the spindle. You will use this to reload the spring in the recoil starter, winding backwards to load the spring. Use a C clamp to hold it in place after loading the spring. Insert the new nylon pull rope through the grommet and out through the hole in the rope spool. Tie a figure 8 knot in the end of the new rope. Slowly release the C clamp to allow the spool to rewind, loading itself with new pull cord. You need about +/- 20 inches of pull cord. Replace the rubber handle on the pull cord and you are ready to mount to blower housing back on the engine. I hope this helps. PS. See the attached url for the Operator's Manual for the 9000 horizontal. http://www.tranzsporter.com/tpdf/Briggs%20&%20Stratton%209000.pdf
May 26, 2016 | Briggs & Stratton Garden
How can I replace starter pull cord?
Hi James:
Replacing any starter cord is usually a matter of removing the pull start assembly, pulling the cord until it is completely unwound, block the reel so it cannot retract, remove the old cord, (remember EXACTLY how it was connected), install a new cord, unblock the reel so it can retract, re-install the assembly.
It may be necessary to remove covers or engine shrouds to get to the pull start assembly. That's part of the fun of "do-it-yourself".
Cheers..
Mar 19, 2016 | Electrical Supplies
Oil leak on poulan snow lower
follow this steps and fix it. God bless you
  • Remove the hex bolts holding the plastic leaf blower housing in place with your hex wrench. You may wish to cut the cord with your scissors and loosen the bolt or screw securing the rope assembly with your hex wrench or screwdriver.
  • 2 Remove the spring assembly carefully. Do not remove the spring, only remove the assembly.
  • 3 Remove the old cord from the leaf blower pull cord assembly by gently pulling it away from the assembly with your hands. Notice the direction the pull cord is wound, as this becomes important in the next step.
  • 4 Wind the new pull cord in the same direction you removed it in Step 3. Make sure the inner end of the pull cord secures in the faster or slot provided on the pull cord assembly. This varies depending on the leaf blower manufacturer.
  • 5 Replace the pull cord pulley and place over the spring. This is the white plastic spool.
  • 6 Rotate the pull cord assembly two or three times in the same direction the cord pulls wearing safety goggles and work gloves. Reinsert the center screw by screwing it in place with your screwdriver; this holds the pulley assembly together
  • 7 Insert the leaf blowers cord end into the end of the handle opening. Secure the handle by tying a knot at the bottom of the new pull cord; this prevents the handle from being pulled off the pull cord while you start the leaf blower.
  • 8 Place the pull cord assembly back onto your leaf blower in its designated area and secure by refastening the four hex nuts with your hex wrench.
  • 9 Replace the housing cover of the leaf blower and refasten the hex nuts with your hex wrench. You removed the housing cover in Step 1.
Nov 24, 2013 | Garden
Broken pull cord
How to replace a broken pull cord on a leaf blower.
1) Remove Hex bolts holding plastic leaf blower housing in place with your hex wrench. you may want to cut the cord with scissors and loosen the bolt or screw securing the rope assemble with hex wrench or screwdriver.
2) Remove spring assembly Carefully. (DO NOT REMOVE THE SPRING ONLY REMOVE THE ASSEMBLY)
3) Remove old cord. Notice the direction the pull cord is wound. This is important in the following step
4) Wind new pull cord in the same direction you removed it, as in step 3, Make sure cord secures in the slot provided on pull and assembly.
5) Replace the pull cord pulley and place over spring.(This is the white plastic spool.)
6) Rotate the pull cord assembly 2 or 3 times in the same direction the cord pulls. (wearing safety goggles and work gloves) Reinsert the center screw by securing in in place with your screwdriver.
7) Insert the leaf blower cord into the end of the handle opening. Secure the handle by tying a knot at the bottom of the new cord.
8) Place the pull cord assembly back onto your blower in its designated area then secure by refastening the 4 hex nuts.
9) Replace the housing cover of blower and refasten the hex nuts.(the housing you removed in step 1.)
I hope this was some help to you. Good luck.
Jul 01, 2012 | Homelite Consumer Products Backpack...
How to reload pull cord spring assembly?
not it not easy but can be done
found this on a web site should tell you what you need to know
john
I removed the screws from the bottom of the unit to separate mechanism that held the blades from the engine. This revealed a clutch on the end of the drive shaft. I removed the springs so I could remove the two halves of the centrifical clutch. I did this so I could then remove the mount these two halves were around. This mount had an arrow and the word 'off' on it. I placed a block of wood against this mount and hit the wood (protecting the mount) as to spin off the mount in the direction of the arrow. A few sharp licks with the hammer and the mount started to come off. I removed it by hand then. Next I removed screws and spark plug so I could get the green housing off where the cord was mounted. Inside this housing is a white spool the cord was on. Becareful with the next step. To replace the cord I removed the spool the cord is wound on but be careful, under the spool is a metal housing under which is the spring that rewinds the cord when you pull start the unit. The end of the white spool that is out of your sight meshes with the end rewind spring. If you pull too far up on the spring or the metal housing that keeps the spring in place you will have spring everywhere and possibly toward your face becareful. So Loosen the two screws and turn the tabs out of the way that hold down the white cord spool. Slowly work the white cord spool off. Replace the cord on the spool making sure you wind it in the proper direction. Then replace the spool and mesh it with the spring. Turn the spool to wind the spring and retention the pull cord rewinding spring. re assemble unit. Good luck! This is not a step by step but I believe it will get you what you need.
Feb 26, 2011 | Garden
How do you remove the clutch drum assembly for model #316.791890
Your clutch drum is held on with a Torx head screw which is screwed into the end of the crankshaft. To lock the engine up so crank won't turn, remove the spark plug, rotate the engine so the piston is down and put some clean pull rope or otherwise soft material in cylinder. ...make sure it is something that won't hang up in the ports on the sides. Then when you rotate the crank, it will compress the rope or soft material, locking up the engine to facilitate removal of the Torx screw, The screw will come loose but will probably not come all the way out...that's just the way they made it.
Jul 08, 2010 | Craftsman Convertible 25cc. Gas Line...
Replace pull cord
The pull cord works by wrapping around a coil that holds the line, and
this works by a spring, and there are 4 bearings in a clutch that help it to engage. Through wear and tear this can get to where it just doesn't work well anymore and needs cleaned. Remove the four screws that attach the motor to the clutch assembly. This will give access to the pull cord. Remove and be careful for the spring likes to shoot out when you remove the 4 tabs that hold the spool in. Replace the cord by running one end through the hole that the old cord is in. You then tie a tight knot in the line, you will see this when you remove the old cord. While there I would clean, lubricate, reinstall, the spring, and you should be back to trimming
Aug 06, 2009 | Poulan Pe550 Gas Edger
Replacing pull cord on weedeater
there is another t20 screw in the neck of the drum. once removed you will expose the drive clutch. soak it good with WD40 then unscrew it from the shaft. if you have all the housing screws out, you should be able to simply remove the housing to expose the pull cord assembly, screwed to housing.
Aug 06, 2009 | Ryobi Garden
Homelite st 155 pull cord wont pull out on my weed trimmer
this works by a spring, and there are 4 bearings in a clutch that help it to engage. Through wear and tear this can get to where it just doesn't work well anymore and needs cleaned. Remove the four screws that attach the motor to the clutch assembly. This will give access to the pull cord. Remove and be careful for the spring likes to shoot out when you remove the 4 tabs that hold the spool in. Clean, lubricate, reinstall, and you should be back to trimming.
Jul 06, 2009 | Garden
Gasoline trimmer won't start
This is a problem with the pull start clutch, remove the four screws that attach the pull cord mechanism to the motor, detach motor, remove the pull start clutch assembly, lubricate, clean and reinstall, You should be back to trimming asap.
Jul 05, 2009 | Garden
Garden Logo
138 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
