Question about NetGear WGT624 Wireless Router
WGT624 router is not getting any power. We replaced the router with another router of the same model that was working at my daughter's house and it wouldn't come on either. Unplugged adapter and plugged it into another outlet. Still no power. I called Netgear support and they told me to go to the Netgear website and buy the new power adapter. I did a search for the model number and it says they don't have it. Now what?
    Sergeant:
    Champion:
  • 301 Answers
    Problem Solver:
  • 16 Answers
Here's a store that sells a UK version of the Netgear WGT624 Router Power Supply - 12V 1.25A: https://www.digidave.co.uk/jshop/product.php?xProd=360
Posted on Mar 09, 2011
4 Suggested Answers
  • 173 Answers
SOURCE: Netgear 108 Mbps Router WGT624 v3
As you say that, you are able to go online with the modem, connect your modem- router and laptop witha cable and check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Posted on Nov 28, 2007
XopenX
  • 108 Answers
SOURCE: No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Posted on Jan 16, 2009
SOURCE: netgear wgt624 v3 problem,cannot go to any sites
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 27, 2010
Power not going to netgear wgt624 router
Your power adaptor is very likely the problem. You can get a suitable 12V Netgear WGT624 power adaptor here, for the UK: https://www.digidave.co.uk/jshop/product.php?xProd=360
Feb 20, 2011 | NetGear WGT624 Wireless Router
Netgear wgt624 does not recognize my ethernet wired connection to the internet. It tell me the cable connection is missing. What goes?
1. check your cable. It should be a "straight through cable".
2. Unplug the router for 1 minute and then power it again.
3. Call your ISP to check the status of the connection (verify).
4. check the manufacturer for firmware updates for your model router.
May 19, 2010 | NetGear WGT624 Wireless Router
So I have a little problem. I'm trying to find out how to connect 2 wireless routers together from across the house. The internet side is connected to a Linksys wireless router (WRT54G). This is located in...
you need a wireless ethernet bridge(like wet54g/wet610n) which will grab signals wirelessly from u're primary router wrt54g,& then a ethernet cable from wireless bridge will be connected to one of the lan port of u'rs netgear router(otherwise u will not be able to do file & printer sharing between 2 routers)Remember,the ip address of all 3 devices shold be of same class.
Jan 02, 2010 | NetGear WGT624 Wireless Router
My WGT624 v3 has no power, seems dead
Yup, I have seen those die that way sometimes. Put a voltmeter on the power supply to check (or take it to Radio-Shack) but it is probbaly the router itself
JOAT
Oct 16, 2009 | NetGear WGT624 Wireless Router
How to install a wireless router without cd
You can download the device drivers from NetGears own website @ http://kbserver.netgear.com/products/WGT624.asp you will need to select the EXACT model( version you have - this can be found on the stamp underneath the router that has all those barcodes on) and download the latest drivers for yours. by doing this it will trigger 1 of 2 responses:
1. You have the latest version, no update is needed
2. You must setup your device before updating drivers. to do this please select OK
1 - Will trigger an auto setup of the device.
2 - Will take you through the setup wizard itself
which depends on how your router was shipped. If you have brought the router 2nd hand then you can obtain a new setup disc free of charge via the same site if neither of the above work.
For future ref: PLEASE INCLUDE YOUR 'FULL' ROUTER INFO-Different models of the same router can work quite differently and you may not get a best fix without it
Best Regards
Cruton
Feb 25, 2009 | NetGear WGT624 Wireless Router
Problem with internet working with router.
I had to turn off WMM on the router. One computer supported WMM so it worked fine, but the others didn't.
Feb 23, 2009 | NetGear WGT624 Wireless Router
I have no installation manual for the wgt624
You can download a manual from the Netgear website.
You'll need the full model and version number of your router. If you're not sure of this, take a look at the base of the router, where there should be a label with this information (for example, WGT624v4, or WGT624v2.)
Then visit this page and click the link to the Support Page for your model number:
Links to the downloadable installation guides/manuals are usually on the left-hand side. Good luck.
Nov 30, 2008 | NetGear WGT624 Wireless Router
Have no set up instructions for the wgt624 wireless router
do you have the cd that came with it? if not, everything can be downloaded here
http://kbserver.netgear.com/products/WGT624v1.asp
there 4 different routers in the wgt624 family. this is the first. check your label to be sure it isn't a later model chipset such as v2, v3, v4. if so use the download link at the netgear site to get the correct downloads for your specific model.
Neatgear WGT624 take over
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 06, 2008 | NetGear WGT624 Wireless Router
Nov 27, 2007 | NetGear WGT624 Wireless Router
NetGear WGT624 Wireless Router Logo
183 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
