Question about Philips Computers & Internet
My Philips double deck stereo burner model CDR775 does not work with todays blank disc speed 1x - 48x. When I put in a disc speed 1x - 24x it works. The problem they don't make 24x speeds anymore. Can you please tell me what I should do?
  • steve huynh Aug 06, 2010
    Any other advises for my issue? Does any one know why they stop making 24x speed drive units?
  • steve huynh Aug 11, 2010
    Thanks for the results!
    President:
  • 3,278 Answers
Hello, Steven.
Your burner was developed 10 years ago. It is older technology and unfortunately will only work with lower speed discs.
You will need to replace the burner or continue to seek lower speed discs, if available.
Hope this helps.
Posted on Aug 06, 2010
  • 1 more comment
  • NinaE Aug 06, 2010
    Hello again, Steven.
    Technology is always changing and improving - faster, better and eventually cheaper.
    Thank you very much for the results. I feel upset now that, I put my unit in a box for 8 years to go to the navy, then return home in 2010 to find out my burner won't expect the blank discs from todays market. That really sucks. Thanks again for the information.
  • NinaE Aug 16, 2010
    You are welcome, Steven. Thank you for your military service and for using FixYa.
  • Philips Master
  • 12,061 Answers
Http://shop.ebay.com/i.html?_kw=24x&_kw=disc
There is nothing one can really do, however i found many many types of 24x disc's at this link below, stock up, and then you have no problem... They may not make them anymore but there are plenty around as show,
It has got to do with the substrate of the disc, and the dye used. Unfortunately your unit, like many others will only play certain types, in saying that though you should try a few differing types many units will indeed work with certain brands...
    thank you, I will try it.
Unit won't play discs,orig or otherwise. Keeps flashing "no disc" although they are loaded.
If the deck in question wont read/play any disc, blank or pre-recorded, try cleaning the laser lenz.
Apr 04, 2014 | Philips CDR775 2-Disc CD Recorder
I need a user manual for a Philips Dual deck Cd Recorder CDR775, Model No:775/00 Production No:VN10220230826. I bought one without the cable. I need to know also what cables I need to record live sermons
Dig down in this slow-to-load directory for the manual.
http://www.p4c.philips.com/files/c/
What 'cable' allows live recoding? You need a mike, a mike preamp and from there probably any standard audio patch cords might work. It would depend on the other equipment.
Sep 06, 2011 | Philips CDR775 2-Disc CD Recorder
CAN I WRITE AUDIO CD IN 8X SPEED
yes, you can write it in 1x or even 42x if you want. The only thing that can happen is a chance of data loss but not quality. Also some older stereos could run into issues not just cuase of the write speed but cd incompatibilitiy. Audio CDs are nothing more than WAV files written on a CD and then a table of contents added as a CDFS file system.
Jun 29, 2011 | LG GH22NP21 DVD-Writer - Internal...
I have a philips audio recorder cdr 760 When i try to record cd rw a blank audio tdk cd the machine said OPC FAIL What I have to do to record the cd rw on my Philips cdr 760 Thanks for your...
There are a lot of forums which discuss OPC failure and it strikes every hardware maker and brand of media.
The bottom line is that certain media and certain writers just don't get along.
The manual:
http://www.p4c.philips.com/files/c/cdr760_17/cdr760_17_dfu_aen.pdf
Discussion online:
http://homerecording.com/bbs/general-discussions/recording-techniques/phillips-cdr870-187247/
http://answers.google.com/answers/threadview/id/318687.html
"I don't buy expensive blanks. I buy modest quality blanks and watch
for sales so that I can them for about a dime a piece after the rebate
check comes in. If I have an OPC Fail message, I try another blank. If
I find that they consistently fail (about half a buck wasted) I move
the stack over to the computer (which seems to work fine with these)
and buy another stack of blanks of a different brand next time I see a
good price..."
an interesting workaround:
http://www.sweetwater.com/forums/showthread.php?10128-Tascam-CD-RW5000
"CDRW 5000 work around for OPC FAIL
Here's a work around for OPC FAIL on cdrw 5000 -
method 1: turn unit on at least 30 minutes or more before use (this seems to work best for me)
method 2: run OPC on an old cd that always works - after OPC passes, remove old cd and insert new CD (you only get 99 OPC runs per disc)
-or use a combination of the two methods
I've always used TDK and I recently bought a new batch and they stopped working. The old ones still work everytime. I don't know enough about the system to guess what the difference is.
side note: CDRW 2000 will finalise discs from the cdrw 5000 but not the other way around.
Hope that helps "
Jan 30, 2011 | Philips CDR760 CD Player
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
My cdr775 does not work with Memorex blank music cd's. Are Philips brand blanks available anywhere? Is there a way to use other blank disc's by Sony or Memorex?
same again here my philips machine would only use there own brand i used to get them from a pound shop no problems with them could not use any other make so thats why i sold my machine the ones i bought were audio cd
Mar 08, 2010 | Philips CDR775 2-Disc CD Recorder
I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
The following is the advertised support for your unit, hope it helps:
Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
Dec 28, 2009 | Computers & Internet
No read no write
One possible source of difficulty is there are different blanks for "slow" recorders (1x - 4x), "high speed" recorders (4x-10x), "ultra speed" recorders (12x-24x), and "ultra speed +" recorders. The disc manufacturers had to change the way the discs were made to accommodate each successive improvement, so older recorders don't work with the newer disks.
It is possible for some 4x-capable "slow" drives to use the "fast" blanks with a firmware upgrade, but there is no advantage to doing so since you're still limited to 4x recording (unless, of course, you're unable to find "slow" CD-RW blanks).
CD-RW discs for the faster drives are labeled with a "High Speed", "Ultra Speed", or "Ultra Speed +" logos. Make sure you buy the right blanks for your drive.
Jan 15, 2009 | LG (GCE-8527B) CD-RW Burner
I have failed to copy pictures on my Sony 48x/24x/48x/16x DVD Rom. The system says there is no disc. I am using TDK DVD-R 1-16x speed 4.7 GB single sided.
Hey,
looking at the details you have posted about your cd drive, its a cd burner with dvd reading cability.
can you post me the model of your drive to confirm this, it says on top of the drive, maybe on the front.
or simply try a CD instead of a DVD
Thanks,
Ekse
Aug 29, 2008 | Computers & Internet
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Computers & Internet Logo
    61 people viewed this question
    Top Philips Computers & Internet Experts
    micky dee
    Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
