Question about Nokia N70 Cellular Phone
Just white screen cannot get thru with calls. tried software but in vain i was told you need to change the PCB which cost about 600 to 700 rs.. the set will function.. pl advise where i can purchase the PBC for my set N70 nokia
    Scholar:
  • 129 Answers
Hai, In my country, we do not change the main board, because the cost is equal to the price of a new, why you need to buy the main board under the warranty repair only the longest one month? whereas if you buy a new or used, it is more worthwhile. If you have tried to change a new LCD display screen, but the results remain the same, perhaps it is divided UEM ic problem, this happens because you always fall. ic is too close to the frame. hentakkan effect on the frame due to falls, may interfere with the original position, if the worst Solder balls under the ic off. If you are lucky. Try to heat the surface of the UEM ic, add Solder flux before the process is done. Solder balls when you get looked melted, press the top surface is a soft ic so it does not directly close to the surface of the board, as this can make Solder ball attached to one another, if you have a place to sell spare parts for ic, it is better there ic change is the new home you buy a new board. cheaper cost, but I do not know the cost of installation if you sending to your technician.
Posted on Aug 06, 2010
CANON IR 1600 COPIER IT WENT OFF AFTER REPLACING POWER SUPPLY BOARD STIL COULD NOT WORK UNTIL I HAD TO REPLACE MAIN BOARD THEN IT CAME ON BUT WITH ERR CODE 354 I HAVE TRYED TO CLEAR IT ALL IN VAIN
the counter PCB or the serial no. PCB is not matching.Did u got the main board with the counter pcb attached.if not then u have to get the counter pcb of the same board or attach the serial no pcb and the counter pcb of the old board . u will get it if ur a rep .if not then u have to consult one
Jun 28, 2011 | Canon iR 2016i Black and White Copier
My nokia n70 cannot start, got light on but it just won run :-)
Do you have a white screen and did the phone doesn't move after that??If that is the problem then your phone may have been infected by virus or you would have repeatedly dropped your phone..Switch off and on the phone by removing the batter and if this doesn't solve your problem,Your symbian os software should be changed to solve this problem.It generally costs Rs.250 to Rs.300.I got the same problem in my nokia N72 and got solved in this way...Best of luck..
Dec 11, 2010 | Nokia N70 Cellular Phone
I am unable to put the lock on my cell nokia n72. my cell code is 359400003259792 please send me master code.
first try to format the phone using the code below
first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
your problem is again continuing go to a mechanic and ask him to flash the mobile ( re-install the software ) it costs around rs 100 to 150 - this helps to reset the code
please rate me if it helps u
Oct 22, 2010 | Nokia N72 Cellular Phone
LG LCD TV there no display on screen. Service person says it SNP(power supply) card has to be replaced as its supplying more current to PCB & cost is Rs. 6000. I would like to know whether the...
No power LED light indication to the tv screen panel at all or LED light power indication flashes?Yes,it is the power supply board have problems.Tries websites like Shopjimmy.com,Ebay.om to buy a refurbish power supply board for the replacement.Refurbish power supply board cost about usally $100-$110 plus shipping.
Sep 28, 2010 | LG Televison & Video
When i rcharge my phone only a white screen
Tray to make an emergency call like diall 112 or 911 if works it means your phone hardware (engine) or software just fine.in that case the problem are on display.usually the problem are from rubber wire (flexyble cable) that connecting between PCB (engine) with up board like screen,ear phone etc.or the screen (LCD) it self. first, tray to change the flexble cabe.I hope it helps.
May 26, 2010 | Nokia N95 Cellular Phone
X red color sign inside battery meter while charging
pls try to install moto software through gsm_ forum by Google search
Jul 17, 2009 | Motorola Mobility Moto Q
Touch screen not functioning after falling down
the touch panel costs 1500 bucks if u give it in redington, chennai.
phone lock cost depends upon availability and the goodness of the service people. I got it changed for 115 rs. Board and socket connection, am not sure. But if u ask me, better buy a new one than spend this much amount.
Mar 31, 2009 | Motorola Mobility ROKR E6 Smartphone
RS-25 foot pedal not working
The foot pedal needs to be plugged in before the software is installed. Just uninstall the software (your files will be fine) and reinstall with foot pedal attached.
Feb 17, 2009 | Olympus RS 25 (147035)
Sony Ericsson K750i White Display
try service mode to check it
>*<<*<* (<=left move on stick)
(>=right '' '' '' '''' )
Nov 18, 2007 | Sony Ericsson K750i Cellular Phone
Nokia N70 Cellular Phone Logo
52 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
